01-17-2024, 09:11 PM | #1 |
Rep 168
Power tailgate issue
Hi all
Troubleshooting a power tailgate issue on my 2018 F86 X6M. The power tailgate does not lift using either the key fob or driver side button. However, the tailgate will shut (using either key fob or driver side button) after it has been lifted by hand. This used to be an intermittent issue - the power tailgate would have issues lifting for a few days and then work for several weeks without issue, but now it seems to have become permanent, which leads me to believe a part somewhere has finally completed worn and failed. A few things to note:
This issue wouldn't bother me so much if the tailgate was easy enough to lift by hand, but it is damn heavy (or feels that way because of the mechanical resistance). Appreciate your thoughts/experiences on anything similar. Last edited by I Luv BMW; 01-17-2024 at 09:17 PM.. |
01-18-2024, 03:50 AM | #2 | |
Rep 48
Had a similar issue with my 2018 F86, where the tailgate would unlock, pop open as it were, but could not lift the tailgate. Once it was open however, it would shut normally as the weight of the tailgate allowed the remaining working strut to close it. I had no error message for the fault, but once I replaced defective strut it opened as it should. My fault finding method was to disconnect them one by one and test. The working strut would open and try for a second, but then stop due to resistance, whereas the the defective strut did nothing. Cheers |
I Luv BMW90.50 |
01-18-2024, 11:03 AM | #4 | |
Rep 48
Fairly easy to replace, only thing is they have to be initialized afterwards, but if you have access to ISTA it's an easy thing to do. Perhaps Bimmercode or Bimmerlink can do the initializing aswell? If you PM me your email I can send you the pdf's of the repair routine from ISTA. |
I Luv BMW90.50 |
01-18-2024, 04:02 PM | #6 |
Rep 2,665
Drives: Goggomobil
Try with the dealer to have the thing replaced under warranty. Maybe they will pay for the parts and you for the labour. A couple of years ago I had this issue with a M50d X6 and BMW came to the party. Good Luck
F86 X6///
