01-28-2017, 11:34 AM | #3125 | |
Rep 3,803
Give me 15 minutes to get home, and grab the sheet I used. |
01-28-2017, 12:11 PM | #3126 | |
Rep 3,803
01-28-2017, 12:12 PM | #3127 |
Rep 3,803
Now... what I cannot find is opening the mirrors with key fob (unlocking doors).
I have it set, without delay, to fold mirrors when locking with key fob. If anyone can help me with that, I'd appreciate it. |
01-28-2017, 12:39 PM | #3128 |
Rep 159
Thanks for that. I could not find it under HKFM2 (the 2017 changed all of them to have a 2 on the end). Tried a search for all those under the main HKFM2 directory thinking they may have moved it from 3010.
01-28-2017, 12:41 PM | #3129 | |
Rep 3,803
01-28-2017, 01:31 PM | #3130 |
Rep 591
Hello, I am trying to code my fog lights to be on with DRLs on my F15, can you please help? I could not find it on the coding sheet or by searching through the forum. Again, I do not want the foglight on at night unless I click the button BUT I would like for the fog lights to be ON with DRL.
Almaretto opasha shawnsheridan |
01-28-2017, 01:41 PM | #3131 | |
Rep 40,774
01-28-2017, 01:47 PM | #3132 | |
Rep 159
BD_BODY 3038 NSW_AUS_BEI_FL change from aktiv to nicht_aktiv |
HZX540e373.50 |
01-28-2017, 01:48 PM | #3133 |
Rep 40,774
That is not Fogs as DRL though, that is Fogs with High Beams.
01-28-2017, 01:57 PM | #3134 |
Rep 591
True, I already coded that a while back now fogs with DRL
01-28-2017, 01:58 PM | #3135 | ||
Rep 591
01-28-2017, 02:17 PM | #3136 | |
Rep 8,364
'17 F15 get HKFM2. You need to use rockerswitch and keyfob button type in new module. |
01-29-2017, 05:05 PM | #3137 |
Rep 102
reverse surround view
[QUOTE=Almaretto;21162975]I have not found any code for this feature. It seems to be firmware based. My F010 always defaults to last used setting (rear-view or top-view), but my F015 (after last I-Step update) now always reverts to rear view.
Do you think if one deactivated rear view, the car would go to surround? Is there a way to deactivate rear view? thanks |
01-29-2017, 06:16 PM | #3138 |
Rep 3,803
Maybe I missed this one, Does anyone have the info to code off the horn beeping, when locking the car, with it running (like running into a 7/11) without shutting it off.
Thanks |
01-29-2017, 07:51 PM | #3139 |
Rep 40,774
BDC => VAM_HORN_AT_SECURE = aktiv
Almaretto2374.00 |
01-29-2017, 08:17 PM | #3140 |
Rep 3,803
Thanks man. I appreciate it.
01-29-2017, 10:35 PM | #3141 |
Rep 159
Close trunk via Keyfob/Inside button HKFM 3010 SCH_FBD SCH_TOEHKI TASTER_FBD I tried searching for all those codes under 3010 and then just under HKFM, could not find them. 2017 f15
Searched for rocker switch and keyfob. Found these but am not sure what to do. [IMG][/IMG] [IMG][/IMG] DVD IN MOTION Also went to finish HU_NBT2 3000 SPEEDLOCK_X_KMH_MAX and SPEEDLOCK_X_KMH_MIN Changed them both to werte=ff but noticed they were both nicht_aktiv. Is that correct? |
01-29-2017, 10:41 PM | #3142 | |
Rep 40,774
HU_NBT2 => VIDEO_FRONT_LOCKED => nicht_aktiv HU_NBT2 => VIDEO_SPEEDLOCK_CONDITION => none HU_NBT2 => SPEEDLOCK_CAR_STANDSTILL => none HU_NBT2 => SPEEDLOCK_X_KMH_MAX => Werte = FF HU_NBT2 => SPEEDLOCK_X_KMH_MIN => Werte = FF HU_NBT2 => SPEEDLOCK_SPEEDVALUE_MIN => nicht_aktiv for ID4 or 1F for ID5 HU_NBT2 => SPEEDLOCK_SPEEDVALUE_MAX => nicht_aktiv for ID4 or 3F for ID5 ( 63 kmh or 39 mph)
01-30-2017, 02:14 AM | #3143 | |
Rep 8,364
Correct; you will not find the same CAFD_000007C8 funktion names in CAFD_00002098. At a minimum, you need one change for rockerswitch and one for keyfob; they are both button type (change from open only to open and close). If you still cannot find them, send me a message and I can look them up tomorrow. |
01-30-2017, 12:47 PM | #3144 | |
Rep 159
Any ideas on the rocker switch and keyfob settings? |
01-30-2017, 12:48 PM | #3145 |
Rep 40,774
None. Sorry.
