      10-12-2014, 01:50 AM   #265
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Originally Posted by Hang0ver View Post
Yeah... I know, sorry man. I suggested one final thing to him to compare his Euro files to CatFlap's to make sure they match up 100%...if they do, it's definitely a hardware requirement, unfortunately.
On a positive note, I just removed 8S4 from my FA and VO Coded BDC_Body for the VLD coding for my low beams. They definitely move around a lot now. They seem lower when I'm driving around my neighborhood, especially up hills so it seems like they are smarter...they also turn earlier/quicker as I'm turning right or left - before the turning wasn't as noticeable, but now you can really tell they are moving as you turn. Just for the heck of it, since I'm so particular about the coding I like, I re-coded all my BDC_Body coding that I had lost when I VO Coded BDC_Body to get the Variable Light Distribution.
Here's my question. I spoke to @skalberti. He said in order to save a particular CAFD module, I just need to Read Coding Data of that CAFD folder and it generated a .ncd file in C:\Data\CAF. I cleared all the previous read CAFD files and just made sure to save the BDC Body CAFD. I did and it was generated as CAFD_000017BE_005_019_027.ncd. This CAFD had all my BDC_Body coding that I had previous fdl coded. So that's on the side now. I VO Coded after removing 8S4 and that worked. No problem. Now, when I want to restore the generated CAFD that I had saved previously, I just right-click on a CAFD (green dot) and select NEW>FDL. This takes me to C:\DATA\CAF folder. I select the generated .ncd file, but the "code fdl" button does not become active. So, I figure ok let me change something by editing the fdl and then change it back and then save. I do this, and I see that the "code fdl" button becomes active. I code fdl, but it is still the default VO coded settings. So, I still have the 8S4 removed and I had to manually go back into BDC_Body and redo all my fdl coding.
So here's the question, how do you get a save your fdl coding if you don't want to keep the new VO coded settings? My plan was originally to just test the VLD coding by removing 8S4 and then reverting back to my previous BDC_Body settings that I had previously coded at the cost of losing the 8S4 removal. Sorry, if this sounds confusing. @shawnsheridan and @skalberti, please let me know. Thanks. I know that when you VO code something, reverting eliminates that VO coding...I remember talking to Shawn S about this and saying it was pointless if you were keeping the FA addition/removal and VO coding. However, for just testing purposes, how would I go about reverting?
I have a SAT.xml with my 6WB and 8S4 present. I currently have a new SAT2.xml with 6WB present and 8S4 removed (I manually redid the fdl codes in BDC_Body for this and saved this .ncd on my desktop while it is also present in C:\Data\CAF).
      10-12-2014, 11:29 AM   #266
simplemind38
simplemind38's Avatar
Drives: 2015 X5
That's a bummer! that totally blows that we might not get anti-dazzle working here in the states, but I really appreciate all the hard work that you guy's do for us in the coding community.
      10-12-2014, 04:30 PM   #267
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
So, with this coding, @Catflap was able to enable the car to shift into neutral whenever the car went above 40mph (if I recall correctly) in Eco-Pro mode. The car automatically does this and shifts back into gear (Drive) when you accelerate or brake. It's very interesting coding and supposedly saves gas and obviously makes the car very quiet while you're coasting because the RPMs drop in neutral. Here's the thread where it was discussed: http://f15.bimmerpost.com/forums/sho...php?p=16440147. Here's @Catflap's video:
https://www.dropbox.com/s/pxu58fav5m...2008.34.11.mp4
It seems like most of the features specified in the coding sheet for sailing is already enabled by default for us.
      10-12-2014, 04:38 PM   #268
opasha
opasha's Avatar
1329
I never tested it. That's odd. So, despite them being enabled, we don't get that same Eco-Pro screen? Are you 100% that you checked all the codes? I'm assuming you were in Eco-Pro when you tested.
      10-12-2014, 04:48 PM   #269
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
Didn't test that by driving. I saw all of them enabled. I already have the coasting feature and the check box for coasting. No checkbox for sailing came up though.
One catch is, we don't have the below section in DME module. At least I don't.
3701 OHNE_ZEITLIMIT
      10-12-2014, 05:27 PM   #270
opasha
opasha's Avatar
1329
3701 OHNE_ZEITLIMIT
Ah, I see. You're positive you searched for it starting from the top DME folder?
