07-01-2020, 01:44 PM | #1 |
Rep 104
50i Upper Oil Pan Gasket Leak
So, when I was changing my own front diff. fluid, I noticed an engine oil leak hidden by my front reinforcement plate. Had my local BMW dealer confirm that it is an upper oil pan gasket. So, this is a lot of labor to get to and quoted me 15.5 hrs and $600 bucks in parts. ($2,660 total) I'm at 73k miles. Having a local Indie shop quote it. Anybody else have this issue with their N63 engine? Any reliable cheaper fix, like an additive that will seal? Any other pointers? I looked up the procedure and seems out of comfort level with all of the dissasembly to the front drive system.
07-06-2020, 11:23 AM | #2 |
Rep 104
Based on zero responses, it seems that not that many have run across this issue. Lucky me! Dealer quoted $2,660, indie shop quoted $2,390; not much difference. Anybody in metro Detroit region have a recommended indie shop? I'm looking for 3rd quote. Also, can anyone recommend any other work that I should have done as preventative work since I will have the front axle/under oil sump area torn down. I'm thinking that I can save some labor if I get other typical problem areas taken care of at the same time. Maybe only parts cost since it will be most torn down already.
07-06-2020, 11:58 AM | #3 |
Rep 49
Actually this is a common oil leak I believe, not only on the 5.0 but also the 3.5. There is no quick fix...certainly don't recommend any oil leak sealer additives, as those may cause other issues.
It is a labor intensive process because the while front suspension sub frame has to be dropped to be able to get the oil pan off. $2600 isn't all that bad ... i think I've seen worse here on this forum. Just get a good indie quote that you can trust, and compare with the dealer. Good luck! |
07-06-2020, 05:16 PM | #6 |
Rep 104
It's hard to determine; it is not dripping on the ground, but the reinforcement plate is catching a lot of it and is quite coated in black dry oil. I can see wet oil though, so it is an active leak.
I was debatting how long I can go before fixing it as i can save an oil change if I wait a few thousand miles. |
07-06-2020, 07:05 PM | #7 | |
1636
Rep 2,995
07-06-2020, 08:46 PM | #8 |
Rep 2,590
Had mine replaced around 80k miles through extended warranty. Cost was around 2600 through the dealership. If I didn't have a warranty I'd probably have let it be since the car was only using a quart of oil every 3k miles.
Good luck and yes it's a labor intensive job. |
02-09-2021, 12:18 PM | #10 |
Rep 120
I just received a quote from the dealer to have the upper oil pan gasket replace on my 2017 50i for $3,500 but they were going to knock a few hundred off. It has 63k miles on it and it's more than just a small leak that I can put off. It's pouring out oil at this point! I just wanted it to last another 10k miles but think it's time to sell it now! Lesson learned!
02-15-2021, 09:25 AM | #11 | |
Rep 104
02-15-2021, 04:45 PM | #12 | ||
Rep 165
gutijoh10.50 |
02-16-2021, 03:14 PM | #13 |
Rep 104
02-16-2021, 09:23 PM | #14 |
170
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
What causes the gasket failure? Poor materials? Design Flaw?
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
05-26-2021, 12:58 PM | #15 |
Rep 77
82k on our 2017 50i, tuned stage 2. dealer reported upper oil pan leak. dealer fix $2700
Independent mechanic only saw a leak from the lower pan gasket and oil drain plug. $500 to fix. Last edited by adonnan; 08-05-2021 at 09:47 AM.. |
05-26-2021, 07:49 PM | #16 |
SPC
7
Rep 73
I was talking to this bmw tech cuz i have a very small leak too. He said I might want to go to bmw dealer and talk to them about this. Supposedly there is class action law suit regarding oil consumption and stuff on N63 engines this might be included in this. He also mention when you talk to them tell them that you car chugs oil and u have to fill it couple of times between oil changes. have not talked to them yet. If anyone does please let us know or if i get time i can mention it here.
05-26-2021, 11:30 PM | #17 |
Rep 5,002
05-27-2021, 09:37 AM | #18 |
Rep 161
OnlyGerman363.50 |
07-07-2021, 10:38 AM | #19 |
Rep 4
Do you have part list which they used ?
I am replacing myself in my garage and I wanna be sure if they replaced the bolts as well. It should be replaced but bmw part seller guy confirmed that I can use them again, while I am tightening them a few bolt did not meet the tightening torque specs and they were about the break, luckly I removed them and I am thinking to renew all bolts. That is why I wonder. Thanks.
