07-26-2014, 06:46 AM | #199 |
12
Rep 80
I've been following this thread as I also wanted to get this chip but apparently it looks like it is a piece of junk.
Thoughts based on this thread as well as the one about 5.0i. Any other alternatives to 3.0d? (3.5d US market) |
07-26-2014, 09:23 AM | #200 |
Rep 113
I've put 3,500+ miles on our X5 in the past month, with the Race Chips installed. Zero issues. I think the "issues" are rooted in something else, but that's just me.
'14 X5 35d Space Grey/Dakota Black
'12 BMW F 800 GS Trophy '09 Mercedes Benz E63 AMG '09 Discovery III HSE- '05 Range Rover HSE '86 DEFENDER 110 RHD TDI- '72 SERIES III 88 2.25L |
07-26-2014, 01:49 PM | #203 |
Rep 710
What do you think?
07-26-2014, 02:31 PM | #204 |
Rep 113
There was a firmware update that was released just as our initial orders were put in. Did you update yours before you installed? It may make no difference or it may make a huge difference. The unit is super simple in its design. There aren't many internal components. It's one of those things that will either work or not work.
07-26-2014, 08:38 PM | #205 |
Rep 710
That's a good point, and no I have not looked for the firmware update - thanks for the info as customer service didn't mention this.
And I agree - the design and software is super simple. That's why we were looking at the harness first in case there is a bad crimp.
07-27-2014, 08:56 PM | #206 | |
Rep 710
07-28-2014, 12:25 AM | #207 |
12
Rep 80
Software upgrades should not be my problem. If a box is released it should be first tested thoroughly.
For most people it works but apparently there are some that experienced problems with this device. I won't take the chance. Thanks! Was also wondering how much the DPF is going to suffer with this upgrade. Increased fuel means increased smoke and higher workload on the filters. |
07-28-2014, 08:53 PM | #208 | |
Rep 710
If you are talking about the DEF fluid, I wouldn't be too concerned as there's enough in the tank for nearly 10,000 miles. Keeping your foot in it might bring it down to 8,000 miles. The cost of DEF is pretty cheap too. If you really want an eye opener, call AC Schnitzler and ask them about their little black box. Same stats, but it goes for more than $5k. I think it's explained by their warranty. In addition, here is a direct quote on their tuning: Engine tuning and performance upgrades have a long tradition at AC Schnitzer. To be on the safe side however, we prefer not to extract the maximum possible power but instead ensure greater robustness, which means a longer life of the engine. Many of our performance upgrades are therefore designed for an increase in torque rather than an increase in horsepower. Because torque is what you feel when for example you're "pressed back in the seat" on pulling away. Check out the price here: http://preisliste.ac-schnitzer.de/ac...e_id_auswahl=1
08-04-2014, 03:08 PM | #209 |
Rep 198
Will this affect the warranty?
I know VW (in Canada) will void the warranty if you do any mods (engine/suspension) on the car. Is there a place in Canada - Vancouver where you can chip your X5 35d? |
08-07-2014, 09:25 PM | #210 |
Rep 710
My last comment on this chip is, you really need to play around with it to find the sweet spot. Mine came in as E0 and I tried all sorts of combinations. I've settled with 00 since it provides just a little better throttle response and my mpg jumped to 30-ish mpg, same mixed driving I've been doing since I bought the car. I also find that the computer is about 2mpg higher than what works out on paper. This last fill up with the 00 setting gave me 30.2 mpg compared to the E0 setting of 28.6 mpg.
And, we never determined what the CEL was a couple weeks ago. It came on, went away on its own and hasn't returned.
08-08-2014, 06:28 PM | #212 | |
Rep 113
08-08-2014, 07:48 PM | #213 | |
Rep 710
S2 = amount of fuel
08-08-2014, 08:03 PM | #214 |
Rep 113
Thanks, Four Two. I'll play around with my settings this weekend. I had always assumed that S1 should always be "E" and S2 adjusted the power gain/fuel sprayed. I'm currently @ E/2. So, is "E" advancing the duration by 5 degrees from stock, if "A" is the baseline?
08-08-2014, 08:48 PM | #215 | |
Rep 710
S2 is the amount of fuel and is throttle response and horse power. Each click is 1.5% and is set at 20% from the mfg. I turned mine up all the way and there was no recognizable difference over what I settled with. That's when I played with it for economy and settled with 2 clicks over the factory setting.
08-26-2014, 12:23 PM | #216 |
Rep 137
Hi All,
Sorry if this has been asked already. It seems some people are concerned with whether the engine is designed to handle the additional power this chip will give. What about the transmission ? I ask because it seems there are a few different variant of the ZF 8 speed transmission, each designed to handle different levels of HP and torque. For example I would think the transmission in the M50D is not the same as the one in the 35D . Even though they're both ZF 8 spd . I would imagine the ones rated for higher HP would be more expensive than the ones rated for less. Why would BMW pay more for a transmission if they didn't have to ? So what does the increased torque do to the 35D transmission over long term ? Anyone has insights ? |
08-26-2014, 12:39 PM | #217 | |
Rep 971
08-26-2014, 02:09 PM | #218 |
Rep 424
I've never bought one of these 'tuning' boxes though can someone tell me how many electrical harness connectors it has? 2 (male) + 2 (female) I guess? One pair inserted in the fuel rail pressure transducer loop and one in the turbo boost pressure transducer loop?
X5 F15 - gone after 5 months!
08-26-2014, 02:29 PM | #219 | |
Rep 424
You can't have more POWER without producing more TORQUE unless, that is, your engine can produce that SAME TORQUE at an increased RPM. You can make a more meaningful comparison of the performance of a tuned engine by comparing the 'before and after' torque curves. The larger the area under the torque curve the greater the 'overall' performance, max POWER values do not tell the whole story! Do these experts think they're addressing an audience, the bulk of whom are idiots?
