04-23-2017, 02:45 PM | #1 |
Rep 66
Coin under cupholder, removal.
I had a coin under my cupholder which turned me crazy, it rolls everytime back and forth, I checked other forums and found how to remove it from a E70 but nothing on F85, well today I remove it, this is how...
On last picture in the circle there is a groove if you place your finger there you will feel the coin coming and go, with patience you can get it out without dismantle the whole thing. Picture 1, with a plastic tool remove the cover, it has 4 clips on the corners. Picture 2, Disconnect all cables, from the buttons module and from Idrive controller. Picture 3, remove 4 screws that holds the brake and AutoHold chrome piece in place Picture 4, Disconnect the cable from Brake module, ONCE LOOSE YOU HAVE TO TURN THIS PIECE 90 DEGREES TO REMOVE IT FROM THE GEAR HANDLE. Picture 5, Remove 4 screws that holds the gear selector module in place. Picture 6, Under the gear module you can find the groove, you have to put your finger in it, if you cannot feel the coin just turn on the car, place in D or R and move it to make the coin roll. Last edited by mgaciah; 04-23-2017 at 02:52 PM.. |
04-23-2017, 06:18 PM | #2 |
Rep 18,713
Good job.
It has been discussed couple times in the F15/F16 section. Don't forget that F85/F86 are the same car as the F15/F16 on most of the parts.
