05-16-2018, 01:22 PM | #1 |
Rep 1,180
MPE buzz at 1500rpms
Hi All,
Now that it's getting in to windows down season, I'm noticing a slight metallic buzzing sound at around 1500 rpms that seems to be caused by the exhaust resonance frequency at that RPM. It's noticeable when the vehicle is cold and seems to go away after the car/exhaust have warmed up. I notice it when the rpms drift over 1500rpms in each gear as I'm acceleration. It's mostly noticeable in eco mode and sometimes in comfort mode. I'm thinking this is mainly because you're generally in the low RPM range in those two modes when driving casually. It almost sounds like the heatshield around the exhaust is vibrating against something causing that metallic buzzing but I can't seem to put my finger on it. Has anyone noticed this or have this issue? Any ideas on how to narrow down the sound? I'm thinking about just buying some dynamat and sticking it to the heatshield to see if that makes any difference.
2018 X5 35i M-Sport
05-16-2018, 01:47 PM | #2 |
Rep 1,915
Have noticed some throttle issues at low rpms too, eco and comfort modes.
I keep my windows closed 24/7, 365 days and music is on, so it's tough to catch those sounds. Will open window and test case you described and report back. |
deutsch1003943.50 |
05-16-2018, 02:30 PM | #3 |
Rep 1,180
Well, I don't think noise in my situation is actually coming directly from the exhaust. Not sure what throttle issues you are having but I haven't noticed any throttle issues with the MPE. Are you referring to sound or throttle response?
2018 X5 35i M-Sport
05-16-2018, 03:37 PM | #5 | |
Rep 1,915
Nothing major, I just don't think the throttle response is the same as it used to be; could be the BMS intake too. Another member reported similar issue with ACS exhaust. Update: took it for ride, rolled down windows, nothing from the rear. Last edited by menelaos; 05-16-2018 at 03:53 PM.. |
05-16-2018, 04:44 PM | #6 | |
Rep 1,180
2018 X5 35i M-Sport
05-16-2018, 04:56 PM | #7 |
Rep 2,194
05-16-2018, 05:15 PM | #8 |
Rep 70
I assume it's the crackling popping, and burbling from the MPPK +MPE. I hear it from time to time when I'm in bumper to bumper traffic. It's pretty faint for the most part and I drive with the windows up 99% of the time. Is the popping not normal or should I be looking into this ?
05-16-2018, 05:21 PM | #9 | |
Rep 2,194
05-16-2018, 07:54 PM | #11 | |
Rep 5,066
Violator4587.50 |
05-16-2018, 08:09 PM | #12 |
Rep 2,194
05-16-2018, 08:54 PM | #14 |
Rep 1,180
It’s not the clamps. I checked the connections when I had the car on a lift installing the lip. I’m ordering some sound dampening self adhesive sheeting to stick to the heatshield above the exhaust to see if that killz that buzzing.
It’s completely gone after the exhaust has warmed up and the exhaust tone has changed.
2018 X5 35i M-Sport
05-16-2018, 09:00 PM | #15 | |
Rep 2,194
05-16-2018, 09:02 PM | #17 |
Rep 1,915
05-16-2018, 09:03 PM | #18 |
Rep 1,180
I haven’t since they didn’t install it. If the sound dampening stuff doesn’t solve it I might take it in.
2018 X5 35i M-Sport
05-16-2018, 11:11 PM | #19 |
Rep 18,713
@CeeTeeX5 , check the tip.
I start noticing BMW MPE tips are cheaply made. I am on my 2nd set of tip on my G30 540i MPE. Starting to rattle again.
05-17-2018, 08:21 AM | #20 |
Rep 1,180
Oh interesting. I’ll check the tips too.
2018 X5 35i M-Sport
05-17-2018, 08:38 AM | #21 |
Rep 714
Drives: BMW X5 M Sport - G05
If it’s the tips, maybe powder coat them? The extra thickness might help dampen the rattle just enough.
05-17-2018, 09:15 AM | #22 | |
Rep 1,180
On that note, I was really trying to focus on the sound today and noticed it kind of sounds like metal vibrating against plastic which is why I'm leaning towards the heat shielding or potentially something in the bumper vibrating.
2018 X5 35i M-Sport
