12-11-2018, 11:11 AM | #1 |
Rep 748
Cold weather and two questions
Hello everyone!
It is pretty cold around here now, and two issue popped up. I would like to ask if anyone experienced following. After cold morning start, (about 20 degrees F), for the first 20-25 min drivers side heater blows warm air, but every like 30-45 sec blows cold air. I can hear how something opens/ closes inside the dash and airflow is being changed to cold. Also, after rear defroster turned on, does it stay on constantly? I thought it supposed to turn off after "some" time? Thank you. 2017 X5 Winter package
12-11-2018, 12:42 PM | #2 |
Rep 1,222
Hi - regarding your first question, no, I do not experience the blasts of cold air. Did you try adjusting the red/blue color wheel (or whatever it is referred to)? If your temperature is set high, but color wheel is on blue (cooler) that may be creating the variation you experience.
As to the second issue, I would also expect the rear defroster to turn off after a while; however, I am not sure. |
12-12-2018, 08:24 AM | #3 | |
Rep 748
12-12-2018, 09:04 AM | #4 | |
Rep 7,498
If you have the stratified air dial turned all the way to the red (this is the dial in the center of the dash's middle face vent)...then you have it set to always send HEATED air. But we have NOT clue as to what temperature you have set on the control panel. If you have the temp set at...let's say 72°F...and the stratified air dial set all the way to the RED...if the temp inside the cabin gets higher than 72°F...then it will blow cooler air into the cabin to maintain the set temperature if you are using the AUTO setting. So again, not knowing what you know or how you have the control panel set...it could simply be operator error...or not having a complete grasp of how the automatic climate system works along with the stratified air dial for the face vents (dash vents) that allow you to temper the air cooler/warmer than the set temp on the control panel. Have you tried setting the temp on the control panel to a comfortable temp for you (where you don't need to keep changing it)...then set the stratified air dial in the dash's center vent to NEUTRAL (halfway between blue and red setting)...then set the IHKA control panel on AUTO. See if you still get the blast of cold air every 30-45 seconds (probably the system trying to maintain the temp setting you've selected along with blasting heated air from the face vents based on the setting of the stratified air dial).
12-12-2018, 09:18 AM | #5 | |
Rep 748
Ok, ok, Temperature dial is all the way up.( 84 F ). Auto is not engaged. Honestly i never engage AUTO, as i sort of like to be in control))). Air is warm, but every about 45 sec blasts cold air for about 20 sec.
12-12-2018, 09:30 AM | #6 |
Rep 7,498
Ahhh...before taking it her in to the dealership...I' would try a different setting (perhaps "testing" the AUTO feature).
From what you just explained in post #5...it could almost be compared to setting your home's thermostat on 84°F...then your spouse or children are cracking open a window to cool the room down. You could even try lowering the temp (to somewhere in the 70°-75°F range), and setting the stratified air dial on neutral (or perhaps one or two clicks into the red if you're really that cold)...and still NOT use the AUTO button...then see if you still get the blasts of cold air.
12-12-2018, 10:17 AM | #7 | |
Rep 748
12-12-2018, 11:11 AM | #8 |
Rep 1,497
Something I'm curious about is even with the thermostat on 65 and air vent dial all the way down with blue the car still puts out warm air. It's cold here in TN but I'm hot natured and sweat easily. I shouldn't have to turn the AC to get cooler air if desired. It's almost as if the car is smart enough to know the outside temp is cold and no matter what the thermostat is set on it will spit out warm air.
12-12-2018, 11:33 AM | #9 | |
Rep 7,498
If you don't want the AC compressor to turn on...then do not engage the AUTO setting. Here's some info about the IHKA control panel and how the climate control system may operate depending on different settings and data from various sensors: https://www.newtis.info/tisv2/a/en/f...ons/1VnXUDTv1I
12-13-2018, 08:38 AM | #10 |
Rep 748
It appears that my driver side thinks it is always in AUTO mode. Despite the fact that it is NOT. I will take her to the dealer after the holidays.
PS I checked with bimmercode if anything was coded. Negative. PPS Can anyone confirm if rear defroster turns off by itself after "some" time?
12-13-2018, 10:40 AM | #11 | |
Rep 1,497
01-24-2019, 11:51 AM | #12 |
Rep 272
Wondering to see if OP found a resolution to this.
Mine is also behaving similar to OPs with cold air every 30-40 seconds. I followed all of Qsilver7 suggestions and have still experienced this behavior. |
01-24-2019, 12:32 PM | #13 |
Rep 748
Yes, after a trip to a dealer issue was resolved. The unit was re-set and calibrated. The issue is gone.
01-24-2019, 03:59 PM | #15 |
Rep 272
So made my appointment but now I'm not sure if it's the same behavior anymore. Now only cold air blows from the dash vents no matter what the settings are for the control panel or vent. However, consistent heat is coming from the defrost, foot and rear vents.
Guess we'll find out on the 31st. |
01-26-2019, 10:28 AM | #18 | |
Rep 131
I had been informed after approx. 30 minutes rear defrost turns off, but never noticed as I turn off immediately once window is clear. |
