06-01-2020, 11:20 AM | #1 |
462
Rep 312
Transmission Service on 50i
I bought a transmission service kit from FCP this last week and performed the service Saturday. It was straightforward and easy enough. I measured what I got out of the pan and it was right at 4 quarts. I put the new pan on, and began refilling it on level ground. The tranny only took 3 quarts of oil, so I heated up the tranny went through the gears even took it out for a drive. Car shifted perfectly no issues.
I then tried to top off the fluid again and the X5 wouldn't take any more fluid. So where the did the extra quart go?? Everything is shifting fine, not sure what is happening that it won't take more fluid. |
06-01-2020, 11:58 AM | #3 | |
Rep 1,564
PROTIP: Pickup a cheap welding blanket from harbor freight to wrap your exhaust in next to the fill port to keep your flesh on your arms... PROTIP 2 - Loosening the valve body (dont remove, just loosen) allows nearly 2 more quarts to drain from the transmission for around 6 total, allowing for a more complete oil change. Last edited by Sophisticated Redneck; 06-01-2020 at 12:04 PM.. |
201201.50 princelybug59.50 |
06-01-2020, 12:45 PM | #4 | |
462
Rep 312
06-01-2020, 01:11 PM | #5 |
462
Rep 312
06-01-2020, 01:13 PM | #6 |
Rep 46
06-01-2020, 05:52 PM | #9 |
Rep 1,564
Ya its not alot of fun being underneath 5300lbs while its running but only way to get that last bit in as it drains from the torque converter as soon as its shut off.
To think all of this hassle could be solved by a transmission dipstick you could fill from....remember those? |
Seattlesquash961.00 |
06-15-2020, 01:31 PM | #10 | |
Rep 104
Has anyone else done "PROTIP 2"? seems like a good idea, but haven't seen any other DIY's or instructions that explain this step in detail. Any risks with loosening/re-tightening all of those valve body/mechatronics asm bolts(something like 18 of them)? |
06-15-2020, 01:34 PM | #11 |
1658
Rep 2,995
I'm not sure I like that idea. Unless you put a new seal /gasket.
06-15-2020, 09:21 PM | #12 |
Rep 1,564
I scan in and post up the torque sequence and spec tomorrow (traveling right now). There is no risk as you tighten everything back up to spec. I have done it several times and at 154,000 miles now on orginal transmission
06-15-2020, 09:24 PM | #13 |
Rep 1,564
No gasket from the valve body to transmission, there is a gasket between the valve body halves but the valve body itself will not be taken apart or loosened. When I post up the scanned image it will make it more clear. We are just loosening the bolts that hold the entire valve body to the transmission and just lowering it about 1/16th if an inch, no bolts are actually removed.
06-15-2020, 09:47 PM | #14 | |
1658
Rep 2,995
05-17-2022, 09:44 PM | #15 |
Rep 12
Hi,
I am puzzled and can't decide what to do. I had a hard time to get the car perfectly leveled for the fluid (and pan) change. First fill took ~4.5l. The car was on a slight slope. Front wheels up 2 deg and right side up 2deg. I thought that, since the fill plug is on the back-right of the pan I could've under filled, so I decides to try to find another spot on my driveway and I was able to add about 0.5l extra to total of ~5l. On the second fill the front wheels were up 1deg and right side was up 3deg. That rose the fill plug location, which could promote overfilling. Now I am not sure if that was a good decision to pursue second fill. The shifting seems to be rougher at slow accelerations with 5l fluid vs 4.5l. (Or I may be paranoid) What do you Guys think, chill and live with 5l or drain that 0.5l. Could 0.5l overfill be damaging for tranny? Thanks! |
05-19-2022, 11:51 AM | #16 |
Rep 1,497
How about a tranny with 112K miles on it? I took ownership at 50K miles and have yet to do a tranny fluid service. Others have stated given the amount of miles they wouldn't touch it.
05-21-2022, 07:28 PM | #17 |
Rep 271
I did this service today (2015 X5 35d) and it was fairly straight forward if you're fairly comfortable working on cars. Not a newbie job IMO. I used 4 wheel ramps in the garage which is very secure and gives sufficient room to work (although still kinda tight). I didn't realize that the structural piece straddling the transfer case needed to be loosened to access the rear tranny cover screws - not a big deal but another step. I added most of a litre of new ZF fluid to the pan and filter before putting it on as I use a 250ml syringe arrangement so any saving of refills was welcome. Like others, I got about 3.5l in when cold and not running. I hooked up ISTA to monitor the fluid temp when I started the car - worked great but took a while as the wheels were on ramps and not spinning - I shifted from Park to Reverse to Drive a few times - temp rose consistently. ISTA tells you when you should do the final fill - two complications there - hot exhaust and darn slippery tranny plug with fluid dripping out at full. In any case, done now I hope for another 100,000 kms. Oh, and the stuff (tranny fluid) stinks - goodness…I'll take used motor oil any day over that! . Bottom line - listen to ZF, not BMW when it comes to the transmission fluid change. Thanks to everyone for the tips - very helpful.
06-03-2022, 02:05 AM | #18 |
Rep 125
M302_imola846.50 |
06-05-2022, 07:23 PM | #20 |
Rep 125
I just did all the fluids on my wife's 17 x5 40e on Friday at 70k.
Definitely not the worse I have seen but definitely worth changing. I might drain the trans again and just do a refill in the next few months. Fluid is definitely too dark for my liking. |
06-05-2022, 08:20 PM | #21 |
Rep 869
Drives: BMW X5 XDrive35i
I did the diffs, tcase, and gearbox all at 40k. ZF recommends 40k on the gearbox so I did all of them preventatively. Not a bad idea if you decide to turn it up.
2017 X5 XDrive35i X-Line | Sophisto Grey | MHD Full Flexfuel Tuned | Mosselman Turbo| Sutphin Tuning TCU | Nostrum Stage 2 HPFP | ER Charge Pipe | FTP F10 Inlet/ Turner F10 Intake Pipe | ApexBuilt Catted DP | VRSF FMIC | Zeitronix Flexfuel Kit | KateCool Oil Cooler | Variant Wheels | Conti DWS06+ | Custom 3.5" Catback |
06-06-2022, 10:21 PM | #22 | |
Rep 7,367
ZF states: "It is recommended, in the event of severe operating conditions, such as: - frequent highway driving in top speed range, - offensive, sporty driving style, - frequent trailer operation, being above average, oil purification (oil change) on automatic transmissions is recommended between 80,000 km and 120,000 km, or 8 years, depending on the load."
sukhk5272370.50 |
