06-30-2023, 12:32 PM | #1 |
Rep 627
Drives: X5 F15 M package
headlight changes - errors and miss behave
I just changed my front lights and have the following errors
- Adaptive headlight malfunction - A Lighting system: Front left malfunction - A Lighting system: Front right malfunction - Headlamp vertical aim control malfunction - back camera not turning on when car on reverse (button is greyed out) Any inputs ? Thank you |
06-30-2023, 01:10 PM | #3 |
Rep 627
Yes and no.
Car is US version with xenon and lights replacement are euro xenon. Should that make sense. |
06-30-2023, 01:35 PM | #5 |
Rep 627
Interestingly enough we tried plugging the original one and still did not well behave.
06-30-2023, 02:30 PM | #6 |
Rep 442
When you get errors, Sometimes you need to shut the car off and wait a few then try again. Resets the computers.
But I'd also get ista and see if the wiring is different between us and euro |
06-30-2023, 04:05 PM | #7 |
Rep 627
Does ista need to be running while plugged to the car to check that ? I m a mac user and my prior BMW coding vm died on me.
Any help is appreciated. |
06-30-2023, 04:27 PM | #8 | |
Rep 442
If they are, then plug in ista. Car has to be on, and ista only works with windows. I think you can do a windows vpn on mac. But you'll need a way to plug in the cable to a mac. |
07-01-2023, 05:48 AM | #9 |
Rep 627
Error still persist despite letting it sleep overnight.
Ista seems to be the way plus Esys |
07-07-2023, 01:50 AM | #11 |
Rep 627
Thank you. Figured the lights are not compatible. UK version (halogen) on US car trying to make it Euro .. let’s see what’s next
07-07-2023, 03:56 PM | #12 |
Rep 627
I am now looking to adapt the EU headlight using US wiring diagram formerly hosted on newtis.
If anybody has a copy would he helpful. Similar to that one |
07-08-2023, 03:23 AM | #15 |
Rep 627
Seems to be the same as euro. Are you sure it’s US version of headlight ?
I need to compare and adapt US to UK lights. UK xenon lights have less fewtures. Using both diagram I might be able to adapt the US plug to UK lights. Thank you very much Updated with US headlight plug showing no purple and silver on #8 (red and off-white top row 3rd from right) |
07-08-2023, 08:19 AM | #17 |
Rep 627
Thank you for your help
You can see there are different headlights. Is there a way to see the pinout from the reference ? |
07-09-2023, 06:35 AM | #18 |
578
Rep 2,047
Pin Type Description /Signal type Connection /Measuring information
1 E Actuation, turn signal light, right Body Domain Controller 2 M Ground Ground point 3 E Supply, terminal 30 Fuse F57 from 2015_08 or Fuse F39 up to 2015_07 4 -- Not used 5 E Power supply, terminal 30F Fuse F10 up to 2015_07 6 -- Not used 7 M Ground Ground point 8 E/A LIN bus signal Body Domain Controller 9 E/A K-CAN3 bus connection Body Domain Controller 10 E/A K-CAN3 bus connection Body Domain Controller 11 E/A K-CAN3 bus connection Right headlight or Solder connector 12 E/A K-CAN3 bus connection Right headlight or Solder connector |
07-09-2023, 01:24 PM | #19 |
Rep 627
Is that the pinout of the non adaptive lights? Trying to understand cause the light plug has positions 1-8 available and 9-12 not available.
07-09-2023, 02:08 PM | #20 |
578
Rep 2,047
I only saw that is for adaptive.
