10-19-2021, 02:43 PM | #23 |
Rep 1,544
Its just telling you its time for another project...
F90 maybe?
classic_erik2808.50 |
10-19-2021, 06:44 PM | #24 |
Rep 1,859
Drives: 23' X7 40i M Sport
Haha yes sir. Only a matter of time!
10-20-2021, 02:03 AM | #25 |
Rep 611
How deep are you sanding, and are you cleaning it after sanding? And what are you using for cleaning?
Most of the time when I see paint do that, it either wasn't sanded enough or cleaned well enough to remove oils and give the primer something to grab onto, or its the wrong combination of primer/paint/clear. Since these are all enamel based and its happening over time I suspect the issue is with prep. If it were the wrong types of paints/primers you would see bubbling happen immediately or while drying. I would pay a little extra attention to your prep. Best way I can explain sanding is make sure there is no shiny left over from previous coatings, and be sure to use a cleaner that doesn't leave behind any oils. It could also just be the paint. I always use Rustoleum paints and I've never had issues. I have also never "baked" high temp paints and I have no bubbling or peeling on exhausts or engines. When I did my tips I: sanded: cleaned with mineral spirits sanded (forget the grit I used, but nothing too harsh that leaves lines) ensure no "shiny" spots are left cleaned with mineral spirits let dry for an hour primer: 3 light coats, 1 hr between each coat let dry overnight paint: 3 light coats and one final medium coat (not too heavy to cause runs), 1 hr between coats let dry overnight clear: 3 light coats, 1 medium coats (again, not too heavy to cause runs), 1 hr between coats let dry over night Test surfaces before each application with fingernail. If its hard to the touch, then you're good to go on. If its still soft or tacky to the touch, let it dry more. Kept the garage around 65deg (was in the winter). |
10-22-2021, 05:35 PM | #26 | |
Rep 1,859
10-22-2021, 05:56 PM | #27 | ||
Rep 2,633
https://www.ebay.com/itm/Stainless-S...-127632-2357-0 I was worried they would not cover the tips. But so far looks fine. Had it for a month and seems easy to remove and replace if needed. |
10-23-2021, 01:22 AM | #28 | |
Rep 611
I want dual rounds for each side, but no one makes anything specific to the F15 except Supersprint, and its $800 just for tips which I find a little ridiculous. I'm likely going to end up caving and getting them eventually. I have Amazon universal tips now but they don't fit the curvature of the rear bumper and it really bothers me. AC used to have great looking tips, but they changed the design and what they offer now is hideous IMO. |
10-23-2021, 03:29 AM | #29 | |
Rep 297
10-23-2021, 12:38 PM | #30 |
Rep 58
They make 900 degree stuff for grills. I've used that on cars I've tracked and I haven't had a problem. Try that. 550 degrees is kind of low.
2019 X5 XDrive50 - Stock for now
2013 Viper GTS- DSC/Tractive coil overs, Sway bars, big aero, carbon stuff, exhaust 2014 BRZ - Race/track car. Cage, gutted, aero, big brakes, race prepped, etc. 2011 Lexus GX (for sale soon) |
10-23-2021, 03:32 PM | #31 | ||
Rep 2,633
Here are some pictures that I zoomed in. |
10-23-2021, 09:25 PM | #33 |
Rep 483
I wonder how the double sided tape will hold up on those covers.
blackoutF15350.50 ggunn9160.00 |
10-24-2021, 12:11 PM | #34 |
Rep 942
Drives: 2016 BMW X5
Should be fine. The heat is def a consideration, but the double sides tape is pretty reliable (at least from 3M). Had a front lip on with just screws and 3M tape and didn't budge. And then consider that there is almost no wind pressure or gravitational pressure etc. pulling at the covers.
10-24-2021, 03:57 PM | #35 | |
Rep 2,633
I was skeptical at first as well, but at $50 it wasn't a big risk. There are of course expensive carbon fiber tips as well that go all the way back, but may not be worth the price. https://www.ebay.com/itm/For-BMW-X5-...-127632-2357-0 |
10-24-2021, 04:00 PM | #36 | ||
Rep 942
Drives: 2016 BMW X5
10-27-2021, 07:36 PM | #37 |
Rep 118
I painted the tips on my diesel (M-sport) almost 3 years ago. I had the rear bumper off to put on Stealth Hitch, so perfect time to undertake this task. I sanded it to roughen up the smooth chrome finish. No primer. I painted it with a few layers of the VHT "roll bar and chassis" paint as was mentioned in one of the above posts. It is still perfect to this day. No chipping, fading, or cracking.
10-27-2021, 09:35 PM | #38 | |
Rep 942
Drives: 2016 BMW X5
10-27-2021, 11:25 PM | #39 | |
Rep 3,647
I'm OEM all the way, I hate cheap eBay crap with a passion, but I gotta admit I'm a bit intrigued by these tips |
ggunn9160.00 |
10-28-2021, 12:56 AM | #40 | ||
Rep 611
I live in MN. We see some of the harshest salt covered roads there are and my tips and kidneys have survived fine. And mine have also survived blizzard trips through the mountains as well. I also painted my E90 kidneys the same way I mentioned above and those lasted the 4 years before I sold the car. They did get some chips as I used typical shelf bought clear though which I don't recommend for anything that may see abuse as it doesn't harden like automotive clear does. For those items I usually got to an autobody and paint store and get an aerosol can made of automotive clear with hardening mixture. It has a thing on the bottom that you pop and it releases a hardener into the can, and you have 24 hours to use it. Once it dries you can sand a polish just like automotive paints, or you can leave it raw. I've used this on a few different things and they have worked out great. I didn't use this on the tips though, but so far so good. One thing I have noticed is gloss paints are harder to work with and I've had more gloss paints bubble and react funny vs semi gloss and matte. I'm not one for shiny things so now I usually use a semi gloss paint and a matte clear. Not sure if that has contributed to my success or not. |
jmack1231300.50 |
10-30-2021, 06:26 AM | #41 |
Rep 48
I painted but had some peeling after a while, so I put these on over the paint about six months ago. They've worked great so far. I went through an automatic car wash with them for the first time earlier this week and they are still firmly attached.
jiggz2141.00 |
10-31-2021, 12:35 PM | #42 | |
Rep 118
I make several ski trips to Tahoe each year, so that's about the extent of cold weather for the tips. No peeling or bubbling at all. Can't speak for durability in real winter climate tho... Good luck! |
11-01-2021, 12:27 AM | #43 |
Rep 611
I lose my damn rear wiper blade from the dryer every time I go through a car wash.
01-16-2022, 06:59 PM | #44 | |
Rep 11
FCX5, how are those tips holding for you? I got similar to yours from Amazon (may be the same factory in China ). I have not installed them yet. I am wondering if that adhesive tape is sufficient? Also how long are yours? Mine are 49mm +/- 1mm and seem ok. The ones I got were super cheap but, a bit wavy on the top and the bottom (that may be the reason for discount). I tried “dry” fit one and it fits like a glove. YIWANG Black Stainless Steel Tail Throat Vent Decorative Car Accessories For BMW X5 F15 X6 F16 2014-2019(Suitable For M Sports Version) https://www.amazon.com/dp/B096JQVD3N...ing=UTF8&psc=1 |
