      07-05-2021, 04:44 PM   #1
Lighting.Grey
Lighting.Grey's Avatar
Drives: F86 X6M // E53 X5 4.8is
2016 BMW X6M  [0.00]
2005 BMW X5  [0.00]
Hi guys, my V8 engine started to burn oil since last service, roughly 2500kms burns 1 litter. I have an appointment coming up tomorrow to do an engine diagnosis, just curious any of you had an engine diagnosis before and what's it looks into?
      07-05-2021, 04:47 PM   #2
johnnydee
Drives: 08 M3 E92 SS II CFR 6 SP
What's the mileage?
Sounds like normal oil consumption to me.
      07-05-2021, 04:51 PM   #3
Lighting.Grey
2016 BMW X6M  [0.00]
2005 BMW X5  [0.00]
Originally Posted by johnnydee View Post
What's the mileage?
It's a 2016 model and currently has 61000kms on it.
The thing is it never burns any oils before, it started after last oil change.
      07-06-2021, 12:19 AM   #4
Lighting.Grey
2016 BMW X6M  [0.00]
2005 BMW X5  [0.00]
No one did an engine diagnosis before?
      07-06-2021, 10:09 AM   #5
RED_Y_
Drives: 2014 X5 3.5d
Are you sure it is burning oil? Not just loose drain plug or something?
      07-06-2021, 10:16 AM   #6
Lighting.Grey
2016 BMW X6M  [0.00]
2005 BMW X5  [0.00]
That I'm not sure, but I don't see any oils on the floor. Well, I just dropped her off to dealer, hopefully they can see whether the drain plug is tighten or no.
      07-06-2021, 11:44 AM   #7
scotty339
Drives: 2015 BMW X5 x35i M-Sport
I assume you are talking about your 16 X6M, so S63TU engine. F85/86 forum will be your best bet. I see you've asked.
I doubt your engine has a loose drain plug.
I assume you were told by the computer to add 1L, and not that you have been tracking its oil consumption (from a measured fill, then measuring subsequent top ups in relation to the oil sensors readout. That computer rounds to the nearest whole L IIRC. So you won't get add .25L or whatever, just add 1L, as its better to have slightly more than too little (in most cases, YMMV)
While there is a class action lawsuit again the N63/S63 engines for excessive oil consumption, 1L/2500KM would worry me personally. Possible you have a bad sensor, or were low a bit, and the computer sent the message.
You also mentioned white smoke on hard acceleration on another post. Is this still happening?
      07-06-2021, 12:01 PM   #8
Lighting.Grey
2016 BMW X6M  [0.00]
2005 BMW X5  [0.00]
Your assumes are right.
when I dropped off my vehicle this morning, I was told every 1500km/1L is within tolerance, but to me that seems too much.
For that white smoke, it happened once on the high way, when I floored the gas pedal(when you can feel the bottom click). And after about five minutes, I tried again but no smoke or just a little bit, not like the first time tons of smoke came out. After that I never pushed the vehicle so didn't happen again.
      07-06-2021, 12:04 PM   #9
scotty339
Alright.... I'd check your coolant, see if you have any discoloration (oil mixing)
White smoke + loss of oil can be a headgasket. Doubtfull given what you have said tho.
See what the dealer says.
      07-06-2021, 12:25 PM   #10
Lighting.Grey
2016 BMW X6M  [0.00]
2005 BMW X5  [0.00]
I will keep an eye on the coolant. Two weeks again I checked coolant level and it was normal.
I doubt they are going to find anything, I feel like those diagnosis are BMW BS, that's why I asked if any members done one before, and what's that about.
Anyway I hope they find the problem, since I still have warranty till end of this year.
