03-14-2016, 03:17 PM | #1 |
Rep 5,066
http://www.dinancars.com/product/d44...ries&mid=1210/
Price from both Dinan directly or getbmwparts.com is $2,059.00 for the 35i and $2,574.00 for the 50i According to Dinan on the 35i models: Max HP Gain 77 @ 5000 RPM Max Torque Gain 81 @ 5000 RPM Peak Horsepower 360 @ 5500 RPM Peak Torque 392 @ 3000 RPM BMW Factory Rated HP 300 (315 Measured) BMW Factory Rated Torque 300 (330 Measured) Torque gains is very close to the diesel territory And for the 50i models: Max HP Gain 73 @ ? Max Torque Gain 67 @ 5500 RPM Peak Horsepower 506 @ 5500 RPM Peak Torque 547 @ 4500 RPM BMW Factory Rated HP 445 (446 Measured) BMW Factory Rated Torque 480 (511 Measured) Who wants to try it and report back? Also if anyone has had this installed care to provide some feedback?
03-14-2016, 03:49 PM | #2 |
Rep 5,446
Or you could just get one of the many other choices that do the same increases for $500 and lot's have people have already tried the Dinan tuner if you search.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
03-14-2016, 03:53 PM | #3 |
Rep 5,066
Yes, I have the MPPK and RCU installed.
Looking for some feedback on the dinan tune.
03-14-2016, 04:04 PM | #4 |
Rep 4,532
Put Dinan on my wife's 35 that already had MPPK. Might be a vbox log on this site. Was worth about 0.50 second reduction in 0-100 from memory. Easy install. Very good design. I do not like the packaging on the 50. If you already have RC I would not change out. I like RC on the non n63tu engines. (BMS for n63tu). RC for everything else.
03-15-2016, 05:19 AM | #6 |
1148
Rep 2,426
Maybe the same as BMS doesn't really sound like that great of a value... not to mention it's not legal in CA.
03-15-2016, 06:35 AM | #7 |
Rep 95
How to they keep it BMW friendly and not void the warranty? I've researched tuners for every vehicle I've owned and every one of them would void the manufacturer's warranty if the dealer found out about it.
Regards, Rodney
2016 X5 xDrive50i |
03-15-2016, 08:44 AM | #8 |
Rep 525
in essence it does void your warranty...but Dinan will cover you if BMW denies coverage and they will pick up the tab....dont know if there has been any cases of this but i believe its stated on their website.
03-15-2016, 08:48 AM | #9 |
Rep 525
this was my thought process.....the question is if it is more similar to RC over BMS....i have BMS on my 50i and it does increase feeling of power(adjusted a few clicks over BMS settings) not sure on a dyno what numbers it would pull over stock, but it definitely works...i just feel the dinan may communicate with the vehicle better? i mean the BMS is a single in line control box with one connection...the dinan is a whole slew of connections and a large ECU type Box...it cant be just a dinan tax and there must be Merritt to their system...although RC is built the same? are they in fact the same product? and then how does it accomplish the same as BMS with single connections
03-15-2016, 09:41 AM | #10 |
Rep 5,066
Yeah lots of people hear from others saying that DINAN products keep the BMW warranty intact and they just repeat what they hear without really researching it for themselves. I guess when customers see that BMW dealers install DINAN products and they assume it is warrantied.
03-15-2016, 09:44 AM | #11 | |
Rep 5,066
03-15-2016, 09:47 AM | #12 | |
Rep 5,446
Dinan also used to flash the ECU in the past, now it is just a piggyback like everyone else, so that may make things a bit easier as the ECU is not going to show up with bad checksums instantly tipping off BMW that it was tuned.
03-15-2016, 10:21 AM | #13 |
Rep 4,532
I have used all 3. Dinan is very smooth and makes good power over the MPPK on the 35i. Very good packaging. Easy install.
Racechip does not work on the N63tu engine. The DME is load based and requires a Dinan style or BMS style box. Racechip is very smooth on the S63tu and makes great power. BMS makes good power on the n63tu at 2:00 but is not as smooth down low as stock. Dinan packaging on the n63tu is awkward. It works but your putting 5 lbs of stuff in a 2 lb can. Racechip is my "overall" favorite because it makes great power, is stock smooth, great build quality and easy install/packaging. On map based DME's it is the real deal. On MAF based DME's it does not work. Ben at RG Sports is a great guy for all of these products. |
03-17-2016, 07:38 AM | #14 | |
IG @bmwF9xG80
3812
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Otherwise I agree, on every model there's someone on the forum who has it.. Dinan guys 9/10 don't dyno dont drag it so they're happy to believe "Dinan Marketing" but we've had ppl who were curious how it compares to similar car with diff tuned. The answer is clear, even a conservative ECU Flash tune will cost less, provide more consistent smoother delivery and even more gains than what the Dinan offers thats not to say what the other piggyback system will provide too. I always say apart from providing drivability enjoyment what do they improve over stock in the 1/4 ($15-$25) and you can test out your speeds if you're not into Dyno lol.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
03-17-2016, 11:01 AM | #15 |
Rep 4,532
I tested 2 different Racechip boxes directly from RaceChip for the N63tu. Not a seat of the pants "ohhh this feels good or bad". Actual test data. It does not work because the DME is very different. It is Maf controlled. So the RC alters the tmap signal to increase the boost and the DME cuts it back again due to Maf max values. You will not find one Dyno of the RC on a n63tu that shows a power increase because it can not. Terry found the same thing at BMS on the JB1 and had to change his design from the typical tmap intercept to a Maf intercept. I am using the RC on a S63tu and recommend it for any map based Bmw DME because it makes very smooth big power. RC knows they have an issue with the n63tu and refunded my $ after I tested both of their boxes.
03-17-2016, 11:38 AM | #16 | |
1148
Rep 2,426
03-17-2016, 02:01 PM | #17 |
Rep 4,532
It is a shame that some parts do not work as advertised. Wheels that crack, exhaust that does not bolt on ,etc. I've been stuck with some parts that do not work without a refund.
03-20-2016, 03:33 AM | #19 |
1148
Rep 2,426
Not sure if RC really works or not, but the car definitely feels less sluggish especially in Eco Pro mode.
03-20-2016, 07:58 AM | #20 | |
Rep 5,066
03-21-2016, 01:31 AM | #21 |
1148
Rep 2,426
03-21-2016, 07:40 AM | #22 |
Rep 208
I've been running bms stage 1 on my n63tu since just after break in. I disconnected for a couple of days while bringing for service. That was first time driving without it, and could definitely notice a difference. Not sure on hp numbers, but I feel for the $500 it was a good entry level, daily driver tune. With a difference of about $2k between bms vs Dinan, it was a no brainer.
