      02-04-2016, 12:14 PM   #243
Slayerkillhate
Ukraine
67
Drives: M8
Guys sorry maybe its off top, but did our car have TirePreasureMonitor? I use Canadian F85 and only see "green" status of tire, but read info that it can be coded, anyone know about this?
      02-04-2016, 01:19 PM   #244
jcfay
jcfay's Avatar
Drives: 2016 BMW X5 M
I'm not sure I really understand your question, but yes, my F85 definitely has TPMS. And the vehicle status shows pressures as well as status. And no coding is required, nor am I aware of any additional coded option that would help provide more tire pressure info. HTH
      02-04-2016, 01:27 PM   #245
WCH
WCH's Avatar
Drives: '20 M8C convertible
US cars now have tire pressure and temperature readings. They can be coded if your car does not. Until last summer, US cars did not have this on from the factory,
      02-04-2016, 01:29 PM   #246
WCH
WCH's Avatar
Originally Posted by ctwickman View Post
For what it's worth the OEM winter sets seem to be arriving about 4 weeks after the order is placed. Got mine in last week.
When I leased my car two weeks ago, there were no OEM winter sets available for order so if you don't have an existing order, it may be tough or impossible to get one this year.
      02-25-2016, 11:58 PM   #247
awesoM
awesoM's Avatar
Drives: 2023 i4 edrive35 2022 X7 M50
Does anyone know if the 469M Wheels will fit a F85? Trying to see if I can use them for a winter package.
      02-29-2016, 05:22 PM   #248
Roundown
Drives: BMW
Selling my near-new set:
FS: OEM F85 X5M Winter Wheels/Tires http://f15.bimmerpost.com/forums/sho....php?t=1231723
      03-28-2016, 07:01 AM   #249
jhnmcdrmtt
Drives: 2013 G550
How many of you guys are getting a lot of flats in NYC East coast area? The 21"s popping often or less often than you expected.
      03-28-2016, 12:09 PM   #250
jcfay
jcfay's Avatar
Good question. I just put my 21s back on after spending the last 4 months on the 20" OEM Winters. And driving around today I hit more than a few fairly gnarly bumps, but no damage. I've been lucky so far, but the 20s had more sidewall to give with so not sure how it's going to go with the 21s before they fix most of the potholes. I'm sure the milder winter helped things.
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers
2014 C63, Klassen M52Rs, Eurocharged tune - Gone
      03-28-2016, 04:42 PM   #251
Coelho
Drives: X5M
I was too scared and ordered with the 20s...
      08-16-2016, 01:11 PM   #252
fyim
fyim's Avatar
83
Drives: E92
Guys i need your help:
I want to order winter wheels. The OEM 20" ones are nice but with the wrong ET of you ask me. So most probably i will go the custom order route.
Can anyone help me with the ET and width for the OEM 20" wheels?
Many thanks
      08-16-2016, 06:10 PM   #253
W C W
Drives: 2016 BMW F16 50i msport
i'm fairly sure they are a 10x20 ET40 11x20 ET37 in a staggered configuration.
      08-18-2016, 03:14 PM   #254
fyim
fyim's Avatar
83
Drives: E92
Thank you sir
      08-26-2016, 04:57 PM   #255
daveinct
Drives: BMW X5M
I started leasing a 2016 X5M in March, and have the stock 20" wheels with summer tires. It seems like a waste of money for me to buy another set of 20" wheels... Is there anything wrong with just buying 4 winter tires and having them installed on my existing wheels?
      08-27-2016, 04:57 PM   #256
UrbanExtant
Drives: F82 M4 Comp Pack
No, there's not. That is exactly what we do with our leased i3. Just make sure you store the unmounted tires in a manner that they won't get damaged.
      08-27-2016, 07:41 PM   #257
daveinct
Drives: BMW X5M
Thanks, UrbanExtant. After I posted that question last night I kept digging, and was led to believe that there aren't even any winter tires that fit the stock rear wheels.... Please tell me I'm wrong!
      08-28-2016, 01:42 PM   #258
SFB_X5M
Drives: X5M
I run Yokohama on original 21s
      08-29-2016, 08:38 AM   #259
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Nothing wrong with that - the only reason not to do that is the convenience of being able to just swap them on in your driveway whenever you want if you have the storage.
If you swap just 20" tires you will need to do a mount/dismount balance each fall and spring. Some people may not want to do that.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red
      08-29-2016, 03:55 PM   #260
GladiatorOwner
Drives: 22 M4C
Are these the v905s? If so how do you like them but not sure we (US) can get these??
      08-31-2016, 06:43 PM   #261
daveinct
Drives: BMW X5M
After talking with someone I trust, I now believe I should get a separate set of winter wheels in addition to tires. I still think it would be ridiculous to pay BMW $4000 outright for a second set of wheels+tires on a leased vehicle, so that's out of the question for me out of principal, plus they are ugly in my opinion.
I attached a winter wheel/tire combination from tirerack.com - what is everyone's opinion of this (performance, safety, compatibility, different tire pressure sensors, etc)? I would be purchasing them at a much lower price than what's listed on that site.
Thanks.
      08-31-2016, 08:29 PM   #262
gan23
Drives: X5M '18 XM’23 X5 50e 24
Originally Posted by gan23 View Post
Actually, at the last M Power Experience tour in Las Vegas, I had a chance to ask Walter Haupt if the 19" 298 wheels would fit and he said no because of the new 6 piston calipers on MY2015. That's why BMW went with 20" winter wheels.
I didn't ask about ET. Bore size should be the same
Check at the beginning of the thread.
From my point of view, 19" won't fit.
Edit
E70 X5m F: 74.1 R: 72.6
F85 X5m F: 74.1 R: 74.1
F15: F: 74.1 R: 74.1
Bore size is different though
      08-31-2016, 10:53 PM   #263
WCH
WCH's Avatar
19" wheels won't fit over the brakes.
      09-01-2016, 12:59 PM   #264
IndyM
Drives: 2017 X5M (DG/MR)
Thanks.
A coupe of thoughts for you on why I decided to pony up for the BMW set... I paid $3800 plus tax from my dealer.
1) The F85 has a wheel fitment (size, bore, offset, etc.) that is hard to find via aftermarket suppliers. The limited options I saw were still well north of $2k and, in my opinion, did not look as good as the OEM setup.
2) Beyond not looking as good, I only have so many hours in the day and I'd rather spend a little more and know that the fitment will be perfect.
3) If you have wheel & tire insurance through BMW (or a third party but sold by your dealer), it should cover a winter setup that is on the car IF it is a BMW wheel... most will not cover an aftermarket wheel.
4) And, lastly, the BMW winter setups tend to hold their value well. I have usually sold mine after 3-4 years for 50% or more of the original purchase price. Aftermarket wheels won't hold their value as well.
So, my conclusion was that the BMW option, although expensive, was worth it. Just my $0.02...
AwesomeM31644.00
