05-06-2017, 11:52 AM | #3411 |
Rep 8,364
05-06-2017, 12:17 PM | #3412 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Sorry I ment if there are more options or the E- Sys Premium is the way to go?
I'm having trouble typing the Location path on the TokenMaster pop up window, the black window that pops up after you install the E-Sys software, I did choose the car type and the memory to use, but can't type the location path on the first row.... Last edited by motex; 05-06-2017 at 12:25 PM.. |
05-06-2017, 02:26 PM | #3413 | |
Rep 18
I found these 2 videos to be extremely helpful and informative ESYS F15 Coding Instructions FA & VO Coding |
05-06-2017, 02:44 PM | #3414 |
524
Rep 2,146
Thanks a lot will check those links
05-06-2017, 05:39 PM | #3415 | |
Rep 8,364
If you choose the ladder, there are options, but Premium or Pro Launcher is the only one I would recommend. Latest launcher does not ask you to type in location. All you need is to type pin twice. Fxx, Ixx, & Gxx Series Coding: Latest Software, Guides, and Tips Once setup, this is what I would suggest using: Coding Made Easier (Cheat Codes in E-Sys Launcher) |
05-07-2017, 12:05 PM | #3416 | |
524
Rep 2,146
"In lieu of using an external charger, the car can instead be coded with the engine running, in order to maintain proper voltage, which is acceptable for coding all ECU's EXCEPT the DME (Digital Motor Electronics) ECU or DDE (Digital Diesel Electronics) ECU. The DME/DDE are typically not coded anyway, so this ECU limitation is generally not an issue." I do have a battery maintainer but not sure if it will hold the voltage needed if the engine is OFF, I would love to do it with engine ON if the text quoted above doesn't affect my specific car Any tips will be appreciated
....Life is too short to drive boring cars
05-07-2017, 01:05 PM | #3417 | |
Rep 8,364
You should be running engine to maintain battery voltage during coding, except if coding DME/DDE Engine ECU. Battery tenders are not the same thing as programming PSU's, which output 13.4+ V and 50-70+ amps. You can also code offline, to minimize the time needed to be physically connected to vehicle with engine running. |
05-07-2017, 04:23 PM | #3418 | |
524
Rep 2,146
There is a link where to learn how to code offline? It sounds great to me because I can use it as a practice without any time stress |
05-07-2017, 11:38 PM | #3419 | |
Rep 8,364
You only have to be connected when "Read," "Read Coding Data," "Code," or "Code FDL." Otherwise, you can do the same things disconnected. |
05-08-2017, 06:45 AM | #3420 |
Rep 4
does anyone know why this time round it says I need an Activation Code from TokenMaster? whereas when I coded last time (around 8 months ago), I wasn't prompted for this? Is there anyway to escape the prompt?
I have emailed him and its been over 8 days without a reply |
05-08-2017, 02:59 PM | #3422 | |
Rep 8,364
No I, but many others.
05-08-2017, 10:52 PM | #3423 |
Rep 61
I recently got the BimmerCode iPhone app and the vGate 2 wifi adapter, I am eager to try it out but will not have the opportunity to do so anytime soon...
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package |
05-09-2017, 07:38 PM | #3425 | |
Rep 8,364
05-09-2017, 10:37 PM | #3426 |
Rep 182
I've used it for simple stuff and it's fine, like mirror folding, losing the confirm screens, changing the startup screens,etc...
2015 F15 X5 3.5i M-Sport SG
Past Rides: 2001 E39 Dinan 5 - 2006 E63 M6 - 2007 335i E93 - 2007 X5 E70 4.8i - 2010 X5 E70 3.0i 2016 428ix M-Sport Gran Coupe - 2014 E71 X6M |
05-10-2017, 10:24 PM | #3427 |
Rep 178
Hi all,
I have a '17 X5 with ID5 that I coded to ID 6 light earlier tonight. Does anybody know where I need to go to change the Vehicle logo to something resembling an X5? Right now, it looks like a 5-series. Also, just to confirm, I should not be coding to ID6 --- just ID6-light... correct? Lastly - unrelated question, does anybody recall where the setting is to code auto-high beams to 'always on' on the F15? I have it coded that way for my F10, but somehow missed the setting on the F15. Thanks! |
05-11-2017, 01:03 PM | #3428 | |
Rep 8,364
View post on imgur.com |
05-11-2017, 04:19 PM | #3430 |
Rep 178
Almaretto The car started the build process more recently than 2/27 -- that is the date we finalized the specs with my dealer... we took delivery on 3/17. I am not sure what S/W version I have --- can you remind me how to check? I've seen that screenshot that you posted above previously, but am not sure what setting I need to toggle in the car to make the X5 picture appear instead of the sedan pic that I see now.
janexus ID6light is working flawlessly on our X5 including the touch-screen. The 'only' downside --- and it is certainly not a deal-breaker --- is that the 'my vehicle' icon shows as a BMW sedan.. but this may be 'fixable' based on Almaretto's feedback. Personally, I prefer ID6L to ID5 and plan on keeping it as my front-end skin. Last edited by jrhav; 05-11-2017 at 04:33 PM.. |
05-11-2017, 06:39 PM | #3432 | |
Rep 8,364
