10-21-2016, 11:24 AM | #2839 |
Rep 591
The sport+ is working. What's not is unlocking doors when the engine is off. My launcher is 2.4.3 please pm the newer version and how do I install it over the old one?
10-21-2016, 12:58 PM | #2841 | |
Rep 40,774
E-Sys Launcher Premium: https://mega.co.nz/#F!PV9lxa4J!wvP4wFcYZVF84JBfc__lAw The link does not change.
HZX540e373.50 |
10-21-2016, 01:04 PM | #2842 | ||
Rep 591
10-21-2016, 03:27 PM | #2843 |
Rep 591
Thank you
Almaretto Updating the esys launcher gave me the CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING to unlock all doors when the engine is stopped. Please remember to go into iDrive after the coding to set unlock to all doors instead of just the driver door.
shawnsheridan for posting the link to the launcher, I suggest adding the link to the first post by opasha which I memorized by heart |
10-21-2016, 04:16 PM | #2844 |
Rep 11
Just having a go at coding for the first time. I have a UK 2014 X5 M50d. I've established a connection ok. Clicked Read FA, and Activate FA. Then Read ECU. The box under SVT is populated, but only with BDC_BODY and BDC_GW. I do not see any of the other modules listed.
What am I doing wrong? |
10-21-2016, 04:18 PM | #2845 | |
Rep 40,774
10-21-2016, 04:33 PM | #2846 | |
Rep 11
You were spot on. Did the coding. Just need to go out and make sure it's taken affect. I couldn't find the setting to enable the foglights to come on with the welcome lights. I found the following in a word doc (not sure where it was from now), but I couldnt locate these values to change: Turn on Fog Lights with Welcome Lights: 3063 MAPPING_NEBELSCHW_L_PART_OF_WL set to: werte=01 3063 MAPPING_NEBELSCHW_R_PART_OF_WL set to: werte=01 |
10-21-2016, 04:46 PM | #2847 |
Rep 11
Enabled video in motion and remembering of auto start/stop. Brilliant.
Thanks very much for this incredibly useful thread and all of the information within it. Made it all very painless and simple. |
10-21-2016, 06:05 PM | #2848 |
Rep 8,364
[QUOTE=HZX540e;20741480]Almaretto Updating the esys launcher gave me the CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING to unlock all doors when the engine is stopped. Please remember to go into iDrive after the coding to set unlock to all doors instead of just the driver door.
That is for an F2x, F3x, F8x. F15's do not have fem_body ECU. |
10-22-2016, 05:48 PM | #2850 |
Rep 13
Hi all, i got two coding questions for the experts. My car is F15, I-level is F025-16-07-502.
1. Try to code A/C OFF_Memory under IHKA2 (per F15 coding cheat sheet). Under IHKA2 CAFD_000047D6_001_000_001, simply there is NO OFF_Memory option. What's the new name for my CAFD file? 2. Try to code Changing the # of Turn Signal Blinks under BDC_BODY 3068 BLINKZYKLEN_ANZAHL_TIPP, although changed werte=04, turn signal remains 3 blinks. Other coding options were Okay for me. Appreciate all experts help! |
10-22-2016, 09:11 PM | #2851 | |
Rep 8,364
Use 3000_5_5_16: nicht_aktiv → aktiv |
10-22-2016, 10:01 PM | #2852 | |
Rep 13
Do you know what the folder name is for "Remember Air Re-Circulation Setting from previous shutdown"? The issue is i could not find these two names. OFF_MEMORY ( i could not know it's under 3000_5_5_16) MEMORY_UMLUFT |
10-22-2016, 10:13 PM | #2853 | |
Rep 8,364
Check storage info to confirm. 3000_0_0_4 = aktiv. |
BMW335is0.00 |
10-22-2016, 10:36 PM | #2854 | ||
Rep 13
10-23-2016, 08:31 AM | #2855 |
Rep 591
I'm trying to enable this feature by default below is my current setting for the x5 40e that I have. Do I need to change the three of them? Having it just like it shows is not getting me the desired outcome.
