      04-06-2022, 08:50 AM   #1
NCThreePedals
227
Drives: 981 GT4/Audi Q8/F15 Diesel
Angry screwed up my door panel with rubbing alcohol - how to fix?
So I was cleaning the goop off the passenger door handle as it has been deteriorating over time due to the heat. Come to find out I was being too liberal with the rubbing alcohol and it started to drip down
I tried to catch it with the towel and clearly made things 100 times worse
I now ordered a new pull handle but my door is destroyed
I read online to use paints like SEMs or Duplicolor but I'm not sure if that will truly fix it or if I should take it to a pro to dye
Thanks
      04-06-2022, 09:10 AM   #2
momoboy
Drives: F15 35i 2017
I'm kind of surprised rubbing alcohol did that but regardless I have had amazing results with this product from Eastman. As long as you prep the surface (which means basically clean it) this will amaze you.
https://www.eastwood.com/ew-plastic-...=google&wv=3.1
You don't have to take the panel off. Just mask everything off and spray. The key is light coats and more is NOT better. Will bring that back to new looking
      04-06-2022, 09:53 AM   #3
NCThreePedals
227
Me too, I was honestly shocked how fast it took it off. I knew I screwed up when I saw the microfiber towel turned black when I wiped it off
Thank you! Will give it a try
      04-06-2022, 10:10 AM   #4
foo2002
foo2002's Avatar
Costa Rica
62
Drives: 2016 F15 30D
with this:
https://www.amazon.com/Chemical-Guys...%2C265&sr=8-13
      04-06-2022, 12:43 PM   #5
Swiftness~
Drives: F82 F15
Try ebay, I was quoted 200 to redye the entire panel ended up finding one in great condition for 120$ on ebay
      04-06-2022, 02:21 PM   #6
NCThreePedals
227
Originally Posted by foo2002 View Post
I had some at home and tried it, made it maybe 5% better
I found a local guy that's going to come out and do it tomorrow (recommended by my shop) for $100 so problem solved
Thanks everyone
