09-07-2014, 12:09 AM | #67 |
Rep 1,377
To clarify, there's no official OEM retrofit kit, but the cluster is a 100% OEM part. It wouldn't work otherwise. The poster from HK is using an OEM part, too. It might not be the actual part number specified for the F15/F16, but clusters from the F10/F11/F12 chassis are physically and electrically compatible. General availability of the actual part for the F15/F16 just happened.
The retrofit physically has been possible since the F15 launch. But coding wasn't possible because the car's software wasn't able to communicate. I believe the I-Level corresponding to 52.0 (~July?) enabled it due to the 6WB option availability in the X5/X6 and SOP of those cars. If you tried to add 6WB to your VO it wouldn't work if you were running an I-Level lower. (This I-Level was also the one that added new icons into iDrive Navigation.) The rear carbon fiber cover has no cut out for a hitch.
09-07-2014, 11:24 AM | #68 |
Rep 774
09-09-2014, 02:26 AM | #70 |
Rep 3,990
Just an update for everyone. I contacted Bimmer-Tech regarding when my 6WB Digital Display Cluster will be shipped and I got this response from them:
Hi Omar, We should receive it from BMW by the end of this week so you should receive it from us by the end of next week. Kind regards, Patryk Matysiak BimmerTech Tel: (646)-439-7920 (USA) Tel: +48 792-111-152 (Europe) Email: info@bimmer-tech.net Website: www.bimmer-tech.net
09-18-2014, 06:22 AM | #71 |
Rep 3,990
Just another update. My 6WB cluster was shipped late night tuesday from Warsaw, Poland. It is currently in Cincinnati, OH. I should get it either by tomorrow or Saturday (hopefully). I'm going to FA code 6WB today or tomorrow into my vehicle so I get that out of the way before the cluster arrives.
09-18-2014, 12:23 PM | #72 | |
Rep 1,377
09-18-2014, 01:26 PM | #73 |
Rep 3,990
Ah, keep forgetting to check this. Thanks for reminding me . I'll take a look today at some point and reconfirm with you.
09-18-2014, 01:46 PM | #74 | |
Rep 535
Omar thanks for all the help! I can't wait to see your steering wheel retrofit and this new instrument cluster. |
09-18-2014, 01:56 PM | #75 |
Rep 3,990
He didn't PM me...do you mean he PMed you? Yeah, I'm a little busy right now, but I can help you out in about an hour or so.
09-18-2014, 05:33 PM | #76 |
Rep 3,990
@wdimagineer, my I-Level is F025-14-03-503. This I-Level is one step below 53.0 (F025-14-07-502), which I am currently using. I checked the I-Level pdf sheet and it shows 52.3 and 52.4 match my current I-Level. Will I be ok or do I have to get the software update from BMW? This is the I-Level PDF I referenced from @shawnsheridan: http://www.bimmerfest.com/forums/att...6&d=1406976367
09-18-2014, 07:19 PM | #77 | ||
Rep 1,377
Opasha - I'd update first. I'm not 100% certain when support was introduced. I heard 53.0.
09-18-2014, 07:27 PM | #78 |
Rep 3,990
No need to apologize, my friend. Thank you for the response. Is it ok for me to try with my current I-level first just to see or will it cause errors? I want to just make sure this method is doable in case others who have similar I-levels can install without a dealer update (since these updates usually wipe all fdl coding right?).
09-18-2014, 10:32 PM | #79 | |
Rep 1,377
09-18-2014, 11:50 PM | #80 |
Rep 3,990
I'll call Bimmer-tech tomorrow and ask them. I totally understand what you mean. Always best to be cautious. Thanks again!
09-20-2014, 01:53 AM | #81 |
Rep 1,377
Here's what to look forward to once you're done installing.
09-20-2014, 01:55 AM | #82 |
Rep 1,377
2 more. Forgot how bad this app is sometimes.
09-20-2014, 02:05 AM | #83 |
Rep 3,990
Thanks @wdimagineer. It looks great! I should have this done by this morning around 11-12pm and then a full installation guide with pictures will be up shortly after .
09-20-2014, 02:39 AM | #85 |
Rep 1,377
Bimmer-Tech has them available for around $1600.
09-20-2014, 02:53 AM | #86 |
Rep 3,990
As @wdimagineer said, Bimmer-Tech has it. Here is the link I posted on page 2: http://www.bimmer-tech.net/shop/bmw-...panel-retrofit.
09-20-2014, 07:42 AM | #87 | |
Rep 2,697
09-20-2014, 08:11 AM | #88 |
Rep 1,133
Has anyone tried getting these from GetBMWParts? I'm wondering if the price might be better or at least faster shipping?
It's good to be bad
