05-01-2017, 12:41 AM | #1 |
Rep 1
Multiple Alerts - Driving Stabilisation collision pedestrian
Hi,
I've fitted my own towbar, and electrics. Followed all of the instructions, and then started to get errors: - Initialisation of driving stabilisation - Front-end collision warning failure - Front-end collision warning restricted - Pedestrian alert failure - Pedestrian alert restricted Disconnected the towbar electrics, but alerts all there still there. Checked front fuses under glovebox, and back fuses, but all seem ok. Any ideas anyone ? The Carly error log indicates a fuse has blown. Whilst I know where the 3 fuse locations are, I cant find a blown fuse: 7. Immobilizer System: <---------------------------> CAS: - Fault: :A blown fuse or short circuit to ground Fa-FH - Code: 03001E - Fault: :A blown fuse or short circuit to ground Fh Bf - Code: 03009E - Fault: :A blown fuse or short circuit to ground fh driver - Code: 03011E - Fault: :A blown fuse or short circuit to ground Fh Bfh - Code: 03019E - Fault: :Missing Lin-slave steering column switching center (SZL) (Lin) - Code: 030350 - Fault: :Missing Lin-slave multi-function steering wheel (MFL) - Code: 030410 - Fault: :Internal fuse 1 defect Kl30F relay front - Code: 80408C - Fault: :Internal fuse 2 Kl30F defective relay front - Code: 804094 - Fault: :LIN error - Code: 8044D7 - Fault: :Missing Lin-slave control unit light (Bel), (Lin) - Code: D90D17 - Fault: :Missing Lin-slave control unit, driver assistance systems (Lin) / Missing Lin-slave control unit, driver assistance systems (transfer) (Lin) - Code: D90D1A <===========================> |
05-01-2017, 05:39 AM | #2 |
'06 525xi, '14 435xi, '17 X5 50i, '16 428xi GC
36
Rep 152
Clear the errors by going External>Transmission. Connect button then scroll down to clear errors. Disconnect and shut down esys. This is going by memory so if it doesn't make sense check out the coding thread and follow the instructions provided there.
06-18-2020, 10:08 AM | #5 |
Rep 1,915
06-18-2020, 01:41 PM | #6 |
Rep 1,255
As said 100 times before, many cars need the electronic power steering recalibrated after battery disconnection. You need ENET cable and ISTA. Otherwise, ask the Dealer to do the EPS calibration for you.
