      07-12-2021, 09:28 PM   #89
RED_Y_
Drives: 2014 X5 3.5d
Originally Posted by virtualbong View Post
Agreed, at this point, I'd rather not self diagnose when I am not a professional mechanic. I will have to just lean on them to do their thing and hope they find the culprit.
In the meantime, I am already imagining my wallet being drained...
It should not be that bad, worst case scenario you can always get a kit like this:
https://www.fcpeuro.com/products/bmw...-31126864821kt
And just do it all in one seating, do the alignment and forget about it for another 75K miles.
      07-13-2021, 07:51 AM   #90
virtualbong
virtualbong's Avatar
103
Drives: 2015 BMW X5 MSport
So they couldn't see me today so I need to wait until Thursday. I'm wondering if I should just go and purchase it and tell them to install on Thursday when they can take me in.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST
| 1998 Acura Integra (Black/Black) - PAST
      07-24-2021, 09:40 PM   #91
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
Originally Posted by tlow98 View Post
Clunks can also be worn strut mount bearings. After 100k they’re questionable and if youre in there consider worth the time/money to replace them
You're correct and I thought this was my issue at first. Said f it, and installed BC Racing coilovers but the sound was still there so in my case it wasn't any to do with the strut mounts.
      07-27-2021, 08:42 PM   #92
dave617
Drives: BMW X5 F15
Originally Posted by dave617 View Post
I did the lowers (#13). Same ones that are in the FCP Euro link above. Any ideas?
May be a tension strut (#8)? Ask you shop to lift the car and check closely all the bushings.
Thrust arm bushings were the problem. Ended up replacing the arms and bushings. Now drives great and noise is gone. Thanks for the help.
      07-27-2021, 08:51 PM   #93
RED_Y_
Glad you got it fixed, I still haven't got mine into the shop, they are busy and funniest part is that noise is almost gone all the sudden. I am very confused, got appointment scheduled on Thursday.
      07-27-2021, 10:04 PM   #94
virtualbong
103
Here is my update. So I had the thrust arm bushings on both sides replaced by my shop but I still had the clunking noise. My shop was finally able to take a look at my X5 and they came back stating that I needed to replace my driver side strut and that I might as well replace both sides. Since I had to go out of town with the X5 that weekend and they were unavailable anyways, I took the car back. I now barely hear or feel the issue. I am wondering if they somehow screwed me the first time and never changed it or maybe they didn't screw something tight. But it's definitely apparent that the clunking is not happening when I start driving 0-10 mph. I am going to keep looking out for it but I am going to not replace the struts unless I hear things again.
Note: I have trusted this shop for some time but it's way to coincidental that it stopped happening as soon as I brought it back to them to check things out. They didn't even charge me for the re-diagnosis.
      07-27-2021, 11:47 PM   #95
tlow98
Drives: 2009 E91, 2014 F15 x35i
Tough situation. Mostly, I like to trust people until proven otherwise. Definitely don't replace it until you hear it again, but stranger things have happened!
      07-28-2021, 09:32 PM   #96
virtualbong
103
Agreed, I would like to think the best of people and they have been good to me in the past so I will let this go as a big coincidence.
      07-29-2021, 02:43 PM   #97
RED_Y_
Just got a call from the shop, they are very surprised how did I get this far (73K miles) with these lower control arms, they have P/N which were mentioned in SIB and replaced by BMW under warranty. So replacing both sides and alignment, keeping fingers crossed this does the trick.
      07-30-2021, 06:25 AM   #98
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Update: replaced my front control arms w/lemforders, no alignment required.
Unfortunately, my driver's rear one is on the verge of needing replacement, but will require an alignment.....could not escape it after all!
      08-17-2021, 05:39 PM   #99
Gkacmaz
Drives: BMW X5 50i
Update on mine. Changed the stabilizer bar links, my car is completely noise free!
What else has been done
- upper and lower control arms on each side
I wish I had bought the whole control arm kit from FCP Euro instead of getting them individually.
For anyone :
Changing the control arms and stabilizer bar link is pretty easy and doesn't require any special tools. You can save yourself some serious money by going DIY
      08-17-2021, 08:39 PM   #100
randrews15
randrews15's Avatar
Drives: 2012 E93 M3 Le Mans Blue
I had a E70 X5 until we got a F15 that had suspension wonder at around 50k miles. It had the sport suspension that was known to eat up control arms. I did a total refresh of control arms and it solved the problem. While it wasn't cheap, I went with Lemforder from FCP Euro for their warranty. I had to warranty the FCA after about 20k miles as they were leaking fluid again. A heavy vehicle like this takes it toll on control arms. It's the price we all pay for these vehicles.
