03-11-2017, 09:46 AM | #1 |
Rep 158
New 22' Rims Installed
No Issues / Perfect Fit No Spacers .
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS RACECHIP XLR |
03-12-2017, 08:10 AM | #8 |
Rep 8,774
Wait what??
Is that a typo or are you really 35 series profile tire both front and rear? I'm surprised you haven't seen any CELs yet because your front and rear diameter are two different sizes. This might cause issues in the long run with your center diff. A buddy of mine did this to his 535xi and he started noticing his traction control system going off randomly until he got the correct tires. Alan |
03-12-2017, 08:17 AM | #9 | |
Herr Oberst
244
Rep 531
'15 X5 35d
'16 740i |
03-12-2017, 08:40 AM | #10 |
Rep 158
photos of the entire car. handling is great and i have being in any type of roads. no vibration.
2016 X6 M PACK/MPPK
teodorjelev584.50 OFFWHITEX5325.50 |
03-12-2017, 08:56 AM | #12 |
Rep 158
Thanks for you tip. i will ask when the i take it to the dealer in my next oil change.
2016 X6 M PACK/MPPK
03-12-2017, 10:15 AM | #13 | |
Rep 11,128
You walking in with blatantly wrong tires, they could blame future differential issues on that. |
03-12-2017, 10:33 AM | #15 |
Rep 158
my is not xdrive is sdrive f16 Mpack. i will not have 25 is to low profile tire.
2016 X6 M PACK/MPPK
03-12-2017, 11:23 AM | #17 |
1148
Rep 2,426
I don't think it matters if there is a difference then.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
03-12-2017, 11:40 AM | #18 |
Rep 211
If S drive should be OK but speedo will read low because your rears rolling diameter is larger than it should be. Also would impact acceleration because you've effectively made each gear taller. If it works for you AOK but a 335/35 is clearly not the correct size for the car. Could have some impact on handling as well with larger rear and smaller front.
Chadmatic660.50 |
03-12-2017, 11:43 AM | #19 |
Rep 158
325/35 22 rear
front 285/35/22 i know speedometer is different for 4 to 6 miles more . no issue to me.
2016 X6 M PACK/MPPK
03-12-2017, 12:17 PM | #20 |
Rep 211
Right got it. Not stock rolling diameter for the car. in the front you have 35% of 285 for sidewall height and in the rear you have the same 35% of 325 which makes the sidewall taller hence larger rolling diameter. If you knew this and are ok with it then its all good.
03-12-2017, 10:07 PM | #21 |
Rep 8,774
Since there is no center diff to worry about I would pay attention to how the cars traction control system behaves. Especially in the rain because the car still thinks the front wheels are spinning slightly faster than the rears.
Alan