      10-12-2014, 06:19 PM   #271
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
Yes I did.. We don't have that section in the module and even the config in that module. So, its better to update the cheat sheet to say IN WORKS ... so that nobody codes it ..
      10-12-2014, 07:11 PM   #272
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
is there a way to make the interior lighting work with light sensor.
I think the lights stay up during daytime also. Correct me if I am wrong.
      10-12-2014, 08:29 PM   #273
opasha
opasha's Avatar
1329
Do you mean the iDrive screen or the Ambient lighting? Despite being Automatic, my iDrive stays only the brightness I set it at. Ambient lighting stays the same setting as well that you set it at for day and night.
      10-12-2014, 08:49 PM   #274
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
I'm trying ambient lighting. So you mean ambient lighting considers the day and night?
      10-12-2014, 09:09 PM   #275
opasha
opasha's Avatar
1329
No, it does not. It just looks way less bright in day time even when it is full brightness. I have mine set to 100% brightness.
      10-12-2014, 09:31 PM   #276
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
Yeah right. That's completely useless power consumption. BMW engineer should have thought of this.
Hope we can find the coding for it.
      10-12-2014, 09:41 PM   #277
opasha
opasha's Avatar
1329
I'm sure it's hidden somewhere in BDC_Body because when we VO Code or fdl code BDC_Body, the ambient lights turn off briefly for some coding.
      10-12-2014, 09:44 PM   #278
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
I'm sure it's hidden somewhere in BDC_Body because when we VO Code BDC_Body, the ambient lights turn off briefly for some coding.
Oh boy. The hardest coding to search is BDC_BODY.
That's like burj kalifa.
      10-12-2014, 09:56 PM   #279
opasha
opasha's Avatar
1329
Hahaha...true that.
      10-13-2014, 10:27 AM   #280
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
Hahaha...true that.
Been searching the whole BDC_BODY. Found some ambient lighting coding in LCIMASTER (3070) and LCICONFIGURATION (3071).
Was able to figure out that below configs are dependent on 563 (LIGHTS PACKAGE)
BDC_01 > LciConfiguration 3071 > ILE_LIN_VAR = V6c
BDC_01 > LciConfiguration 3071 > LAYERING_LIN_SLAVES_ANZAHL = F15
BDC_01 > LciConfiguration 3071 > LESELICHT_HINTEN_VERBAUT = nicht_aktiv [Default]
BDC_01 > LciConfiguration 3071 > LIN_RGB_SYSTEM_VERBAUT = aktiv
BDC_01 > LciConfiguration 3071 > MAPPING_LCI_4_FUNCTION = footwell_rear
BDC_01 > LciConfiguration 3071 > MAPPING_LCI_5_FUNCTION = ovt
BDC_01 > LciConfiguration 3071 > MAPPING_LCI_6_FUNCTION = cs_1
BDC_01 > LciConfiguration 3071 > MAPPING_LCI_7_FUNCTION = cs_2
BDC_01 > LciConfiguration 3071 > PIA_DEFAULT_CS = Farbe_9
BDC_01 > LciConfiguration 3071 > RGB_LIN_LAYER_1 = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_LAYER_2 = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_LAYER_3 = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_LAYER_8 = initwert [Default]
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_1_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_10_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_11_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_12_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_13_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_14_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_15_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_16_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_17_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_2_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_3_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_4_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_5_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_6_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_7_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_8_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_9_FKT = F15_F16
BDC_01 > LciConfiguration 3071 > RGB_LIN_SLAVE_FRL_FRONT_LAYER_8 = aktiv
BDC_01 > LciMaster 3070 > AMBIENTE_ANZAHL_LIN_LAYER = 3_LAYER
BDC_01 > LciMaster 3070 > AMBIENTE_FARBE_FAHRBEREIT = H-Farbwert
BDC_01 > LciMaster 3070 > AMBIENTE_FARBE_NICHT_FAHRBEREIT = H-Farbwert
BDC_01 > LciMaster 3070 > AMBIENTE_MODUS = RGB Layering
BDC_01 > LciMaster 3070 > AMBIENTE_NACHFUEHRUNG = aktiv
BDC_01 > LciMaster 3070 > WL = aktiv
Now...need to find out which ones really make it happen @shawnsheridan @skalberti -- any thoughts on what to change to make the ambient lighting to turn off automatically during daylight? or if it is even possible?
