07-01-2018, 10:43 PM | #1 |
88
Rep 366
Brake Force Flash
For anyone wondering what the brake force flash option looks like when you're coding.
I really like it, and I think it grabs your attention more than just "more brake lights".
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
07-02-2018, 11:14 AM | #2 |
Rep 29
How did you code it? (What is it under?) Its not in the code sheet in the main coding thread and according to this google doc it did not work?
https://docs.google.com/spreadsheets...8JY/edit#gid=0 |
07-02-2018, 06:50 PM | #3 |
Rep 254
Didn't work on mine. I tested it a few times and it threw out an error every time I slammed on the brakes. I don't remember what it was as it was a while ago, so I gave up.
07-02-2018, 07:19 PM | #4 |
482
Rep 317
I don't think you can, the US spec tail light on the X5 not have the bottom led light (where the rear fog lights are), its blank, you cant even retrofit the rear fog light switch like you can on the F01 7 series or F10 5 series.
07-03-2018, 09:27 AM | #5 |
88
Rep 366
I actually did it through the Bimmercode app.
And, I think you CAN code rear fog lights on, but its not the same as the Euro lights.
07-03-2018, 10:29 PM | #6 | |
Rep 475
01-02-2020, 11:26 AM | #8 |
Rep 7
01-02-2020, 06:42 PM | #9 |
231
Rep 369
I have that coded on mine but no error message
Current
07-28-2022, 04:48 PM | #10 |
Rep 4
I coded it to my X6 I have the same issue though getting a "lighting system malfunction" after talking to bimmer code this is the response I got "Hi,
this coding does not work for the X6 and this is why it is not included in the basic coding mode also." |
01-16-2023, 01:01 PM | #11 |
Rep 234
Is this not possible on US spec? I coded the flashing and hazards to come on and this morning I got the lighting system malfunction warning and no hazards. I haven’t confirmed if the flashing operates yet or if it just threw the error.
Is there a workaround or should I just code back to default and forget it? This worked flawlessly on my f30 so it’s a little disappointing if it can’t work.
01-17-2023, 04:14 PM | #12 | |
Rep 7,519
FRM coding may work whereas BDC or FEM or REM may or may not work.
01-17-2023, 04:31 PM | #13 | |
Rep 234
01-17-2023, 08:38 PM | #14 |
Rep 2,514
I can't find the thread rn but if I remember correctly for US spec model it required additional module to be added in order to emulate this feature. Or you will need euro spec taillights.
UPD: Found the thread: https://f15.bimmerpost.com/forums/sh....php?t=1453039 |
01-17-2023, 10:05 PM | #15 | |
Rep 234
I did confirm that when I had flashing and hazards coded it didn’t function and I got an error on the screen. I removed the hazard coding and left the flashing and still got the error. So I reverted the coding to stock and activated hazards and the system functions as expected, so it’s just the flashing that doesn’t seem to work. Now this evening I finished my rear fog retrofit and I’m understanding from previous posts that by doing this I will lose my brake force display, so I’ll be testing this to see if I still have my stock brake force or if I lost it, but my hazards still come on after an emergency stop.
