10-23-2021, 07:22 AM | #133 | |
Rep 28
But to be honest, none of the tech knew what they were doing. Even for DSC changeout to DSC ACC was unsuccessful on the first try as they didn't have ISTA+. They were using ProTools which isn't suited to BMWs. Well very few 3rd party workshops here uses ISTA+ and ESys anyway and those who does, charges exorbitantly U need to have Esys 3.30 (for CAFD injection and flashing) and ISTA+ (for initialization, troubleshooting etc.) running on your pc first. Then u can check via Esys KIS/SVT calculations for actual hardware against target hardware to get definite answer. |
10-23-2021, 04:49 PM | #134 |
Rep 1,353
Seems like it is gonna be easy retrofit then
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
10-23-2021, 04:50 PM | #135 | |
Rep 1,353
If i am Pro in BMW world today, i owe big time to "BMW Techs"
11-02-2021, 09:10 AM | #136 |
Rep 28
Finally everything has been completed.
Installed the bimmer8 HOD module as per the instruction and did the 5AR coding (VO code for ICM module, the rest FDL editing since I've followed instructions from bimmer8). I've managed to use the TJA for a single journey of 350km mix 60% highway and 40% town driving. Here is my observation; 1. I've enabled TJA max speed to 99kmh but when i set ACC to say 110kmh, it will still engage when u are following vehicle at <99kmh. 2. My TJA steering response at 99kmh was very good, not much swaying and it seems to steer within lines even though car in front keep on veering left to right. The only drawback is when u have curvy road that require close to 1/4 turn then it will disengage. 3. It can even follow motorcycles for town driving which is quite impressive. 4. For most of town driving, the car could not identify road lane markings (left and right) but TJA works just fine by following front car/motorcycle. 5. Managed to use the TJA in rainy weather and works just fine except for when it's really heavy, the sensor deactivated by itself with warning on IDrive saying "sensor could not be activated, keep safe distance" error message. Well I couldn't be more pleased with the results and seeing myself will be using this function more often than not. |
SaNGRia996.50 |
11-02-2021, 09:13 PM | #137 | |
Rep 1,353
I rent a Subaru Legacy during Universal trip, it had advance 2 KAFAS camera side of the rear view mirrors, i was able to drive 100mhp with TJA and it response super accurate. That is why 5AU > 5AT
11-02-2021, 10:15 PM | #138 | |
Rep 28
I'm trying to increase the TJA speed limit to more than 99kmh see if that can be worked out. But since it doesn't have LKA so ur hand should always be on the steering for quick intervention. |
11-03-2021, 06:52 PM | #139 | |
Rep 1,353
I believe it is possible to upgrade that 2 on our vehicle. But the issue is you will need FSC codes for the KAFAS High. I am not sure if our ICM will support this even with 2021 software update which i have already done.
11-06-2021, 11:32 AM | #140 | |
Rep 28
Anyway as an update, I've increased TJA speed limit to 149kmh and funnily the dashboard message would show "TJA available up to >9kmh" when it's activated. Somehow beyond 99kmh it will start to show funny symbol instead of the actual numbers. Expected as other thread reported the same finding. On the driving experience however, I am glad to report that it worked pretty well on highway. I did cruising at 110kmh when I activated the TJA and both road marker lines was identified as well as the car in front was recognised as usual with good weather outside. The steering didn't veer much when it followed the car in front on the left most lane (we are following UK roads and it is expected as car in front was managing his line quite well). Things got more interesting when the front car switched to the right lane to overtake, TJA system recognized this and as it tried to swerve to the right lane just before it hits the road line markings, the system buzzed and turned off saying typical lane too narrow message. I did this scenario few times over the 300km drive and can confidently says that the system will intervene and disabled itself when it tries to follow front car going outside current lane. In overall, the cruising experience felt much more relaxed at 110kmh highway speed as I started to trust the system. At higher speed however it felt a bit overwhelmed as the auto steering couldn't keep up with more than 5degree turn (estimated). A bit lengthy post but just sharing in case anyone wanted to try higher speed for that long highway drive ahead. |
11-06-2021, 05:27 PM | #141 | |
Rep 1,353
Thanks for sharing. I will never going to trust KAFAS2 over 60 mph in the state since lanes are alot wider than european autobahn. I am good with 63 limit.
08-10-2022, 09:24 AM | #142 |
Rep 53
Hi -
I would love to install this mod but am totally intimidated by the work :-). Is there someone in MA, USA who is interested in installing it on my '16? |
11-20-2022, 06:14 AM | #143 | |
Rep 3
Btw I already have ACC and my VIN is WBAKS420400J64078. Can i code TJA only with the Steering mod from ebay or am I missing some sensors etc? |
01-09-2023, 08:05 AM | #145 | |
Rep 28
And yes u can. U just need the TJA module + codings to make TJA work. Simple enough imo |
04-15-2023, 08:52 PM | #147 |
Rep 1,353
Hey, I used about 2,5meter in total
05-21-2023, 08:11 AM | #148 |
Rep 22
Hi, I’m planning to retrofit ACC to my F30. My car come with Adaptive Suspension and HUD and my ICM version is v7.3 part number 34526867170. May I know will my ICM work with the ACC retrofit or I should look for a ICM v5.4? I hope someone can give me info regarding this retrofit, thanks!
05-21-2023, 10:15 PM | #149 | |
Rep 1,353
05-22-2023, 06:13 AM | #150 |
Rep 22
No, I don’t have parking assist would that be my ICM not compatible? Based on my research I need ACC Radar, ABS pump, ABS wheel speed sensor, steering wheel with ACC control button and last which I’m unsure about is the ICM. Because most of the people is recommend getting V5.4 that’s why I’m a bit confused if mine ICM can work it out or not.
05-22-2023, 06:17 AM | #151 |
Rep 22
And regarding the ACC Radar module, can I get other chassis to work in my F30? Example can I buy a used Radar which original dismantle from a 5 series with BE2 on the label to use it on my F30?
05-22-2023, 11:13 PM | #152 |
Rep 1,353
BE2 is correct. No need new steering wheel just get emulator for HOD. U need DSC ACC. Your ICM is good! 5.4 and up is compatible!
05-23-2023, 03:54 PM | #153 |
Rep 2,665
Drives: Goggomobil
Hats off to you two. Brave and helpful to the BMW community. It's a very interesting challenge despite being visually daunting. Wouldn't mind tackling if there is an end-to-end DIY. Having said that, not all F85 and F86 configuration and equipment levels are the same.
Well done!
F86 X6///
SaNGRia996.50 |
06-10-2023, 06:04 AM | #154 | |
Rep 22
I guess I can start hunting for parts already Just I wasn’t too sure about ICM because some member in the forum said I need to use ICM v5.6 and I checked my ICM part number it was stated as ICM Plus instead of High |