View post on imgur.com |
10-23-2016, 04:05 PM | #2856 |
Rep 591
10-23-2016, 04:24 PM | #2857 |
Rep 40,774
Neither is possible. There is no Coding to affect Auto-Hold.
10-23-2016, 04:28 PM | #2858 |
Rep 591
Much appreciated. What's the coding for the auto start stop is for then when that is no longer an option to control?
10-25-2016, 04:10 PM | #2859 |
Rep 4
Issue with re-coding anti-dazzle / glare-free high beams
I’m hoping to have better luck by posting in this thread. It's a duplicate posting from Bimmerfest but I really want this to work and I'm also puzzled by this weird behavior.
I'd also like to Thank Almaretto for his help. I have been trying to re-code the anti-dazzle / glare-free high beams on my 2016 F15 (X5 40e – Manuf. July 2016) with Lightning Package. I’m using E-Sys v.3.27.1 and PSdZData_Lite v.59.4. I followed Appendix 2 of the most recent guide (January 2016) “How to Enable the GFHB Functionality of Adaptive LED Headlights on US F15/F16/F85/F86 Cars” and coded all 70+ parameters on both FLE modules (after editing FA/VO & VO coding BDC_BODY, KAFAS2, and both FLE). The issue that I have is with the passenger-side FLE (FLE-44) which read the following values even after FDL coding: Schlechtwetter_C1_Idx: UNKNOWN = 03 01 01 01 02 03 01 01 01 01 Schlechtwetter_C2_Idx: UNKNOWN = 03 01 01 01 02 03 01 01 01 01 Stadt_V_Idx: UNKNOWN = 12 01 01 01 02 03 01 01 05 01 H_8_Autobahn_E3_Idx: UNKNOWN = 03 01 01 01 03 03 01 01 01 01 H_6_Autobahn_E2_Idx: UNKNOWN = 03 01 01 01 03 03 01 01 01 01 H_5_Autobahn_E1_Idx: UNKNOWN = 03 01 01 01 03 03 01 01 01 01 H_4_Autobahn_E_Idx: UNKNOWN = 03 01 01 01 03 03 01 01 01 01 H_plus4_Idx: UNKNOWN = 03 01 01 01 02 03 01 01 01 01 Blendfreies_Fernlicht_Idx: UNKNOWN = 0F 06 01 01 06 06 01 01 01 01 Compared to the Driver-side FLE (FLE-43) which read the following (CORRECT) values after FDL coding: Schlechtwetter_C1_Idx: F015Wert = 00 01 01 01 02 03 01 01 01 01 Schlechtwetter_C2_Idx: F015Wert = 00 01 01 01 02 03 01 01 01 01 Stadt_V_Idx: F015Wert = 04 01 01 01 02 03 01 01 05 01 H_8_Autobahn_E3_Idx: F015Wert = 03 01 01 01 02 03 01 01 01 01 H_6_Autobahn_E2_Idx: F015Wert = 03 01 01 01 02 03 01 01 01 01 H_5_Autobahn_E1_Idx: F015Wert = 03 01 01 01 02 03 01 01 01 01 H_4_Autobahn_E_Idx: F015Wert = 03 01 01 01 02 03 01 01 01 01 H_plus4_Idx: F015Wert = 04 01 01 01 02 03 01 01 01 01 Blendfreies_Fernlicht_Idx: F015Wert = 01 06 01 01 06 06 01 01 01 01 All other 70+ values that needed to be changed in both FLE are coded without any issues. Other 2015-2016 F15 owners have been successful in re-coding this feature and my case seems to be unique. I have my FA and SVT files for anyone who can help me solve this mystery. Thank! |
10-27-2016, 07:11 PM | #2860 |
Rep 1,746
Hi guys,
I just picked up my X5 from service, and all my codes are gone. Interestingly, although I didn't pay attention, the warning screen did not show up, rest is gone. shawnsheridan, Has anything changed in last 18 months or so in coding? That was the last I coded. I don't miss most of my codes but mirror fold and 5 blink turn signal was very convenient. Should I check the current version before attempting to code? Thanks.
