01-13-2024, 01:40 PM | #1 |
Rep 7
Camshaft sensor no 12v
Hi, I am new to the forum, so please excuse any stupid questions. My bmw 5x 2014 f15 530d had does not have a 12 volt voltage at the camshaft sensor
Cranks but does not start code 273c00 on ista camshaft sensor no signal I checked all the fuses. They are fine the battery I don't know how old it is. I just acquired the car, I have checked the 12v wire from the sensor all the way to where it goes into the car at hood Only shows 3.4volts 1 pin is 5v Middle pin is ground 3rd pin suppose to be 12v but i get 3.4 Tried new sensor still same Any help much appreciated Tried with jump leads and booster pack connected At battery just cranks |
01-15-2024, 10:58 AM | #2 |
Rep 7
so it turns out fuel pump under rear seats is shorted .
positive and negative seem to shorted both are ground this will also throw this code possibly , tried removing relay short still present where this will be shorting any ideas thanks |
