06-23-2017, 07:31 PM | #1 |
Rep 142
F16 X6 M-sport, M - performance brakes, worth the change?
To all,
I took my X6 50i to Road America for a track day and am now looking at the M-performance brake package. I drove the X6 hard, as hard as i could, i didn't warp the rotors, but i was worried i might. My next track will be Brainerd Raceway and i really want to ask if anybody has done this mod and what your thoughts were. I don't care about the cost, it's the experience of pushing that vehicle into that corner as fast as you can, braking and not cooking your brakes. I've read all about brake dust, don't care. I will probably learn to change out the pads for better track pads. The X6 might not be the best track vehicle but I had an absolute ball at Road America and I want more. An M4 is the next vehicle. Thanks for your advice. KP |
06-23-2017, 09:44 PM | #2 |
Rep 18,712
I personally would do Brembo if you are serious.
Because the MPBK only change the front and just bigger rotor on the rear. While the Brembo are 6 piston front and 4 piston rear with real floating rotor. I had them on my F15 X5 sDrive35i and I tracked it once with the Brembo, very impressive stopping power for this big car.
04-30-2018, 05:12 PM | #3 | |
Rep 272
Anyone else do this upgrade? Duke
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) |
04-30-2018, 05:23 PM | #4 | |
Rep 1,092
05-01-2018, 12:26 PM | #5 | |
Rep 18,712
I used 405 front and 380 rear. I am not sure if it will fit the 19", when I used it on the stock 20", it is a tight fit already. You may want to call Brembo to check with them directly.
05-01-2018, 04:12 PM | #7 | |
Rep 272
295mm front rotor 285mm rears? Thanks. Duke
Duke
05-01-2018, 04:26 PM | #8 |
Rep 7,160
M performance is the 4 pot. 395 front 385 rear
05-01-2018, 04:38 PM | #9 | |
Rep 272
I was wrong. The brembos are 380mm rears. Thanks.
Duke
05-01-2018, 11:28 PM | #10 | |
Rep 272
Thanks. D
Duke
05-01-2018, 11:37 PM | #11 |
Rep 2,700
As Maverik259 stated M performance is the 4 pot. 395 front 385 rear. While performance wise Brembo is better I didnt think I needed it and Mperf looks better (with F85 rotors front and rear). I think my deal was pricy as I got F85 rotors in addition to the whole perf package (unless I sell OEM perf rotors - possibility as they are same for E70 X5M I believe).
05-02-2018, 06:55 AM | #12 | |
Rep 272
Duke
05-02-2018, 11:29 AM | #13 | |
Rep 18,712
I would get it again. But not if I am getting F95.
05-02-2018, 03:00 PM | #14 | ||
Rep 2,700
05-02-2018, 03:22 PM | #15 | |
Rep 272
Another question, did you need the longer hex attachment bolt m8x12 or was the shorter bolt the correct fit? Thanks. Duke
Duke
05-02-2018, 03:55 PM | #16 | |
Rep 844
http://f15.bimmerpost.com/forums/sho....php?t=1464952 If you are referring to the bolt that holds the rotor on the hub, new bolts are needed for the front, if desired. Also covered in that thread. |
05-02-2018, 04:05 PM | #17 |
Rep 7,160
I also don't think the F85 rotors are a true 2 piece rotor. But I've never seen them up close. Racing brake is another option. They make excellent components and give you the ability to replace the iron rings instead of buying a whole new 2 piece rotor. Only downside is they are a bit more expensive at the start.
05-02-2018, 04:24 PM | #18 |
Rep 272
Thanks all. I've been through that thread referenced above -- just want to be certain before the money dump. Trust but verify!
Duke
Duke
1230vani651.00 |
