08-03-2014, 08:47 AM | #24 | |
Rep 3,990
Before anyone helps you over the internet, you need these items: 1)OBD2 Ethernet Cable 2)Ethernet to USB Dongle (only if your laptop or tablet does not have an ethernet port) 3)Latest ESYS Software/Latest PSDZData files (these are basically all the coding files that ESYS reads/codes when connected to your vehicle)/EST (.est file) Token file from fxx token master(at)gmail(dot)com (no spaces in his email; that's the only way I was able to post that because I think emails are not allowed) - .est token is needed for reading/coding access in ESYS. Use this Step by Step Coding guide to install the files above: http://www.bimmerfest.com/forums/sho...d.php?t=631884 If you have all of the above installed and working correctly or at least fully downloaded with easy access to each file, I can remotely help you over the internet via Team Viewer - download the all-in-one full version, it's free (select personal/home use): http://www.teamviewer.com/en/download/windows.aspx. Have a look here at r33's cheat sheet for things you want coded: https://docs.google.com/spreadsheets...9s4/edit#gid=0 REMINDER TO ALL: You need to have everything I indicated above if you want ANYONE to remotely help you code. If you have difficulty setting up the software, feel free to PM me, but the step by step link above is what I followed and it was easy. The best people that have way more knowledge than me to get any coding help/software download help/questions of any kind regarding coding are shawnsheridan (bimmerfest forums), wdimagineer (bimmerpost), and r33 (both forums). There are others with plenty of knowledge here (http://www.bimmerfest.com/forums/sho...d.php?t=693949), but I'm just referring to those that I know are very active and you are familiar with. If I gave any wrong information, please don't hesitate to correct me. Thanks .
08-03-2014, 10:25 AM | #25 |
Rep 18,728
For sure, but my bet would be opasha will have more time during the weekend.
08-04-2014, 12:36 AM | #26 |
Rep 162
