02-05-2018, 06:27 PM | #3983 |
Driver 🇦🇲
32
Rep 43
02-06-2018, 09:31 AM | #3985 |
Rep 40,928
PM's sent.
02-06-2018, 12:49 PM | #3987 |
Rep 40,928
Hit the Update button in Launcher PRO.
02-07-2018, 11:39 PM | #3989 | |
Rep 155
02-08-2018, 06:34 AM | #3990 | |
Rep 40,928
02-08-2018, 06:45 AM | #3991 | ||
Rep 155
02-09-2018, 06:51 AM | #3993 |
Rep 40,928
PM sent.
Neuera09278.50 |
02-09-2018, 05:35 PM | #3994 |
Rep 218
Has anyone figured out how to change the interior light colors since the new update? i am unable to find the WERTE values for each color, since there is no drop down menu available with the color names anymore.
02-09-2018, 09:17 PM | #3995 | |
Rep 8,364
The problem is you can only change first six groups. |
02-12-2018, 02:22 AM | #3996 |
Rep 1
Hello everyone.
I have a problem with X6 F16 BDC (car is 2017 year with kessy, EWS5). It was killed by ISTA/D after attempt to add webasto option (ISTA/D programming). I have ICOM A2, latest ISPI and E-Sys 3.31, but I can do nothing with dead BDC (ethernet timeout at flashing). With another BDC (used) TAL calculating ends with errors, so I can't start programming. I know about keys, I have new one and ability to write keys too. Are there any step-by-step manual or hints to renew and flash used BDC? Regards, Casper. |
02-14-2018, 10:50 AM | #3997 |
Rep 2
Question about steering wheel heat. I read on an earlier post about another member wanting to increase the temperature of their M Sport steering wheel. I'd like to do the same. The wheel settings are most likely in BDC body, but does anyone know the exact FDL?
Thanks for everyone's work! |
02-14-2018, 11:04 AM | #3998 | |
Rep 528
02-15-2018, 02:08 PM | #3999 |
Member
7
Rep 32
Drives: 2014 X5 M-Sport
e-sys looking very strange
i just downloaded the newest software for all the coding but for some reason the e-sys program is super small font and i cant access many of the buttons because the menu windows are super small and only half the information is visible. Anyone know what could be causing this?
Thank you. |
02-15-2018, 02:30 PM | #4000 | |
Rep 40,928
02-15-2018, 03:07 PM | #4001 |
Rep 96
Drives: 2010 335d, 2018 540d
Smart Opener coding help needed, please
I’m retrofitting Smart Opener on my 2015 X5 35d. Wiring as per wiring diagrams for an X6 was straight forward. I have gone into coding BDC (no VO coding required as it is part of Comfort Access).
I have set VAM Enable Smart Close to ‘aktiv’ and left Werte at 1. I have set VAM Smart Open to ‘aktiv Splitdoors’. Other options were aktiv HK or aktiv HS. I left Werte value at 03. The only other entry that shows up when searching ‘Smart’ in BDC is under 3031 CaIntegration. It is CAH Smart Opener COD Fahrzeugtyp. It only has 2 Werte values that are changeable (no aktiv/nicht aktiv option). They are Wert=FF and Werte=FF. Does someone have an X6 with Smart Opener that could tell me what values I should set these to, please. Thanks very much! |
02-15-2018, 06:19 PM | #4002 |
Member
7
Rep 32
so is there any way i can fix it?
02-15-2018, 06:21 PM | #4003 |
Rep 40,928
No way that I know other than using a Laptop without QHD Screen.
02-15-2018, 10:39 PM | #4004 |
Rep 28
Drives: 2015 BmW X5 M-Sport 35i
Hi Shawn,
I like to request the link for the e-sys software. Thanks for the help. |
