11-20-2023, 04:41 PM | #1 |
Rep 10
F15 X5 Thrust Arm worn bushings
Just curious to know if there is a way to replace ball joints on the thrust arms ?
Did anyone tried replacing the ball joints on the thrust arms/or lower control arms on F15 BMW X5 Sdrive 35I ? There are options for replacing bushings but what about ball joints ? What if ball joints are bad ? Do we have to replace whole thrust arm ? |
11-20-2023, 11:18 PM | #5 |
Rep 661
That ball joint does not have accessible C-clip window for servicing. You're SOL, replace the whole arm and don't skimp on this. If you get that garbage no-brand replacement from eBay, you'll look to do the job again in few months. FCPeuro is a good source, and they have lifetime program behind it. Go for it.
11-21-2023, 06:53 PM | #6 |
Rep 270
Agreed, gotta replace them. You can get them (Lemforder) for a good price (look around) and the job is two hours max shop time so not horribly costly. Had a clunky front left and am so happy I had them done this summer…quiet again!
11-21-2023, 10:21 PM | #8 | |
Rep 10