You can use the wiring diagrams and check the wires from BDC and check the pin assignment backward from BDC to headlight. Connector location views Number X-pin, colour Description A258*1B 1-pin, black Component connector Body Domain Controller A258*2B 42-pin, black Component connector Body Domain Controller A258*3B 54-pin, black Component connector Body Domain Controller A258*4B 54-pin, natural Component connector Body Domain Controller A258*5B 42-pin, black Component connector Body Domain Controller A258*6B 24-pin, black Component connector Body Domain Controller A258*7B 54-pin, natural Component connector Body Domain Controller A258*8B 54-pin, black Component connector Body Domain Controller A258*9B 54-pin, blue Component connector Body Domain Controller A258*10B 12-pin, natural Component connector Body Domain Controller Pin assignments at plug connector A258*2B Pin Type Description /Signal type Connection /Measuring information 1 A Engine start signal Digital Motor Electronics Digital diesel electronics 2 A Activation Horn, low range Horn, low range 3 A Activation Horn, high range Horn, high range 4 A Actuation, magnetic clutch A/C compressor 5 -- Not used 6 A Actuation, control valve A/C compressor 7 -- Not used 8 -- Not used 9 -- Not used 10 -- Not used 11 E/A LIN bus signal Bus connection 12 A Activation, relay, terminal 15N Integrated supply module Petrol engine 13 A Wake-up signal, terminal 15 Connector, terminal 15 wake-up signal 14 A Activation Water valves Water valves 15 -- Not used 16 -- Not used 17 -- Not used 18 -- Not used 19 -- Not used 20 -- Not used 21 -- Not used 22 A Activation Wiper drive Wiper drive 23 A Activation Wiper drive Wiper drive 24 A Activation Washer pump for headlight washer system Washer pump for headlight washer system 25 A non LED light Activation, low beam light Right headlight 26 A non LED light Activation, high beam headlight Left headlight 27 A Activation Water valves Water valves 28 A Activation Driver's door central locking button Driver's door central locking button 29 A Activation Front passenger door central locking button Front passenger door central locking button 30 E Door contact signal Driver's door lock 31 E Door contact signal Front passenger-door lock 32 A Activation, brake light Tail light, outer left not USA 32 A Activation, brake light Tail light, inner left USA 33 -- Not used 34 -- Not used 35 A Activation Auxiliary water pump Auxiliary water pump 36 E Signal, reset contact Wiper drive 37 -- Not used 38 E Door contact signal Door lock, rear driver's side 39 E Door contact signal Door lock, rear passenger's side 40 E Contact lock signal Bonnet contact switch 41 A Locator lighting Connector 58g 42 -- Not used Pin assignments at plug connector A258*3B Pin Type Description /Signal type Connection /Measuring information 1 -- Not used 2 A Supply, terminal 15 Digital Motor Electronics Digital diesel electronics 3 A Power supply, terminal 30B Crash safety module 4 A Actuation, bistable relay Fuse carrier, rear 5 A Actuation, bistable relay Fuse carrier, rear 6 M Ground Ground point 7 A Activation, fog lights Left fog light 8 A Activation, fog lights Right fog light 9 E Switch signal, interior lighting Interior light, rear X6 only 10 -- Not used 11 E/A Signal Washer fluid level sensor Washer fluid level sensor 12 -- Not used 13 -- Not used 14 -- Not used 15 -- Not used 16 A Brake light switch signal Trailer module 17 A Switch signal, hazard warning light switch Trailer module 18 A Activation DDE main relay DDE main relay 19 A Activation, relay, terminal 30B Front power distribution box 20 A Activation, relay, terminal 15N Front power distribution box 21 E Activation, interior light Roof function centre 22 E Brake light switch signal Brake light switch 23 -- Not used 24 M Sensor ground Refrigerant pressure sensor 25 A Supply Refrigerant pressure sensor Refrigerant pressure sensor 26 E Signal Refrigerant pressure sensor Refrigerant pressure sensor 27 E Signal AUC sensor AUC sensor 28 -- Not used 29 -- Not used 30 A Power supply, terminal 30F Fuse F12 31 A Power supply, terminal 30F Diagnosis socket 32 A Power supply, terminal 30F Fuse F10 33 E Supply, terminal 30 Fuse F509 34 A non LED light Activation, high beam headlight Right headlight 35 A non LED light Activation, low beam light Left headlight 36 A Activation, flashing indicator lamp Right headlight 37 A Actuation, turn signal light, right Electric outside mirror 38 A Power supply, driver module Right headlight 39 -- Not used 40 A Activation, brake light Tail light, inner right or Interference suppressor filter 2 X6 only 41 A Activation, bi-xenon shutter Right headlight 42 A Actuation, tail light, right Tail light, outer right 43 -- Not used 44 -- Not used 45 A Power supply, terminal 30F Telematic Communication Box 46 A Power supply, terminal 30F Dynamic stability control (DSC) 47 -- Not used 48 A Activation, flashing