11-21-2023, 02:57 PM | #1 |
Rep 39
Rebuilt Motor - Ista Errors (Elec)
Hi all,
I have just finished rebuilding my S63tu (15' X5M). I bought the motor with 2 spun big ends, the car ran (albeit with a loud knock) before rebuilding. I am getting quite a few electrical errors which I am having trouble diagnosing. A foreword on the errors, I am quite sure I have connected all grounds, however this is slightly different to my E70 50i which I rebuilt, so would like a second opinion. Grounds are the two on the main harness cover above engine, 4x on injector clamps, 1x for radiator fan and thats it? I left the box in the car so the gearbox, diff and exhaust ground were not touched. The smaller battery is brand new. The larger isn't however it holds voltage, I have also tried another battery out of my other X5 (battery near new). I will test continuity on the relevant circuits below in the coming days, however remembering that the car ran without these errors prior to rebuild, so I doubt (hopefully) that anything is wrong with the harness. Errors below, any help would be appreciated. E12C01, 804951 Left fuel level sensor, short circuit to B+ (or line disconnection) DE8C5E LIN SINE, communication fault 20A504 Turbocharger - coolant pump, actuation: line disconnection 1C4119 - Engine oil temperature sensor, electrical: malfunction 136208 Valvetronic system 2: No movement identified 152021 Relay, ignition and injectors, supply voltage, ignition 2 : Short cuircuit to B+ 133011 Valvetronic, supply voltage: Malfunction, secondary retraction, voltage supply 135608 Valvetronic system: No movement identified 133104 valvetronic relay, activation: Line disconnection 1F4A10 Relay, ignition and injectors, activation: Line disconnection 109001 Collant temperature sensor, electrical: Short circuit to B+ CD9001 LIN, message: auxillary coolant pump for charge ari cooler: missing CD8E12: LIN, message, alternator: Missing 10A001 Radiator outlet temperature sensor, electrical: Short cuirt to B+ or open line |
