10-15-2018, 07:51 AM | #1 |
Rep 54
Need help for the M performance brake
Hi,
I upgraded the M performance brake (front only) about 2 years ago and now with 50,000km and it is time to change the pads. However I can't find the right part number on the web. Does anyone can help what is the part number for the pads & sensors? Thanks |
10-15-2018, 08:33 AM | #2 |
Rep 178
I can confirm the Part # for the front pads included in the MPBK is # 34116799964.
I just purchased the MPBK and had it installed, but I swapped out the rotors to F85 Rotors and went with CarboTech Pads so I still have the Rotors and Pads Front/Rear sitting and listed for sale as a kit. I am not sure on the sensors since I already had them installed and threw out the packaging. The MPBK is the same as Brakes on 2010-2013 X5 M Series and that sensor # is 34-35-6-792-568 so you may want to consider that part #, but definitely double check. https://www.getbmwparts.com/oem-part...Y4LWdhcw%3D%3D |
10-15-2018, 09:02 AM | #5 |
Rep 178
I read a ton of reviews on this forum on both the dust and squeal of the OEM's on the F85 rotors so I figured I would try the CarboTechs per all the recommendations on this forum. Has been less than a week, but quite impressed with the limited dust and not a single squeal, even during this break-in period.
