02-11-2018, 10:37 AM | #1 |
Rep 1,180
Which first? CF splitter or MPE?
Hi all,
Looking for opinions on which to go with first or at all? They are both around the same cost and I'm having a hard time deciding between going with the visual mod or the audible mod first. Anyone have both that would chose one over the other if they could only have one? Pros and Cons of either? My concerns with both: Splitter - Reduced front end clearance. Anyone taken before and after install measurements? - Having to drill in to the bumper. Non-reversible without either having holes in the bumper or having the have the holes filled and painted. - I also have clear bra installed that does wrap under the bumper. Am I going to have to remove it for the install? Anyone run in to this problem? MPE - I'm really not sure how loud it is as I've yet to witness one in person. Hoping I can find someone local that has one that I can meet up with. I've heard a few people mention it drones at cruising speed...Anyone have any video at cruising speed? - No performance gains for "Performance" exhaust Both are ridiculously overpriced, so that's a moot point TIA Last edited by CeeTeeX5; 02-11-2018 at 10:44 AM.. |
02-11-2018, 11:35 AM | #5 |
Rep 842
I like to do cosmetic things first to stand out from the other stock cars.
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
02-11-2018, 11:43 AM | #6 |
326
Rep 303
In regards to a few of your questions:
1. OEM CF splitter doesn’t reduce your ground clearance. It extends you a bit horizontally, but does not make you lower. 2. I suspect you would have to remove part of you paint protection film so the Betalink can properly adhere to the front bumper. 3. MPE sounds good but really isn’t too loud. I never noticed any drone whatsoever. Last edited by HomeIn2; 02-11-2018 at 12:56 PM.. |
CeeTeeX5936.00 |
02-11-2018, 11:57 AM | #7 |
Rep 714
Drives: BMW X5 M Sport - G05
I drove one with the MPE and unfortunately couldn’t tell a huge difference. However, I’m probably going to order one in a month or two.
02-11-2018, 12:04 PM | #8 |
Rep 102
MPE. The sound is pure joy to my ears. When i got my car first thing i ordered while picking up was MPPK and then wanted MPE. Last month got that put on.
Its not super loud at all and inside the cabin sound is not annoying at all. Only time its loud is on initial start up. the rumble is very nice on low rpm's. i do have a video that i made between M Sport exhaust note with MPPK and then with MPE(but MPE is just on idle not while driving). I got mine from here by the vendors. I paid $1270 (exhaust, finishers and shipping). I was not going to pay BMW $1700+ plus labor (set $215+tax). If you PM me, i can share where i got mine. |
CeeTeeX5936.00 |
02-11-2018, 12:13 PM | #9 |
Rep 102
Also, if you do end up going down the road of MPE, i recommend to get VHT black glass and clear gloss paint(parts store, i got mine from auto zone) and paint the tips before installing if you are interested in making them black.
02-11-2018, 12:30 PM | #10 |
Rep 2,194
I’ve never experienced the MPE w/out the MPPK, but paired with the MPPK it sounds great! Especially in Sport/+ modes, mine even has a great note and pops in Eco (I use this mode in traffic).
Do you plan on getting MPPK and/or a piggy back then? If so, I’d say get the MPE and wait on the splitter. If you don’t have or plan to tune, I’d get the splitter. |
CeeTeeX5936.00 |
02-11-2018, 01:17 PM | #11 | |
Rep 25
sbinshihon684.50 |
02-11-2018, 01:46 PM | #12 |
Rep 129
Depends what you want to do. Personally I would do the MPE first because it's something you will hear all the time when you drive.
The splitter doesn't really decrease ground clearance much if at all. You should not hit anything and if you do, it would have likely damaged the bumper anyway. I have a full body wrap on mine with ceramic and so it was harder to get the 3m tape to stick well even after the prep. I took the car over 100 just to be sure and I was paranoid so I took the 3M off and used betalink instead. My wife who is not a car buff feels the increased stability at speed in turns and actually complained the car felt weird without the lip when I had it off in between to do the betalink. |
CeeTeeX5936.00 |
02-11-2018, 02:21 PM | #13 | ||||
Rep 1,180
Thanks all for the feedback so far. |
02-11-2018, 02:47 PM | #14 |
Rep 129
It's a clear paint protection wrap, similar to Xpel. They used STek Dyno Shield I believe. I placed the splitter on after the car was wrapped, but had the splitter coated with the ceramic since it was easy to do
2023 CSL FBG/powered buckets - 2022 X5m BSM/Sakhir - 2020 M2c HS/Blue -
2007 M5 BSM/Black - 2004 M3 LSB/LSB - 2001 M5 Carbon Black/Imola |
CeeTeeX5936.00 |
02-11-2018, 03:18 PM | #15 |
Rep 1,180
got it, ok. So I could just mount it on top of the ppf if I wanted to.
02-11-2018, 03:33 PM | #16 |
Rep 129
But you have to sand it still to make it rough otherwise it's too slick
02-11-2018, 07:05 PM | #17 | |
Rep 674
The MPE is okay but seriously sometimes you wont feel its there, let alone someone else. |
02-12-2018, 01:52 PM | #18 |
Rep 1,180
How well is the CF splitter holding up for you guys? Are you seeing many dings and rock chips?
I am thinking about going the RW Carbon route. I know the fitment may not be 100% perfect but it's also about half the cost and I won't feel too bad if it gets a bit banged up.
2018 X5 35i M-Sport
02-12-2018, 09:37 PM | #19 | |
Rep 674
So, Definitely get the OEM part. |
CeeTeeX5936.00 |
02-13-2018, 09:08 AM | #21 |
Rep 11,136
You already got bigger wheels, right? If so, do the splitter. I don't think the splitter in combination with 20" wheels looks right.
02-13-2018, 10:09 AM | #22 | |
Rep 5,066
IMO I'd go with the MPE.
