02-27-2023, 12:15 PM | #1 |
Rep 12
Does the Platinum extended warranty replace a faulty battery?
2016 X5 50i 32K miles and platinum extended warranty.
I started getting battery drain errors on startup and fault codes read like a failing battery. Have the car on a battery maintainer while I evaluate replacement options. Does the platinum warranty cover an old battery, or just a "defective" battery? |
02-27-2023, 11:36 PM | #3 |
Cattlecar
42
Rep 141
I have never seen an extended warranty cover an aged out "natural causes" failed battery. They can, but even this is only some select plans, cover batteries if they are damaged by a failed alternator. I'm referring to overcharging and a battery that swells. I looked at platinum plan on a 2015 brochure and it had the coverage list. Battery was not mentioned but a note " some items will have coverage is associated with a covered item". That is the statement where an overcharging alternator or a starter that sticks on and grossly overloads battery where it bulges and will not charge can get battery covered if dealer gets authorization and it is granted.
03-01-2023, 10:44 AM | #4 |
Rep 12
Confirmed with dealer, no warranty for "old" battery.
Coverage only for battery failure caused by failure of a part that is covered by the warranty. When asked for an example, told it depends. They seem to make it purposely difficult to figure out just what is and is not covered. |
03-01-2023, 12:05 PM | #5 | |
Rep 660
I listened to a Service Manager perform verbal gymnastics to some pour soul in the waiting area who believed his navigation replacement should be covered by the most expensive ultra-platinum-plus extended warranty he paid for. |
03-04-2023, 03:50 PM | #6 | |
Rep 1,042
There are essentially two types. Inclusionary and Exclusionary. Always try and get the later. Inclusionary policies list out the parts covered, which may look impressive at first glance, but with something actually breaks you’ll find it’s more than likely not on the list. Exclusionary policies only list the parts that aren’t covered (normally wear parts like batteries). More often than not, when something breaks, you’re going to be covered with this type of warranty.
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler http://www.e90post.com/forums/showthread.php?t=782212 |
zero2sixtyZ951.00 |
03-07-2023, 06:44 AM | #7 | |
Rep 30
Laguna Seca Blue238.50 |
