      08-03-2022, 02:26 PM   #23
Chicane_S54
Chicane_S54's Avatar
37
Drives: F15 X5
Exclamation
Originally Posted by crystalworks View Post
How are there no pictures/specs of everything posted yet? Any hardware, wheels, tires, etc could be influencing this.
We went from 19's to 20's (with used tires) and required no TC calibration. That is until the rears wore down for about 6 months and then we started getting a "tug" or "thud" as you describe. The TC wants <1% difference in rolling diameter from front to back. New tires installed and no more problems from the TC.
As a matter of good maintenance however you could service your TC fluid (we did later) and reset the calibrations using a Foxwell NT530 or ISTA. The fluid that came out @ 85000 miles was not burnt, but it wasn't great either.
I'm not saying that you are not 100% correct because I think you are but there aren't 1000 miles on these tires with no appreciable wear or wear spots on the tires. Right now I need the TC calibration steps with ISTA. I would rather change the TC fluid and calibrate the TC before I drop $1300 for new tires.
      08-03-2022, 06:19 PM   #24
crystalworks
crystalworks's Avatar
522
Drives: Many BMW's
I hear that. Just get an NT530. It costs ~$150 and does 95% of the things ISTA will do. Way handier to carry on trips and things. I use it more frequently than anything else. Though I do have Carly as well (I have owned 20+ Bimmers... so have an extensive diagnostic tool cabinet).
That said, ISTA is not hard to use once it's running. I use it with an ICOM though which adds expense. Good luck.
      08-03-2022, 07:00 PM   #25
Chicane_S54
37
Drives: F15 X5
Question
I have ISTA, I don't need to purchase a different unit. Do you know the ISTA procedure or no?
      08-04-2022, 10:11 AM   #26
crystalworks
522
Drives: Many BMW's
Oh you have ISTA running.
I'll run a scan on my X5 today to get the menu tree if I have some time. It'll be under service functions, possibly under drivetrain or traction control, but I'll see what I can find.
      08-04-2022, 10:41 AM   #27
Chicane_S54
37
Drives: F15 X5
Exclamation
Thanks.
      08-04-2022, 10:58 AM   #28
Chicane_S54
37
Drives: F15 X5
Originally Posted by ///d View Post
The overall diameter of the fronts vs rears need to be within 1% of each other. If you get outside that 1% then you can run into issues with the traction and stability system thinking a wheel is slipping because of differences in rotating speeds.
That doesn't even make sense for 28 inch overall width on a 20" wheel/tire that would be .28 or approximately 1/4 of an inch diff. My OEMs are worn all to shit with at least that much diff and they give me zero drive-train issues.
Not to mention the vehicle hasn't kicked a single DSC or ABS code.
      08-04-2022, 11:50 PM   #29
crystalworks
522
Drives: Many BMW's
He's right. Anything outside 1% will cause issues. Not necessarily trigger a code either. That was exactly what I experienced when my rears wore out more quickly than the fronts (OE 20" tire sizes). What tire sizes are you running on the BBS wheels?
I scanned the truck today to get the service tree. It goes as follows in ISTA-d: Vehicle Management: Service Functions: Power train: Transmission contro unit VTG: Oil change. That will initiate the adaptation service plan. I'll post a picture tomorrow.
Edit: Here's the picture for service location
      08-07-2022, 09:43 AM   #30
Chicane_S54
37
Drives: F15 X5
Attachment 2949318
BBS SX's with 275/40R20 Continentals
So that boils down to approximately 1/4" of wear. Could it be the 20" wheels are more sensitive to this difference in wear than the 19's? It looks as though I am looking at getting a new set of tires. What size tires are you running on your 20's.
Are your 20's staggered? When I go to Tire rack when I select tires by vehicle every 20" setup is a staggered setup.
      08-07-2022, 11:12 AM   #31
Clifton
Clifton's Avatar
Drives: Cars with tires
May be worth running the Transfer case calibration (VTG control unit) before buying new tires.
