      05-21-2018, 08:51 PM   #749
penet05
Drives: 2014 X5 Sdrive35i, 2013 328i
Can you activate/de-activate rear air suspension with Bimmercode?
      05-22-2018, 01:09 AM   #750
CatalinP
Drives: BMW X5 F15 2014 3.0xd
No, you need Ista-D.
      05-22-2018, 04:08 PM   #751
SCA
SCA's Avatar
Drives: Multiple BMWs
Originally Posted by Dan_man_001 View Post
Any luck coding ambient lighting after dealer reflash?
Uncertain as it is not an important coding feature for me.
      05-22-2018, 05:29 PM   #752
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
523
First page if the coding thread. Just search. It's like the first thing. The cheat sheet is kept up to date and has t changed recently
Thanks!
      05-27-2018, 07:06 PM   #753
seis-speed
#savethemanuals
seis-speed's Avatar
Drives: 1M | GT3 | J392 | GRc
Speed display in instrument cluster? I can’t get it to display? Can I code this with bimmerlink? Thanks!
      05-28-2018, 02:47 AM   #754
mkdan2004
Drives: BMW X5 F15
You can code speed in the instrument cluster with bimmercode, not bimmerlink (bimmerlink is for diagnose mostly). I have coded it in my F15 and it works well (i have 6WB cluster).
      05-28-2018, 01:25 PM   #755
seis-speed
#savethemanuals
seis-speed's Avatar
Thanks! I have BimmerCode.
I coded it in, but now have a check engine light and MPG! ⚠️
Any suggestions?
      05-28-2018, 02:17 PM   #756
smyles
Drives: '21 X5
Check engine light will go away
seis-speed2430.50
      05-29-2018, 12:50 AM   #757
mkdan2004
Drives: BMW X5 F15
I believe it happens when you code with engine running. It happened to me too. After restarting the car, CEL went away. I was used to coding with E-sys, which has no issue with coding with engine running.
      05-31-2018, 08:50 PM   #758
eric_s
Drives: X5
Originally Posted by SchweiZ4 View Post
Coding is just replacing values of existing parameters with other values, that are often more or less accepted by the system.
So I don't see where it can harm specifically 40e electronics.
The only thing is not to change parameters that are not known or tested by anyone.
You can go ahead !
thanks VM for your inputs..
      06-03-2018, 12:55 PM   #759
SchweiZ4
SchweiZ4's Avatar
France
52
Drives: F15 X5 M50d
You can go ahead !
Just reminding coding principles, that is it, you're welcome.
Does anyone knows how to turn on surround camera on reverse instead of reverse camera by default?
That's the last coding thing that I am missing ..
1230vani648.50
      06-12-2018, 04:43 PM   #760
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
You can add the "x5 M//50d" logo to 6wb cluster now!
      06-12-2018, 07:46 PM   #761
RichM50d
Drives: ‘22 8 Series Gran Coupe
What’s the point, if you don’t have an M50d?
      06-12-2018, 07:48 PM   #762
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
What's the point, if you don't have an M50d?
Just looks cool I think
I tried before didn't work, now available!
      06-12-2018, 10:01 PM   #763
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Lol I somehow coded M550d to my cluster when I open the doors or when I shut off the engine. Not exactly sure how I did that lol. It happened when I was coding TJA. I must have seen something and changed it and forgot all about it. Haha anyone know where this is. Again it's only when I first open the door and after I turn the car off when it shows up at the bottom of my cluster.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      06-14-2018, 06:45 AM   #764
Ljn21
Drives: 2017 X5 x35i
Still having some trouble getting bimmercode to work. I am connecting to the vgate via wifi from an iphone 6...when I go to change the code, it gives a network connection error, almost like because when connected to the vgate it cant connect to the actual internet (cant have two wifi connections at the same time)...what am I doing wrong? Should I be connecting to the vgate via Bluetooth instead? The iphone I am using isnt active on a carrier, its a backup phone so to get internet I connect via home wifi and I did verify signal by disconnecting from vgate wifi and connecting back to home wifi. Slow communication is enabled.
