07-14-2023, 09:18 AM | #1 |
Haihan
128
Rep 39
HELP NEEDED: front tire feathering
Hello all,
I’ve been struggling with the front tire featuring issue for years and no one has provided a solution that can effectively address it. Thus I’m looking for some wisdom here. I have owned the car since it was brand new on the lot with white protective films still on it. It is a 2018 model and currently has 80,000 miles on it. 70% highway, normal driving and no abuse. I’m on my third set of tires and feathering happened to every set of front tires at round 8/32 tread (rear ones never had a issue). I have asked BMW dealer to investigate this issue every time I was in for serveice, but they kept saying it’s due to the car’s suspension setting and it’s how the car is. Wheel alignment at dealer twice failed to make any difference. I know this is not going to prevent me from driving and enjoying my car every day but the road noise is really annoying. Anyone can help here? Thanks in advance! |
07-14-2023, 09:26 AM | #2 |
Rep 25
I have same issue on my wife's 2017 x3. It's like it is chewing the outside of the tire. the car has never been abused or driven aggressively.
I will follow this thread. |
07-14-2023, 09:33 AM | #3 |
Rep 660
I’m afraid the dealer is correct. It’s normal for the X5/X6 to feather the outside edge, but not normal in general.
It’s a suspension flaw in the front and there isn’t an adjustment point to correct the positive camber. That’s why alignments won’t really adequately address the issue. I do believe there are some aftermarket solutions that can help. I’ve opted to live with it until I refresh the suspension. |
07-14-2023, 09:46 AM | #4 |
Rep 41
Its normal for this chassis to wear the outer front tire edge. There isn't enough negative camber, and there is no camber adjustment, as others have mentioned.
Fortunately, Meyle has come out with a solution to allow adjustment at the upper wishbone. You can get about -0.9 deg of negative camber which will cure the tire wear and make the vehicle turn better. The other solutions, like KMAC adjustable bushings, don't work - they loosen up. Finally, the X5M solutions are quite a bit more expensive. These Meyle parts are no-brainers in my opinion, BUT there's a good bit of labor to get them in. Right: https://www.fcpeuro.com/products/bmw...ly-31126863786 Left: https://www.fcpeuro.com/products/bmw...hd-31126863785 |
Tomcat_F15_STL149.50 |
07-14-2023, 11:10 AM | #5 |
Rep 1,544
I had the same issue on my E70 with adaptive drive. Does your car have dynamic drive? The only thing that really fixed it was changing the toe to as close to 0 without being 0 and changing the upper control arms to give some more negative camber.
07-14-2023, 01:33 PM | #6 | |
Haihan
128
Rep 39
07-14-2023, 01:45 PM | #7 | |
Rep 660
FCP Euro has a nice user guide (Click Here) for the X5/X6 suspension with DIY how to videos. There is also a section where they mention the issue with the front upper wishbone. |
07-14-2023, 01:47 PM | #8 | |
Haihan
128
Rep 39
07-14-2023, 01:52 PM | #9 |
Haihan
128
Rep 39
My car does not have dynamic handling package. Not sure if it is even a package available for f16. Negative camber makes sense.
07-14-2023, 01:58 PM | #10 | |
Haihan
128
Rep 39
Wondering if simply airing down the front tires could create more tire contact and even out the tread wear. If so, that would be much easier. |
07-14-2023, 02:20 PM | #11 | |
Rep 660
Air Pressure wear factors: Higher = more center / less outer - better MPG, less wet traction Lower = more outer /less center - less MPG, better wet traction |
07-14-2023, 06:10 PM | #12 | |
Haihan
128
Rep 39
07-15-2023, 02:18 PM | #16 |
Haihan
128
Rep 39
