06-24-2021, 09:53 AM | #1 |
Rep 8
2018 X5 (F15) sDrive 35i lowering
Hi all,
I purchased a "New to me" sDrive and would like to lower it a little bit to reduce the wheel gap & body roll. I have been searching for a set of springs or Coilovers, but cannot seem to find anything for an sDrive.... I am only wanting to come down about 1-1.5" all around. Does anyone have any suggestions or know where I can actually find something for the RWD? Thanks! |
06-24-2021, 11:38 AM | #2 | |
Rep 3,647
You can send a message to him from this page - https://f15.bimmerpost.com/forums/member.php?u=76551 |
2018F15JW0.00 |
06-24-2021, 05:01 PM | #3 | |
Rep 8
07-03-2021, 09:04 AM | #5 |
Rep 8
That's the option I am seriously considering....were there any other parts you needed to gain a good alignment? Or are the factory ranges enough? I would probably set them at about 1.5" drop all around as we just put 22's and need to eliminate some of the fender gap.
07-03-2021, 09:56 PM | #6 |
Rep 118
07-03-2021, 11:21 PM | #7 |
Rep 71
Went with KW's, will do a review here shortly. Max dropped all around, rides amazing.
Turn in slop gone, body roll massively reduced, still a good ride a bit tighter but not too noticeable. No rebound problem either compared to just lowering with springs and leaving stock struts. I did this with a 335 and 535, coilovers huge difference. Also threw on 15mm/20mm spacers |
lionyard43.50 |
07-04-2021, 01:03 PM | #8 | |
Rep 297
07-04-2021, 01:31 PM | #9 | |
Rep 364