I’m running 275/40R20 (F) and 315/35R20 (R) and recalibrated shortly after replacing them 5k miles ago.
Worth noting, Tire Rack can shave tires to match tread depth of existing tires if aren’t replacing all 4.
      08-07-2022, 11:20 AM   #32
Chicane_S54
37
Drives: F15 X5
Exclamation
Thanks. That hardly seems worth sending my existing tires to Tire Rack better to find a local tire place that can do the same.
      08-07-2022, 12:55 PM   #33
Clifton
Clifton's Avatar
Not sure that you read my post correctly. You mentioned buying new tires and looking at Tire Rack offerings. My post was intended to make you aware of that service if you were going to proceed with purchasing from them. Never implied mailing them back.
Good luck!
Regards,
Clifton
      08-07-2022, 02:33 PM   #34
crystalworks
522
Drives: Many BMW's
I've got factory sized tires on staggered style 597 20's (275/40R20 (F) and 315/35R20 (R)) with Toyo Proxes STIII on them installed new in January I think it was.
I had a set of DWS' on them prior that had 30k miles+ on them when the tugging from the transfer case started. As soon as the Toyos went on the problem went away.
FWIW, I never had problems with tugging on the factory 19's and Bridgestone RFs. It could very well be possible that the 20's thinner sidewall wears the rears at a rate that makes the front to rear unhappy.
sukhk5272169.50
      08-07-2022, 07:27 PM   #35
Chicane_S54
37
Drives: F15 X5
That is what I am thinking as well. The 20's seem to be a staggered setup I don't know if you can run 20's squared. What is the width of your rear wheels?
      08-08-2022, 11:02 AM   #36
crystalworks
522
Drives: Many BMW's
20x10 F and 20x11 R, wheels were originally from an X6 F16.
In theory, you can run any wheel tire combo out there with a near identical diameter. Otherwise the 19's would have issues as they are not staggered.
I can see how this is frustrating. All things point to this being able to work without issue. Yet here you are. At this point... I'd try and service the transfer case fluid and run the calibration. Because why not. At any rate, I'm rooting for you.
      08-08-2022, 11:10 AM   #37
Chicane_S54
37
Drives: F15 X5
Question
Will definitely do that this weekend. But I don't think anyone is running a 20" squared setup. These BBS SX's are 20 x 9, it may very well be that the drivetrain is too sensitive to run that squared setup. What fluid do you use for the transfer case?
      08-08-2022, 11:34 AM   #38
///d
///d's Avatar
Drives: F15 35d M Sport
It doesnt matter if you have a 10" tall tire or a 100" tall tire, as long as all four tires are within 1% of eachother the electronics in the car "should" not care (other than your speedo being off). It is simply taking the rotational speed of each corner and comparing them. When one tire has a different overall diameter it will rotate a little slower or faster than the others. THAT is what causes the car to get upset and start triggering traction systems. The car does not know if you have 19's, 20's 22's, all it knows is the rotational speed at each corner.
It may not trigger any codes because it doesn't think there is anything wrong with the system, it just thinks there is wheel slip.
Yes you can run 20's squared. I do and have for years with M Adaptive and DHP, always active, with no issues.
Some tire makes are spot on for their sizes, and some are not. I have seen a lot of people on these forums and in FB groups have issues with brand new conti's that are supposed to be the correct sizes to maintain that 1%. I have never ran conti's because of this.
An old room mate of mine used to manage a Discount Tire. He would often talk about how he could take two tires, same make model and size, and one would be taller than the other once mounted, even with the same lot numbers.
You can try the transfer case calibration and service, it may help, it may not. Won't know until you try.
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread
      08-09-2022, 11:48 AM   #39
Chicane_S54
37
Drives: F15 X5
Exclamation
I will re-calibrate the TR but what it looks like is I need some new tires.
      08-09-2022, 01:01 PM   #40
///d
///d's Avatar
If the recalibrate doesn't work you may be able to work with the tire shop and work an exchange if you haven't put many miles on them, especially since you can show other setups do not cause issue.
