06-05-2023, 01:49 PM | #1 |
Rep 161
Towbar Wiring
Folks, has anyone fitted a towbar to an F15 and done the wiring yourself? If so, what wiring kit did you use? There seem to be a few kits which require the parking sensor button to be pressed to deactivate the rear sensors when towing, and I can only see 1 kit that deactivates the sensors automatically.
In my E70 the sensors went off automatically, but I don’t know if it’s worth paying an extra £60/70 for the privilege! Just wondering if the likes of the ECS kit is grand, and if pressing the button is that much of an inconvenience?! Thanks! |
06-07-2023, 08:28 PM | #3 |
128
Rep 301
Parts via bimmerworld think all the normal players have the parts
Wiring: 82712349500 Module: 63119463372 etrailer did the Draw-Tite class 3 and a 7/4pin mount Do towing coding via bimmer remote, wish I did the manual camera option. You’ll be good to go with that setup. I paid an Indy shop for install under $500 Sensors get deactivated when you plug into the oem wiring. If you have a bike rack or anything not plugged it sensors will go crazy. Just realized you are in Europe might differ slightly! |
06-08-2023, 12:05 AM | #4 |
Rep 243
Get the Tenkonsha wiring kit. Honestly not a big deal to hear the sensor beep for a few seconds you will be in reverse. It's less than a $100 and easy to install without any cutting or splicing of wires.
