09-22-2021, 07:35 AM | #1 |
Rep 176
Auto Folding mirrors?
Is it possible to have the mirrors on a 2016 F15 X5 automatically fold when I lock the car? I know you can long press the lock button which does this, but it also closes the sunroof blind so ideally I'd like them to fold automatically when I lock the car normally.
09-22-2021, 08:19 AM | #2 |
Rep 241
Yes you have to use Bimmercode to code the mirrors to fold in when you lock and unfold when you unlock. If I am not mistaken this has been covered several times, so use the search and find a step by step process to guide you on how to code it.
BMW F06 M6 GC (Fun Ride)
BMW F15 M-Sport 35iXDrive (Family Ride) BMW F48 X1 (Wife's Ride) 96 Camry (Daily Ride) |
09-22-2021, 11:35 AM | #3 |
Rep 176
Thanks, I'll see if I can find it.
09-23-2021, 11:48 AM | #4 |
Rep 7,535
If you have the BimmerCode app...you don't have to search far to find it...it is one of the "easy" coding parameters...and should be listed on the "supported coding" options listed on their web page...which also gives the control module that you'd need to go into to code it.
Here's a direct link to the BimmerCodeapp.com website coding options for the f15 X5: https://www.bimmercode.app/cars/f15/ EDIT: Under the MIRRORS heading...this is what it says:
09-23-2021, 01:23 PM | #5 | |
Rep 176
09-23-2021, 02:54 PM | #7 |
Rep 97
Check the sticky threads. There are a lot of codings in the cheat sheet.
2018 X5 35i
09-25-2021, 01:29 PM | #8 |
Rep 536
09-26-2021, 08:15 AM | #9 |
Rep 157
Drives: X7_M50d(2020), X5_30d(2015)
Via EsysX it is basically about the time which one needs to hold remote button/touch handle to fold the mirrors. Default value is about 2 seconds, so you just simply set it to 0 and that's it...
"F15 X5 Cheat Sheet", line 55+ "BDC_BODY" > "KOMFORT_SCHLIESSEN" > change value from "werte=0f" to "werte=00" |