      10-13-2014, 12:30 PM   #281
NPickles
United Kingdom
71
Apologies if this has been covered in this thread already but I haven't seen anything in what I have read so far.
I have the bi-xenon headlamps in a UK spec car which has LED fog lights. One thing that winds me up is that when flashing the headlights in acknowledgement at another car they are so slow to react. I put this down to it moving something inside the headlight rather than flashing another bulb as in most other headlamps. It is almost impossible to get a proper flash, it's either almost nothing or too much, you know what I mean?
I know there has been lots of talk about the new LED headlamps but many people still have the "old fashioned" bi-xenons.
Does anyone have any codes to increase the reaction speed of the headlights when flashing an acknowledgement like this or point me in the right direction so I can have a fiddle myself.
      10-13-2014, 04:47 PM   #282
Hang0ver
Hang0ver's Avatar
20
Drives: 2015 X5 35i
@opasha -- can you check what are the values of below codes for your car as it has 6NS by default? If these are off, can you see what happens if you change these. I want to test these on a default 6NS car.
Found some settings to play around with in HU_NBT (works with 6NS coding)
3003 TELEFON_TELEMATIK_ONLINE
PIM_ACCEPT_CAL_EVENT --> default: nicht_aktiv --> change to aktiv
Comment = accepting and declining of calendar supported
PIM_EXCHANGE_SUPPORT --> default: nicht_aktiv --> change to aktiv
Comment = access to PIM data via MS Exchange WebServices supported
PIM_NEW_ELEMENT_TEXT_NOTE --> default: nicht_aktiv --> change to aktiv
Comment = Create and synchronize new text note
API_IPOD_VIDEO --> default: none --> change to both
Comment = activate/deactivate video function of iPod on the first USB or/and on the second USB
Wondering why are these disabled
Adding some more that I found using F30 coding.
KOMBI -- 3000
BC_V_KORREKTUR --> default : aktiv --> change to nicht_aktiv
Comment: Removes speed correction and displays actual speed (When testing speed correction turned off, it causes the speed to always be approximately 2 mph lower than Cruise Control set speed.)
IHKA -- 3000
OFF_MEMORY --> default : nicht_aktiv --> change to aktiv
Comment = Keeps AC turned off/on while starting if it is off/on when stopped.
HU_NBT -- 3003
TIMESTAMP_DISPLAY --> default : nicht_aktiv --> change to aktiv
Comment = Enable display of time stamps in the incoming calls list(for Inbox)
I will let you know once I test these. Then we can add these to the coding sheet.
      10-13-2014, 05:34 PM   #283
opasha
opasha's Avatar
1329
Not sure what delay you're experiencing. Mine seem fine, but I don't know what code is responsible for this. I'll look for it though and PM you if I find anything relevant.
KOMBI -- 3000
IHKA -- 3000
HU_NBT -- 3003
Interesting coding finds, buddy. I can check the values of those codes related to 6NS, but I don't ever use bluetooth nor are any of those features relevant to me (I have an Android device so the last one I'm not even sure about). I also found this thread about the API_IPOD_VIDEO: http://www.bimmerfest.com/forums/arc.../t-746059.html. Seems like it doesn't do anything, but the features that do for media playback, I have enabled already. There was one extra one that I saw: ENT_MC_VIDEO_SUPPORT - I'm interested in what this does. Can anyone comment?
      10-13-2014, 05:51 PM   #284
OuKEnFoLdMX
OuKEnFoLdMX's Avatar
Mexico
26
Drives: BMW F15
@opasha
HU_CIC / HU_NBT 3000 HMI ENT_MC_VIDEO_SUPPORT aktiv / Werte=01 nicht_aktiv / Werte=00 Allows videos to be stored to the internal hard drive
      10-13-2014, 05:54 PM   #285
shawnsheridan
shawnsheridan's Avatar
Originally Posted by OuKEnFoLdMX View Post
@opasha
But is it actually working?
      10-13-2014, 05:58 PM   #286
opasha
opasha's Avatar
1329
@opasha
Thanks for the info.
I'd like to know this as well.
