07-08-2021, 03:56 AM | #1 |
Rep 8
F15 carly back light coding
Hy
I have purchased low mile f15 Diesel, so far so good.. I have full Version of carly and I want to Code back light to be always On, but I just can't find Way to Code.. Can anyone help me with this one? I have Coded couple of things and It's working.. But back light I just can't find.. Thanks |
07-08-2021, 08:00 AM | #3 |
Rep 8
Yes,
Now when I Start car.. Front light ( I have LED) is OFF, but Angel eyes is always ON, headlight Switch is on 0.. And rear lights is OFF.. When I Turn Headlight Switch is on first Position right, then I have in Front Angel eyes ON, and back light ON.. And I want to have this on 0 Switch position.. |
07-08-2021, 08:43 AM | #5 |
Rep 8
07-08-2021, 10:25 AM | #7 | |
351
Rep 380
07-08-2021, 11:14 AM | #8 |
Rep 1,260
I wonder if those rear lights are designed to be on all the time, I mean how long before they start fading out like any LED...
I know that Gxx have those on from factory. |
07-08-2021, 12:42 PM | #9 |
351
Rep 380
LED bulbs can last up to 10 -15 years, ballast is one that can go bad. But should still be min 5 years. I'm basing on light fixtures that get turned on 24/7. I'd assume bmw uses top quality materials. Im not worried too much about it
07-08-2021, 01:47 PM | #10 | |
Rep 364
Drives: F15 M50d / ex E90 335i / Panda
07-08-2021, 03:03 PM | #11 |
Rep 8
07-08-2021, 03:06 PM | #12 | |
Rep 8
Im not worry that It will be ON all time.. |
07-10-2021, 11:48 AM | #13 |
Rep 8
So..
I have tryed to Code, but I just can't find Way to do It.. Seams that I don't have that Option?!? I don't have Bimmercode, just Full Version of carly app, just to have in mind, if somebody can tell me or Show how can I Code, I would be thankFull.. |
07-10-2021, 01:53 PM | #15 |
Rep 7,485
You haven’t mentioned what model year (build date) your X5 is. In the pic you posted…it shows you looking in the BDC (body domain controller) module.
Since the rear DRL parameters were moved to the REM module in later model years…and rear DRL info isn’t listed in the BDC module for your X5…you may want to look for rear DRL coding in the REM (rear electronics module). Things change during the production run and the REM is one of the changes that occurred. Does Carly list an REM control module for your X5?
07-10-2021, 02:59 PM | #16 | |
Rep 8
Sorry, My X5 is 8/2017 produced.. I really don't know, I hope that It can read REM.. Thank you! For some reason, on I-drive screen He won't play M Performance Logo On starting I-drive.. It was working fine, but then I have It change to normal (due to Service at stealer) and later I have It Coded to M start logo, and It doesn't work.. 🤦*♂️😡 + It throws 40+ faults.. Good old Carly.. |
