12-16-2014, 09:05 AM | #750 |
Rep 40,314
12-16-2014, 09:06 AM | #751 |
Rep 40,314
12-16-2014, 11:57 AM | #752 |
Rep 18,628
@opasha @shawnsheridan, thank you.
I will PM you the link of my server after finish downloading them.
12-19-2014, 04:09 AM | #753 |
Rep 193
Hi guys!
I read yesterday info that some guy made a coding on his x5 50d, the coding changed the sound from 50d to x5M, did somebody hears about this??? Or may be did the same thing??? |
12-19-2014, 05:32 AM | #754 |
Rep 43
hi boys,
I did now most of the coding from the excel sheet and everything worked out as expected. except the foglight on with high beam: Enbales Fog Lights with High Beams / Flashers BDC_BODY 3068 NSW_AUS_BEI_FL aktiv I tripple checked and its aktive. anz idea how to work this out? Thanks! |
12-19-2014, 06:21 AM | #755 | ||
Rep 3,990
12-19-2014, 02:00 PM | #757 |
Rep 3,990
PM sent .
12-19-2014, 05:55 PM | #758 |
Rep 193
Hallo guys!
Have a problem and would like ask yours help(if somebody can) Yesterday somehow I've lost key(second one I had at home) and came to dealer to cancel key which one was lost (prevent access to the car). So came to dealer and they told that cannot do programming(remove lost key from soft) and need to upload latest software version. I told them that it is fine with me and they can proceed with it. After couple of hours car was finished. When I switched on engine I saw yellow triangle on the left side of the panel, after checking vehicle status I relalised that tyre pressure need re-calibration. I tried to do it at least 10 times(as several times after process started and aprox.15% was done the system said that tyre pressure monitoring activated but no values shown) and finally did it. I couldn't come to dealer straight away as it was end of the day, otherwise I would do it after second time failure to calibrate. After this I came home to re-programm back settings(obviously they were gone after software upgrade) which I did before(like engine auto stop/start function, USB all formats readings, etcc...). But when I started ESYS(v.3.24.3) and went till process read ECU report showed me 15 errors(please see in attached file)!!! So could you please tell me what kind of errors they are??? Is it ok???? P.S. And if these errors are not ok, I am not sure how to go to dealer and what to say-how I found it out... Please help... |
12-19-2014, 06:02 PM | #759 | |
Rep 3,990
2) Since you did a software update, you need newer esys/psdzdata files. I have PMed you the new links. Download them and you should be able to get it to work without all those CAFD errors. Those errors occur when there are updates/big changes in those specific ECU folders - the new version does not match with the older psdzdata files.
12-19-2014, 06:26 PM | #760 | |
Rep 193
1) I ment to say that I had to do standard procedure(everyone can find it in car settings) "reset tyre pressure monitoring system" and I re-calibrates(process starts from 0 till 100%) and after this it can show the pressure. But the thing was that when I pressed "reset" it did not finished process and stopped(after this I was not able to see pressure) and had to repeat it several times, and finally was able to achieve normal working condition(and see pressure). 2) More difficult-trying to follow your instructions which you PM me Still downloading newest soft... |
12-19-2014, 06:58 PM | #761 | |
Rep 3,990
12-19-2014, 07:04 PM | #762 |
Rep 3,990
It seems like some people are having difficulty setting up ESYS for the first time. Should I make a video for ESYS install with the PSDZDATA files? Let me know.
12-19-2014, 07:31 PM | #763 |
Rep 193
12-19-2014, 07:51 PM | #764 |
Rep 43
12-19-2014, 08:02 PM | #765 |
Rep 3,990
It's ok. Sometimes the answer is right under our nose. We just tend to over-think things .
12-20-2014, 04:05 AM | #766 | |
Rep 208
12-20-2014, 06:09 AM | #767 |
Rep 193
Opasha thanx for the help yesterday!!!
You are very quick and experienced user, will try to catch in future as well Meanwhile as you advised will write to shawnsheridan, may be he can advise something regarding problem with 6NS |
12-20-2014, 06:30 AM | #768 | |
Rep 3,990
You're very welcome, buddy . Sounds good, keep me posted .
12-20-2014, 12:52 PM | #769 |
Rep 193
Yeaaah!!!
Today with help shawnsheridan and opasha in my car start working 6NS function!!! Thank you very much guys!!! Trying to find out what benefits it can bring to me, but anyhow more options is better Thanx once more!!! YOU ARE THE BEST(if feel myself really stupid, when I see what and how quick they are doing-it was remote assistance) P.S. Going for shopping-my GF angry as almost whole day I was busy with it. |
12-20-2014, 12:55 PM | #770 | |
Rep 40,314
Angry GF =