      06-14-2018, 07:12 AM   #765
SchweiZ4
SchweiZ4's Avatar
France
52
Drives: F15 X5 M50d
Usually when I get this error, this is because the car is not turned on or shut down during the process.
My steps are the following :
  1. Open the car
  2. Push the ignition button once
  3. Push the vgate button to turn it on (if it is pluged in)
  4. Connect via WiFi to vgate with your phone
  5. Using the app, connect to the car with the application
  6. Code anything you need without touching to the car ignition button or whatever
You can find more information in the BimmerCode app --> Settings --> Quick Start Guide.
Hope it helps
      06-19-2018, 11:00 PM   #766
SparkyBeems
SparkyBeems's Avatar
Drives: 2017 X5 xDrive40e M-Line
Hey everyone… Beginner here trying to code my 2017 F15 40e using the Bimmercode/Bimmerlink apps.
I’ve had success in all areas until I arrived at the BDC… I coded comfort access mirror folding and door handle lights in reverse, and after the barrage of faults that came after the BDC came back online, I was stuck with a CEL that wouldn’t go away. No faults showing up in iDrive though. I cleared all faults a few times with Bimmerlink… no luck. Then loaded the backup coding back to the BDC, cleared all faults, and still a CEL. Took the car out for a little spin, still had the check engine light on. I let it sit for a few hours and then came back and cleared error memories again, and this time went into the hidden menu in the instrument cluster and did a few tests and the “software reset”, and finally, the CEL was gone!
So… thinking that I figured out how to clear the CEL, decided to go back into the BDC and code the door handle lights and mirror folding again. Same as before, when the BDC came back online all sorts of messages about stability and parking brake, etc- and the return of the CEL. I then proceeded to clear the error memory with bimmerlink, and then again do the software reset in the hidden menu of the instrument cluster, but this time the CEL remains. I have not yet driven the car since the second round of BDC coding – not sure if that is part of the reset logic
So before I revert the BDC to backup (the coded functions that I want are working), I wanted to see if anyone knows what I’m doing wrong— or what the BMW logic for clearing the CEL actually is. As I stated before, in iDrive, I’m getting an “all systems ok” message, and everything else as far as I can tell is normal.
Thanks in advance for your help!
UPDATE:
Car sat overnight and in the morning the CEL was gone. I suppose this is the CEL reset logic?
      06-21-2018, 09:54 PM   #767
ragingpixel
Drives: 2015 X5 50i
Took a pass at coding my 50i tonight, and everything worked flawlessly. I used BimmerCode (iPhone) and the Veepeak ODBCheck Bluetooth adapter, and coded the following:
- Variable light distribution
- Turn signals on HUD
- Active blindspot at lower speed
- Hatch open/close from remote / inside button
- Tire pressure/temp display
- Door handle LEDs on while reversing
- Turn off radio on door open
- Disabled disclaimers
Had to use expert mode for a few of them, and used the cheat sheet in the other coding thread for the values. Just took it for a test drive, and everything works great. Got a few errors on the cluster after programming various modules, but anything that didn't clear on its own after a few seconds cleared after turning the ignition off and back on. Didn't need to download BimmerLink
      06-21-2018, 10:19 PM   #768
Duke I
Drives: X5
Will these still work on a 2018?
Duke
2018 X5 50i
2015 911 C2S
2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run)
      06-21-2018, 10:48 PM   #769
ragingpixel
Drives: 2015 X5 50i
According to the cheat sheet, the turn signals on HUD doesn’t work with digital instrument clusters (6WB)... not sure if that means all 2018’s or not. The rest of it should work.
      06-21-2018, 11:13 PM   #770
Duke I
Drives: X5
Thanks Raging. It's been hard for me to determine whether the cheat sheet is up to date and applies to all years of the F15, especially 2018 with potentially new software. Imesp daily want the turn signals in the HUD -- I did not option the 6WB, did not want them -- and GFHB which seems to not be on the cheat sheet -- at least it's not clear to me that it's there, VLD yes. I need to get it all figured. D
Duke
2018 X5 50i
2015 911 C2S
