      11-18-2016, 07:28 AM   #1
TallTrees
TallTrees's Avatar
Drives: 2014 X5 35d M Sport
LED headlight Issue?
I'm pretty sure I read a post at some point where one of you were talking about one half of your LED headlight not being on. Can't for the life of me find it now. Anyways I just notice last night that one half of my drivers side LED headlight is not illuminating at low beam. Is this normal? I have coded Anti-dazzle and allow fogs on when /parking lights. Both of these work as expected.
My thought is that half of the LED is burnt out BUT that's unlikely as LED's have a crazy long lifespan AND when I turn on high beams both side of the bulb light up. Don't want to take it to the dealer and have them blow away all of my coding if that's the problem. Wondering what you guys think. Thx!
      11-18-2016, 07:40 AM   #2
Nonopr01
Drives: 2017 BMW M3
DO you have your steering straight ahead when you took this photo?
      11-18-2016, 08:45 AM   #3
Terp335
116
Drives: E90 2011 335i M Sport
I think it's more likely that the coding you did for anti-dazzle impacted the light vs anything else. Whether you're seeing something caused by the tunneling effect driven by the glare off of the savanna in front of you or it's a defect in the code, I don't know. I've not seen the headlights go on and off like that for a turn of the steering wheel. AFAIK it's only the fogs that do that.
      11-18-2016, 08:45 AM   #4
TallTrees
TallTrees's Avatar
yes steering straight for sure.
      11-18-2016, 08:49 AM   #5
TallTrees
TallTrees's Avatar
I think coding also...I need a coding expert to help me narrow down what I should be looking for.
      11-18-2016, 09:40 AM   #6
Doanster
Doanster's Avatar
627
Yes, it's due to Anti-Glare coding. Most likely due to wanting to absolutely ensure no blinding of oncoming traffic under normal driving conditions (driver's side hump is smaller). Even though it may look awkward, it doesn't affect the overall vision IMO.
You can confirm the section still illuminates by putting the car into reverse. Everything lights up...
Terp335115.50
TallTrees148.00
      11-18-2016, 11:01 AM   #7
Terp335
116
Great info as usual!
      11-18-2016, 11:52 AM   #8
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
you may be referring to my original posts on the matter:
http://f15.bimmerpost.com/forums/sho...&postcount=141
http://f15.bimmerpost.com/forums/sho...php?p=19810599
      11-18-2016, 12:27 PM   #9
TallTrees
TallTrees's Avatar
Originally Posted by iconoclast View Post
Yes it was your post..Thx for that. So where did you end up with it? Do I just have to live with it?
I haven't programmed auto fogs on or handles on in reverse BTW.
      11-18-2016, 01:25 PM   #10
iconoclast
iconoclast's Avatar
7266
The vehicle was coded with 100% LED Corona Lights and the issue went away.
There was no other way to resolve it without having one LED out or the beam looking like it was dipped in Tourist Solution mode.
The way it sits now is standard beam pattern with the EU/ROW Anti-Dazzle coded. Everything works as designed and has the appropriate beam pattern.
      11-18-2016, 04:05 PM   #11
brianhn1
Slow Mo
15
Drives: BMW
Ever since this thread came up, I did sleuthing and I have the same issues as you did. When you said you recoded a 2nd time in the other thread, did you do the same coding as the V2 documented steps and do 100% LED corona intensity to get the double hump back?
BMW '17 X5 35i, '15 M4, ED 7/1/14, US 8/4/14, PU 8/18/14, '13 X5 35i, '08 335i
Motorcycles: BMW '12 R1200GS, '10 F800GS, '74 R90S
      11-18-2016, 09:10 PM   #12
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You can PM me your FA, SVT, and NCD's and I can check values.
      11-18-2016, 10:09 PM   #13
iconoclast
iconoclast's Avatar
7266
yes. the coding was reset to original parameters then redone with 100% drl. issue resolved.
Almaretto2374.00
      11-18-2016, 10:30 PM   #14
Almaretto
Almaretto's Avatar
2374
That looks familiar.
      11-21-2016, 01:21 AM   #15
megabmw
megabmw's Avatar
52
Drives: GT 630dx and i3
I noticed this morning mine have the same thing with the light, it is the adaptive light function that goes in motion. When I turned the headlight switch from (A) automatic to 1 (ON) all leds turn as they should.
      11-21-2016, 01:44 AM   #16
Almaretto
Almaretto's Avatar
2374
Do you have this coded?
      11-21-2016, 04:24 AM   #17
megabmw
megabmw's Avatar
52
My car is stock with these functions. European car.
No coding yet, just got it last week
      11-21-2016, 07:59 AM   #18
TallTrees
TallTrees's Avatar
The code says production post 06/15. My X5 is a 2014...any ideas?
Edit: I looked for the FLE Module...couldn't find it. Guessing they added after 06/15.
After some more testing here's what I found
Added HBA Active when Headlights on manually LDS in A or 2 no change.
If I switch from #3 Auto driving lights to #6 Lowbeam lights the drivers side half light comes back on.
      11-21-2016, 01:53 PM   #19
TallTrees
TallTrees's Avatar
You're going to laugh but I'm not sure how to send you these(ie where they are located). I'd love to have you take a look.
      11-21-2016, 02:55 PM   #20
Almaretto
Almaretto's Avatar
2374
TMS and LHM were the older lighting modules, still found in F10 and F8x. They were replaced by FLE in newer F15's and 2016 F3x's. The G-series have even newer different ones.
PM-'D guides which include summary page that explains saving and other helpful hints.
EDIT: Saving Instructions. There is no attachment button in PM's, so they must be linked using cloud service (eg, Dropbox, Onedrive, etc).
Saving FA, SVT, CAFD
• FA's & SVT's must be saved to computer, with associated "Save" button if you want backup copy.
• NCD's are automatically written to computer when you hit "Read Coding Data." And, they are overwritten if present in C:\data\CAF directory when "Read Coding Data" again or save changes with floppy disk icon in FDL-Editor.
      12-02-2016, 10:10 AM   #21
MochiEater
Drives: 2017 X5 40e
So is my understanding correct that this driver's side half dark LED low beam is normal for USA cars coded with VLD?
Can anybody with a stock non-USA car with Variable Light Distribution tell us whether their driver's side LED headlight half dark is normal for low beam?
Like OP I am in the USA and coded VLD and GFHB and I also have the driver's side LED headlight half dark. Also, from following another family car, it looks like the driver's side LED stays half dark even at highway speeds (65 mph/104 kph). My driver's side LED can be fully lit up if I switch from A automatic headlights to manual headlights. Is the driver's side LED always half dark for VLD under all conditions?
      12-13-2016, 08:20 PM   #22
08bmw128i
Drives: 2018 X5M
I just noticed the half dark headlight on my us spec with vld and gfhb coding. seems weird to me. i'm missing out on some light lol
