09-26-2016, 01:56 PM | #2 |
Rep 664
Do you have CarPlay? We've only had the car since Friday (2017 with CarPlay) and have had no issues with either an iPhone 7 or an iPhone 7 Plus. I don't know if CarPlay vs non-CarPlay makes a difference but I think it might.
2021 BMW M3 Comp
2021 BMW X3M 2018 BMW M3 - SO/SS ZCP - Gone 2017 BMW X5 40e M-Sport - Gone 2015 BMW M3 - Gone - ED Pickup June 2nd, 2015 |
09-27-2016, 07:11 AM | #4 |
Rep 256
Drives: '17 F15 MSport
I don't have an iPhone 7, but my iPhone 6 is having issues with playback. I can no longer use the toggle wheel on the steering wheel to change/advance songs and if I switch from radio to phone playback I have to physically press play on my phone. To get the music to start The only way I can change/advance songs in iPhone playback is with the iDrive knob or on the phone itself. I suspect these issues are due to the most recent iOS updates. Looks like I will finally need to load my music library on a thumb drive.
I should add that these issues occur when connected via Bluetooth and plugged in to the USB port. |
09-27-2016, 01:16 PM | #5 | |
Rep 1,448
This is iP7 10.0.2, AT&T, using BT not USB
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
09-27-2016, 09:05 PM | #6 |
Rep 256
09-29-2016, 12:22 PM | #7 |
Rep 664
Just saw this. You guys are not alone and apparently BMW is aware and working with Apple to fix.
http://www.macrumors.com/2016/09/29/...-audio-issues/ |
10-04-2016, 09:14 PM | #8 |
Rep 256
Just updated my phone to iOS 10 and music functions work in the X5 again. My issues must have been related to the last iOS 9 updates.
10-05-2016, 12:53 AM | #9 |
Rep 663
Mine would stop playing music via bluetooth. I read that there is an issue and BMW is working on a fix.
I removed the phone from the car and the car from the phone then re-paired them. So far so good. BTW - My issue seems to be an IOS 10.0.2 issue as it didn't happen prior to the update. I have a 6S and a 7. Both had the same issue |
10-11-2016, 08:46 PM | #11 |
Rep 247
Drives: 2015 F15 50i, 2016 E89 35is
I had the same problem, oddly enough a complete wipe and restore of the phone has fixed it completely.
10-25-2016, 03:04 AM | #13 | |
Rep 2,697
What helped is to set "Forget this device" on the iphone and then start installing CarPlay again (but that takes time). Once (I have this car only for a week now) during the process screen froze, then went to NO SIGNAL and it regenerated in 5 minutes. |
10-26-2016, 10:36 PM | #14 |
Rep 86
Following up on my own post, I had intermittent Bluetooth issues with my iPhone 7 running iOS 10.0.x and iDrive 5. I am using CarPlay.
After upgrading to 10.1, I have (*knock on wood*) have had no issues with Bluetooth or CarPlay. CarPlay will now often load before I'm ready to back out of my parking space which is a marked improvement over when I first bought the car. Last edited by athanyel; 10-26-2016 at 11:24 PM.. Reason: Blasted typos... |
12-14-2016, 06:36 AM | #18 | |
Rep 1,448
Anyone else having issues with the latest Apple update?
12-14-2016, 06:46 AM | #19 |
Rep 95
I didn't realize 10.2 was out until you just posted this. So, what's going on now? Back to locking up the screen once you start streaming or is there a new issue?
Regards, Rodney
2016 X5 xDrive50i |
12-14-2016, 09:54 AM | #20 |
Rep 1,448
In my case, I cannot stream music from my phone. I do not see any category and more importantly the playlists.
Unlike others upthread, this problem did not show up until I 'upgraded' to iOS 10.2
12-14-2016, 04:53 PM | #22 |
Rep 1,448
I should report that my post about iOS 10.2 was in error. There is no problem with this update as I simply miscalculated the iDrive position.
