02-13-2020, 12:06 PM | #89 |
Rep 592
02-13-2020, 05:37 PM | #91 |
Rep 90
Drives: 2017 F86 X6M Donington Grey
RF 17s
9
02-16-2020, 02:27 PM | #94 |
Rep 90
Thanks man. I got it from eBay for around $260 shipped. Fitment is on point and it wasn't difficult to install. Unlike my F30 MP splitters which primarily bolted underneath with 3m in the front, this kit you have to drill (6) holes in front bumper to hold the weight of the splitter. I don't really have to worry about it being damage since I'm not lowered like my F30 was but overall I'm satisfied with it though.
02-17-2020, 03:10 PM | #95 |
Rep 592
02-17-2020, 09:29 PM | #96 | |
Rep 90
02-18-2020, 06:35 AM | #97 |
Rep 32
02-20-2020, 11:33 AM | #98 |
Rep 592
02-28-2020, 05:52 AM | #99 |
Rep 162
Thinking of going down the 22” route, what’s the issues with TPMS ?
If I buy after market wheels with TPMS/RDK sensors fitted will they need coded and If so is this a dealer visit to do the job ? On the other hand, if I buy used OEM 21” with OEM TPMS will they just fit right on and away I go or might these also need coded ? Thanks,
cr55
02-28-2020, 11:11 AM | #100 | |
Rep 149
One caveat, keep the old wheelset and sensors away from the car so it doesn't connect to the old sensors over the new ones. |
02-28-2020, 11:59 AM | #101 | |
Rep 162
Perfect - thanks
cr55
01-28-2022, 08:01 PM | #106 |
Enrique
Rep 21
I know post its already outdated, i have been reading that bmw i the rear the inner wears out. Im not lowering but adding 22rims” 295/335 how can i make sure the tire last as long as possible even if the align is ok?
01-28-2022, 08:17 PM | #107 | |
Rep 164
01-28-2022, 08:19 PM | #109 | ||
Enrique
Rep 21
I know but i read that bwm's rear inner wear out faster even tho its aligned properly |
01-28-2022, 08:22 PM | #110 |
Rep 149
This is somewhat correct but this affects all size rims/tires to some degree. The issue is not alignment or rim/tire selection but rather the aggressive rear camber to improve handling of the vehicle. Common issue with German cars regardless of brand, from what I understand. I had this happen on both my stock 19” rims with winter tires as well as my 22” summer setup with high performance tires so not sure it’s avoidable. If you have a squared setup, you can rotate the baks to the front every few months which will delay this 1.5” wear strip on the inside of the tires. That shared, you should start with a shop that focuses on suspension or can check the geometry. Hope that helps!