indicator lamp Left headlight 49 A Actuation, turn signal light, left Electric outside mirror 50 A Power supply, driver module Left headlight 51 -- Not used 52 A Activation, brake light Tail light, inner left not USA 53 A Activation, bi-xenon shutter Left headlight 54 A Activation, tail light Tail light, inner left Pin assignments at plug connector A258*4B Pin Type Description /Signal type Connection /Measuring information 1 A Actuation, mirror heater, basic mirror Exterior mirror, front passenger 2 A Actuation, mirror heater, basic mirror Exterior mirror, driver 3 A Actuation, water jet heater Connector, heated washer jets 4 A Activation, relay, terminal 15N Fuse carrier, rear 5 A Activation, relay, terminal 30B Fuse carrier, rear 6 A Supply, terminal 30 Fuse F500 7 A Activation, power window drive Power window drive, passenger 8 A Activation, power window drive Power window drive, passenger 9 A Supply, Hall sensor Power window drive, passenger 10 E Hall sensor signal Power window drive, passenger 11 E Hall sensor signal Power window drive, passenger 12 E Signal Passenger's door power window switch Passenger's door power window switch 13 E Aerial signal, comfort access Interior aerial, centre console, front 14 E Aerial signal, comfort access Interior aerial, centre console, front 15 E/A LIN bus signal Remote control receiver 16 A Actuation, central locking drive Central locking drive, fuel filler flap 17 A Actuation, central locking drive Door lock, rear passenger's side 18 A Actuation, central locking drive Door lock, rear driver's side 19 A Actuation, central locking drive Front passenger-door lock 20 A Actuation, central locking drive Driver's door lock 21 A Supply, Hall sensor Power window drive, driver 22 E Hall sensor signal Power window drive, driver 23 E Hall sensor signal Power window drive, driver 24 E/A LIN bus signal Electric steering column adjustment 25 E Aerial signal, comfort access Interior aerial, centre console, rear 26 E Aerial signal, comfort access Interior aerial, centre console, rear 27 E/A LIN bus signal Exterior mirror, front passenger 28 A Actuation, central locking drive Front passenger-door lock 29 A Actuation, central locking drive Driver's door lock 30 A Actuation, central locking drive Driver's door lock 31 A Actuation, central locking drive Front passenger-door lock 32 -- Not used 33 M Ground Ground point 34 A Activation, power window drive Power window drive, driver 35 A Activation, power window drive Power window drive, driver 36 A Activation Windscreen washer pump Windscreen washer pump 37 A Manual headlight beam throw adjustment activation Right headlight 38 A Manual headlight beam throw adjustment activation Right headlight 39 A Manual headlight beam throw adjustment activation Right headlight 40 A Manual headlight beam throw adjustment activation Right headlight 41 E/A LIN bus signal Bus connection 42 E/A LIN bus signal Switch block, driver's door 43 A Actuation, central locking drive Door lock, rear passenger's side 44 A Actuation, central locking drive Door lock, rear driver's side 45 A Actuation, central locking drive Central locking drive, fuel filler flap 46 A Actuation, central locking drive Door lock, rear passenger's side 47 A Actuation, central locking drive Door lock, rear driver's side 48 A Activation Windscreen washer pump Windscreen washer pump 49 A Manual headlight beam throw adjustment activation Left headlight 50 A Manual headlight beam throw adjustment activation Left headlight 51 A Manual headlight beam throw adjustment activation Left headlight 52 A Manual headlight beam throw adjustment activation Left headlight 53 E/A LIN bus signal Right headlight 54 E/A LIN bus signal Left headlight |
11-08-2023, 06:56 AM | #21 |
Rep 14
Did you ever figure this out? I am in a similar situation. I just picked up the X5 and it has non adaptive xenon headlights in it. When I look at the connector the brown wire (I believe pin 7) was unplugged. I plug them back in and was able to get the halos to work but no high beams still. I also noticed when I exit the car and it enters sleep mode the halos turn themselves on and they stay on!
11-08-2023, 07:22 AM | #22 |
Rep 627
I partially figured out this issue.
Moved a pin on the BDC. But then only the driver side light was fully operative. Despite all the wiring schema etc… I couldn’t get the passenger side to work properly. So I ran a wire from the driver side light to the passenger side light. This allowed me to pass the examination of the car for the homologation. Side effect, the car throughs an error when I break stating malfunction. We tried to code many settings including changing the country etc… no luck. What an i going to do next? Since the car is fully approved now; I will revert to my US light and get ride of all the mess. I am not sure why the reverse camera stopped working. On ISTA it simply shows offline. Hope this helps TFran3c |
