04-12-2017, 12:05 PM | #45 |
Rep 11,891
ah screw it, this is way too complicated. Time to sell car.
04-12-2017, 12:43 PM | #46 | |
Rep 748
04-12-2017, 12:49 PM | #47 |
Rep 11,891
IIRC from the manual, when you push this button, this ensures you're driving a real auto-mobile.
artem123249.50 |
04-12-2017, 11:47 PM | #49 |
'06 525xi, '14 435xi, '17 X5 50i, '16 428xi GC
36
Rep 152
04-13-2017, 05:15 AM | #50 | ||
Rep 8,364
Back on topic, I code my cars for this exit sequence:
Chadmatic660.50 |
04-13-2017, 08:13 AM | #51 |
Registered Member
661
Rep 608
04-13-2017, 11:06 AM | #52 |
85
Rep 331
Chadmatic660.50 Flying Ace4984.50 |
04-13-2017, 12:07 PM | #53 | |
Rep 8,364
EDIT: Only 3 & 5 are coded for additional functionality. The rest operate as intended from factory. Last edited by Almaretto; 04-13-2017 at 12:21 PM.. |
04-13-2017, 03:16 PM | #54 |
Registered Member
661
Rep 608
04-13-2017, 03:43 PM | #55 |
Rep 8,364
04-13-2017, 11:00 PM | #56 |
Rep 1,181
Heh, you guys really think the engrs didn't consider these scenarios and built in fail-safes to the code/logic? I'll bet (and no, I'm not going to experiment and get back to you! ) nothing will happen if you push either button at speed.
Here's one example of how they thought of many scenarios: if you leave the shifter in manual mode after coming to a stop and then hit "P", the lever automatically gets pushed back to the right so that when you return to the car and start it up, you're not in manual mode and can't shift into Reverse or Drive.
04-14-2017, 04:32 AM | #57 |
Rep 1,887
This doesn't need to be coded. This is how they all work (this particular step, not the rest of it). Press it once, the engine shuts down and it goes into park. Unless, of course, the vehicle is moving, in which case, it won't.
Chadmatic660.50 |
04-14-2017, 08:08 AM | #58 | |
Registered Member
661
Rep 608
04-14-2017, 08:11 AM | #59 |
Registered Member
661
Rep 608
Thanks for clarifying, I have always put my car in park before pressing the start/stop button so I never noticed this feature.
05-05-2017, 02:50 PM | #60 | |
USAF Retired
207
Rep 216
Drives: F15.50i
I try my best to pull up as close as possible so they either: 1. Get the message and make the turn at the first available moment -or- 2. Be stuck with their nose so far out if they don't turn that traffic turning "across" their lane comes insanely close to clipping their front bumper! |
Almaretto2374.00 |
05-05-2017, 03:30 PM | #61 | |
Rep 8,364
These are one of the few situations where I use my horn:
05-05-2017, 03:33 PM | #62 | |
Rep 424
05-05-2017, 06:30 PM | #63 |
1150
Rep 2,426
The problem is now I two-press every I'm in...
2015 BMW X5 xDrive50i
BMW CCA 509766 |
11-14-2018, 01:54 AM | #65 |
Rep 31
Hi
To update the map in the car, it takes about 30 minutes. Should i have do it with the engine running, or it is possible engine off? However , when the engine is off, the radio and NAV stay on, only about 10 minutes. How is possible to leave NAV off for the whole time of the update, 30mn or more? As it is for one shot, i wouldn't make a specific codification. I have a X5 F15 thanks |
11-14-2018, 02:38 AM | #66 |
Rep 1,260
If the update does not finish before the nav switches off, it will resume from where it was left next time you start it.
So you have 2 choices: keep the engine running or do the update while driving, and if you do short trips it will complete the update eventually. |
