03-05-2015, 05:39 PM | #2 | |
Rep 7,063
I used a slim trim removal starting from the inside of the X5 working myself from the top to the bottom. It is held in by clips around the edges so put a tiny amount of force and they pop out all around.
03-05-2015, 07:25 PM | #3 |
Rep 3,990
As Taran said, you just have to get a thin plastic tool that allows you to wedge in between the black gloss area (start at the top) and the painted mirror cap. Slow work your way around and it will eventually pop right off. It's not difficult at all.
06-24-2016, 06:01 AM | #4 |
Rep 5,066
opasha do you think a credit card would work? Or would it be too flimsy?
06-24-2016, 06:09 AM | #5 |
Rep 3,990
It might, but just be careful you don't damage your paint on the mirrors because of the credit card surface. A chipped card might work better since they are much more rigid/smooth.
06-24-2016, 08:44 AM | #6 |
Self-Deprecating Narcissist
7266
Rep 6,561
walk over to your local paint or hardware store, home depot, lowe's etc... purchase a .50c plastic putty knife / spackle tool and do it right... very similar to a platic trim tool if you don't have access to one locally.
06-24-2016, 08:53 AM | #7 |
Rep 5,066
^^ I was actually thinking about that as well.
Thanks for the tip.
06-24-2016, 09:12 AM | #8 |
Rep 18,713
It should be easier if you remove the glass then push the locking clips out to remove the mirror covers.
Just be careful in taking the mirror off, as it will drop and break or scratch or hit the car if you didn't catch it. It has the autodim and heated wires connected to the mirror though, but don't rely on it.
06-24-2016, 09:32 AM | #9 |
Rep 5,066
Thanks Ben, I was thinking the same but with my luck, I will probably drop them ha ha!
06-24-2016, 09:42 AM | #10 |
Rep 3,990
Ben's idea is good, but not as easy as using the plastic tool. That is the easiest/safest method without scratching anything up. I recently did the Euro mirror install, which is why I'd go with the other way .
06-24-2016, 10:45 AM | #11 | |
7266
Rep 6,561
06-24-2016, 11:52 AM | #12 |
Rep 867
I was installing the CF mirror covers on my F30 last night. I assume the lay out is the same. If so, there is no way can move the caps without open the mirrors, because it has 3 clips holding the caps and it will break if trying too hard. Will upload some pictures once I finish up with my F15. Picking the car up next week.
Also, check on Youtube. type in remove BMW Mirror Caps. It has a video shows how to do it. Don't break your OEM mirror caps while you might still able to sell them.
2022 BMW X4MC
2018 Tesla Model X 100D Last edited by Sharp_Cai; 06-24-2016 at 11:58 AM.. |
06-24-2016, 06:38 PM | #13 |
Rep 18,713
Lol. I tried both method, removing the mirror glass gave me a cold sweat. Since the mirror doesn't have the plastic outer rim like the 2/3/4/5/6/7 series.
I could careless if it fall and break, I just scared of it to snap break on my hand. It would be a nasty cut. The other method, I used my own hand with no tools. I just wear a rubber latex glove to help the grips. And start pulling from the outer top.
06-25-2016, 12:55 AM | #14 | |
Rep 867
2022 BMW X4MC
2018 Tesla Model X 100D |
06-25-2016, 03:21 AM | #15 | ||
Rep 18,713
06-26-2016, 12:48 AM | #16 |
Rep 867
Intersting...Did you also open the mirror to try?
2022 BMW X4MC
06-26-2016, 05:19 AM | #17 | |
Rep 18,713
RG Sport - Mirror Cover removal DIY http://f15.bimmerpost.com/forums/sho....php?t=1277633
08-23-2017, 12:30 PM | #18 |
Rep 67
Hey fellas. I had no issue getting the old mirror caps off, however, I when I put the new CF caps on, the passenger side would not snap in tightly, how matter how hard I pushed it on it would easily come off with a pretty light touch (certainly not good enough for highway speeds). The outermost tab seemed like it would not grip and click in like the OEM one would. For those that have done this, did you use the AutoTecknic caps? They are definitely thicker than the OEM. Wondering if anyone else had issues like I have? I have asked them to send me a replacement passenger mirror cap, but I'm not confident it will work if the mold they're using isn't perfect (the next one they send may have the exact same issue). Any info/experience with the AutoTecknic CF caps is greatly appreciated.
08-23-2017, 12:32 PM | #19 | |
Rep 18,713
