01-20-2022, 02:59 PM | #1 |
109
Rep 385
Gasoline grade.
I pulled in behind a guy pumping gas into his 440ix and he was using 87 octane regular so I had to ask.
He’s been doing it for 37k miles alternating with 3 fills regular and 1 premium and said no issues. Car runs great. Surprised because premium at BJs was only .30 cents more and way cheaper than gas elsewhere. I know of I can’t fill up at either Costco or BJs I will use 89 mid grade. What grade are you guys getting? |
01-20-2022, 03:09 PM | #2 | |
Rep 3,652
Chevron 92 octane for me, that's the highest grade available in Washington where I live. |
01-20-2022, 04:35 PM | #3 |
Rep 2,516
Right, 3 years later this guy returns his 440x when the lease is over and some lucky person gets CPO with engine problems. This is how all these stories start about bad and unreliable BMWs or other premium cars. If you can't afford proper gas for the car go get Camry with 3.5 V6 and fill it up with 87 all day long. How much do you save on full tank doing this? $5? $6? Whopping $200 a year or so? 91 is the gas for N55, you can get it from Costco (they have high tier rated gas) or any other decent station. This is just plain stupid.
01-20-2022, 10:10 PM | #4 | |
Rep 144
The Libertine1237.00 |
01-21-2022, 02:44 AM | #5 | |
Rep 1,532
I went to school in Texas and had an e34 535 and e39 540 at the time. 87 was 1.89 premium was 2.59…the two cars got similar mileage but that hit made a big difference. With the fact that everything was 50% further away I ended up spending way more on gas in TX lol |
Surgx572.50 |
01-21-2022, 10:12 AM | #7 |
109
Rep 385
I feel the same way re fuel. No regular for me. Was so surprised is why I asked him.
He came back to my car and said and it’s the twin turbo 6 which I knew being a 440. I think the 2019+ is premium only and not recommended but not sure. |
01-22-2022, 03:42 PM | #8 |
468
Rep 343
while 91 is the recommended fuel, in my area most stations are either 89 or 93 so I just go every other fill up between the two. The difference between 89 and 93 is about 30 cents a gallon.
For those lucky enough to have Top Tier gas readily available that is more important for the additive package it possesses. Octane is merely a resistance to detonation.
cheers - Dave
01-22-2022, 05:43 PM | #9 | |
78
Rep 116
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
All that said, top tier 93 in the non-diesels. It's easy enough to take a look here every so often: https://www.toptiergas.com/licensed-brands/ I always found the M20B25 motors to be particularly fussy to addaiive packages, and so it started precedence in the late 90's. |
01-22-2022, 06:48 PM | #10 | ||||
468
Rep 343
cheers - Dave
01-24-2022, 11:43 AM | #11 | ||
Rep 1,532
Does it call for 91 because that is ideal or because that is the highest grade available in CA which is the largest auto market in the US? Porsche calls for 93 but my friends with em either fill 91 or 91 plus a dash of octane booster...from the seat of your pants you can't tell between the two. Here's a quote from BMW regarding the performance figures on the M2: Quote:
01-24-2022, 03:55 PM | #12 |
Ground Clearance?
232
Rep 1,653
nowadays BMW DME's are smart enough to detect if youre running less than optimum fuel and will just adjust the car accordingly. you arent really necessarily hurting the car but its also not running at its highest power setting.
E90 330i - E90 335i - E92 335i |
