12-13-2016, 05:29 PM | #155 | |
Rep 103
Are the any special member discounts or current promotions going on that a hypothetical new customer could take advantage of?
cars
12-13-2016, 05:45 PM | #156 | |
Rep 18,739
12-19-2016, 03:17 PM | #157 | ||
Rep 2,353
12-19-2016, 03:25 PM | #158 | |||
Rep 18,739
12-28-2016, 09:16 PM | #160 | |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
463
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
12-28-2016, 09:20 PM | #161 | ||
Rep 18,739
Where the 15mm doesn't clear it. You can use the 18mm for the front, but it will stick out 3mm more than the 15mm.
01-02-2017, 07:00 PM | #162 | |||
463
Rep 2,002
01-06-2017, 03:18 PM | #163 |
Rep 2,353
Thanks to Ben and a set of 15mm rear spacers, I am much happier with the stance on the OEM winter set for my F85.
Easy enough to install with the proper tools. Highly recommend picking up a wheel hanger (makes lining up the spacer and wheel much simpler), a torque-limiting socket (brakes torque at 75ft/lb) and a good torque wrench. Of course, you'll also need a breaker bar, BMW jack adapter, jack stands (if you want to be extra safe), anti-seize and a jack (my low-profile 2-ton jack seemed a little stressed under the weight of the F85... might be time to upgrade). Tools... Holly brakes...(makes sure to remember the anti-seize)! Left side are the OEM 11.5x20 with 315 (width) Continental DWS06, Right side OEM 10.5x20 with 285 (width) Pirelli Scorpion Winter. Photo wasn't taken directly behind, so it's a bit skewed. Finished product.. Last edited by Roundown; 01-06-2017 at 04:07 PM.. |
r33_RGSport13022.00 Mexecutioner101.00 |
01-06-2017, 03:57 PM | #165 |
Rep 2,353
01-07-2017, 12:55 PM | #166 |
463
Rep 2,002
My set up 15mm rear
Here is my set up no spacers in the front 15mm in the rear
hufington3122.00 |
01-07-2017, 01:01 PM | #167 |
Rep 18,739
Looks imbalance IMHO.
The 5mm in the front will help.
01-07-2017, 02:53 PM | #168 |
463
Rep 2,002
Would the 5mm really make a difference though? To bad can't do thicker.
01-07-2017, 03:02 PM | #169 |
463
Rep 2,002
I have these laying around from my e92 will they work if I buy bolts from u?
01-07-2017, 03:04 PM | #170 | |
Rep 18,739
That E92, you need to check the center bore. Most likely won't fit.
01-07-2017, 03:09 PM | #171 | ||
463
Rep 2,002
01-07-2017, 03:10 PM | #172 | |||
Rep 18,739
01-07-2017, 04:48 PM | #173 | ||||
463
Rep 2,002
01-07-2017, 06:39 PM | #174 | |||||
Rep 18,739
10mm, 12mm, or 13mm won't fit due to the hub centric clearance.
01-08-2017, 07:34 AM | #175 |
Self-Deprecating Narcissist
7266
Rep 6,561
For anyone installing spacers, keep in mind your park assist may curb your wheels because the wheel widths have changed. Park Assist on my vehicle gets in pretty tight to begin with and is basically parked as close to the curb as possible. I would be concerned adding 15mm and damaging the wheel.
01-08-2017, 02:44 PM | #176 | |
Rep 18,739
The whole time I have park assist feature in my 650GC, I almost never use it. 1 main reason, there are not that many parking condition where it require me to do parallel. 2nd reason, I never got it to work. It is not as easy as it seems. 3rd reason, whenever you are setting it up, the car behind you will not have the patience or give you enough clearance to do it. Because you need to pass the spot about a car length before the park assist able to detect the empty space. In conclusion, it is a pain to use it. Not as easy as it seems.
