10-29-2017, 01:10 AM | #2 |
Rep 18,713
Are you trying to change the tip to different color or different shape?
Also, is your X6 is the 35i or 50i?
10-29-2017, 07:58 AM | #3 |
Rep 859
10-29-2017, 08:41 AM | #4 |
Rep 174
10-29-2017, 08:52 AM | #5 | |
Rep 18,713
Non M Sport, use rubber mallet and hit it from the back. It will slip off.
10-29-2017, 08:54 AM | #6 | ||||
Rep 174
10-29-2017, 09:00 AM | #7 |
Rep 18,713
Oh, I thought you just want to change color.
If you are going to change to aftermarket tips, I can't help you with that. I thought you want to take it off to get them painted different color. I only can help you with changing to OEM M Performance square tips.
BTConverse0.00 |
10-29-2017, 10:37 AM | #8 |
1150
Rep 2,426
Will the 50i tips slip off if I hit them with a mallet also. My tips need to get painted I think. I don't want to do the car wrap method.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
10-29-2017, 05:41 PM | #9 |
Rep 18,713
No. 50i is weld on.
10-29-2017, 07:26 PM | #10 |
Rep 174
So if I want to paint them what is the process?
10-29-2017, 07:46 PM | #11 | |
Rep 18,713
Paint it, then re-install them. Seems like best for you to let a shop to do it.
01-28-2018, 07:25 PM | #12 |
Rep 6
What is the size of the stock exhaust pipe once the tip is removed from a X6 35ix F16?
Looking for a clamp on tip that has a larger outlet but will have the correct inlet to clamp the stock exhaust piping. Thanks! |
04-03-2019, 08:25 AM | #13 |
Rep 100
Did you replace the tip 35i tips with a new set? if so, what did you get and any pics?
