01-13-2017, 10:00 AM | #1 |
Rep 6
HVAC Blows Cold Air in Morning
2017 F15, beautiful vehicle that I've owned a couple months now. I'm a leave the HVAC settings on "auto" at 68-degrees kind of guy, and every other vehicle I've owned will not blow cold air in the morning until the engine is hot enough to make warm air. I think even my wife's E90 holds off on the blower. On my F15, it was 22-degrees this morning and after about 30 seconds the blower started gently blowing cold air for several minutes until it began to warm.
I've noticed this in the past when it was in the 50s outside and thought it was a fluke, but at sub-zero temperatures it should not be blowing cold air! Is this normal? |
01-13-2017, 10:33 AM | #2 |
Rep 452
Im also on the same boat. It was -15 celsius the other day and the AC was blowing cold air for atleast 10 minutes before it started to slowly warm up. Its quite annoying especially with passengers dying of cold
01-13-2017, 09:50 PM | #3 |
Rep 599
I agree the HVAC system in these cars does not make sense. My '17 blows ice cold air from the front vents whilst simultaneously blowing scorching hot air via the foot vents. Outside temp 28 - desired in car temp 65. I am going to take it in to the dealership since it drives me nuts. None of my previous BMWs and otherwise have done this. Anyone else experienced this?
01-13-2017, 10:29 PM | #6 |
Rep 155
This is normal. Keep in mind, that the whole system is at ambient temperature when you get in the vehicle. Just like when you turn on the hot water in your kitchen it takes a few seconds for it to get hot.
01-14-2017, 12:59 AM | #7 | |
Rep 8,364
Preconditioning takes care of my vehicle climate. |
01-14-2017, 09:19 AM | #8 |
Rep 6
Right. And in virtually every other modern car, the system remains "off" for a few minutes until the car warms up.
01-14-2017, 02:32 PM | #9 |
1152
Rep 2,426
If I set my dial to hot only, it does not blow any air until the engine is warm.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
01-14-2017, 04:23 PM | #10 |
Registered Member
661
Rep 608
Hmm... have owned many different German makes and models and have never noticed this feature, which modern car brand are you referring to and what is the feature called?
01-14-2017, 06:05 PM | #11 |
Rep 137
I have the same complaint, I hate it blowing cold air on me when I first start the car up in the morning. I wish system would at least remember where I have the system set when I shut the car off, rather than defaulting to AUTO on. So I don't have to turn the HVAC system off after I start the car and then after car warms up... turn it back on.
01-14-2017, 10:11 PM | #13 | |
Rep 155
01-14-2017, 10:12 PM | #14 |
Rep 155
01-15-2017, 05:03 PM | #15 | |
Rep 6
I'll try setting the top vents to hot and see if it makes a difference. |
01-15-2017, 06:30 PM | #16 |
Rep 8,364
There are two separate issues:
01-15-2017, 11:39 PM | #17 |
1152
Rep 2,426
I really wish BMW would update the preconditioning option on app for those of us that installed the factory remote engine start retrofit. I get on the 40e you can use electricity for heat in the winter and for some cool air in the summer, but on the gas/diesel only model that's obviously not possible without engine heat or the motor running the compressor. I really think the BMW app is a bad when it comes to this.
BMW CCA 509766 |
01-16-2017, 03:55 AM | #18 |
Rep 30
Drives: F15 X5 xDrive35i
I agree - the AI of the auto-climate system is not perfect in cold weather start-up resulting in the fan being turned on too early and blowing cold air. Conversely, in warm temperature even with the "aggressiveness" set to max the auto -AI climate needs manual override to true maximum cooling.
Since I love my x5 I would say this is the one area I have slight disappointment with. My 1999 4-Runner had smarter auto-climate than my 2016 x5. |
01-16-2017, 01:00 PM | #19 |
Registered Member
661
Rep 608
Ahhh... I missed the part where the climate control unit has to be set to Auto as I never use that feature.
01-19-2017, 11:23 AM | #20 |
Rep 1,547
My 2014, regardless of the blend dial settings, will not blow cold air during cold startups. I find the HVAC near perfect in these vehicles. I set it to auto, 2nd fan speed, and 20-21.5 degrees...always comfortable and it never fogs up.
01-27-2017, 12:32 PM | #21 |
Rep 23
Did you leave the Auto on? if the AUTO light is on, that mean the AC compressor will be running until the Temp sensor detect the current temp and then cold air will stop. That's happen to any new cars these day.
01-30-2017, 10:32 AM | #22 |
Rep 1,547
Update on mine, its happened a few times now, the two center vents (dash) blow cold air, regardless of the temp setting - even at max. The blend control makes no difference in this. A cycle of the ignition seems to solve the problem. Any one else experience this?
