02-18-2023, 09:27 AM | #1 |
Rep 108
Transmission fluid change on 40e hybrid
From other posts and Youtube, I'm familiar with the general procedure. What I have question on is how to keep the ICE on for the trans to reach the desired temperature range for the 2nd fill up? In Park, it shuts off automatically. I can switch from P to to manual to keep the engine running, but I'll have to hold the brakes and can't crawl underneath the vehicle to fill up (unless I have a helper).
Is there a better way? I have ISTA-D but the service function doesn't indicate any hybrid specific procedures (tho ISTA-D knows that it's connected to a hybrid) |
02-23-2023, 09:30 PM | #3 |
Rep 97
Save your time buy a Bluetooth obdii reader. You need to click a lot of buttons to read the temp using Isra. By the time you get there, tranny has already reached above the temp.
2018 X5 35i
02-24-2023, 10:00 PM | #4 |
Rep 108
T_N_C: will give that a try to see if the engine will stay on in Park.
MH20jy: I am pretty comfortable navigating in ISTA-D so that or other handheld scanners isn't the main issue in my case. Thank you all. |
